Coolant and Brake Fluid replace - Bimmerfest - BMW Forums
Old 10-23-2019, 03:57 PM
akii akii is offline
Mein Auto: NY
I need to do a coolant and brake fluid flush. Does anyone know how many gallon on the coolant or Brake Fluid I need?
2014 335i Xdrive Automatic.
F30 BMW 335iX. Type Code: 3B93
Old 10-24-2019, 10:06 AM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
I would get gallon of coolant. As for brake fluid, usually takes a liter to flush it. If you do it yourself, buy 1.5-2ltr as you donít want to run out of fluid during flush.
Old 10-24-2019, 11:46 AM
Mein Auto: NY
They recommend 50/50 mix. 1 Gallon will yield 2 gallons.
Brake fluid came with 12 fl oz. 1 Litter will need about 3 bottles. So 5 bottles will be enough?
Old 10-24-2019, 12:57 PM
namelessman namelessman is online now
Mein Auto: bimmer
Online search says N55 engine has coolant capacity of 10L(10.5 quarts). 1 gallon coolant + 1 gallon water 50/50 is around 8 quarts, but it is likely some coolant will still be trapped in engine block.
My mechanic charged me for 1 liter($10-$12?) of DOT4 for the brake flush, so around 5-6 bottles of 12 fl-oz should be plenty.
Old 10-25-2019, 07:18 AM
Our BMW Our BMW is offline
Mein Auto: 328xi GT
Here's some good info on brake fluids: https://www.fcpeuro.com/products/bmw...id-81220142156
Also if you capture the old, it's lifetime guaranteed.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
Old 10-25-2019, 05:05 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
1 liter = 33.814 US fluid oz. One 32 oz. (0.946 liter) bottle of Prestone or Valvoline synthetic DOT 3/4 brake fluid - $6-8 at the big box parts places - will usually do the job, unless you want to pay more for the low-viscosity stuff (like Pentosin DOT 4 LV brake fluid).
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 10-25-2019, 05:11 PM
Mein Auto: bimmer
Originally Posted by John in VA View Post
1 liter = 33.814 US fluid oz. One 32 oz. (0.946 liter) bottle of Prestone or Valvoline synthetic DOT 3/4 brake fluid - $6-8 at the big box parts places - will usually do the job, unless you want to pay more for the low-viscosity stuff.
Yes BMW brake fluid is DOT4 low viscosity for $4/12 ounces, local indy uses Pentosin low viscosity, which sells for $50/5L.
Old 10-28-2019, 07:33 AM
Mein Auto: NY
why people use Motul brake fluid? Is it much better than OEM? temperature wise???
Old 10-28-2019, 06:12 PM
Compare the dry boiling points of the products you're interested in & choose what you prefer.
___________
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
