1995 E34 Electrical Troubleshooting Manual - Page 2 - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 03-03-2015, 10:47 PM
Mr._Graybeard Mr._Graybeard is offline
Mein Auto: '95 540i, '95 525it
http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
Wiring should be similar to the 525i
Old 03-03-2015, 11:16 PM
e21brs e21brs is offline
Mein Auto: e21 3.23
Thank s
Decorations that will be I know it's different, but I know it wrong
Old 07-06-2015, 10:43 PM
Luis ruvalcaba Luis ruvalcaba is offline
Mein Auto: BMW 540i
What causes throttle position sensor problems? My car accelerates but have much power as it should.
Old 07-09-2015, 07:53 PM
yolowantit yolowantit is offline
Mein Auto: 1991 BMW 525i e34
not sure if anyone else encounters this problem during the winter but doors and windows will not work when below freezing point. 30degrees Fahrenheit... Would assume this is an electrical problem but living in new england, you could only imagine the frustration of not being able to lock/unlock your doors. And no fresh air. Any help???
On my 91 525i e34
Old 01-19-2016, 11:28 PM
capricornbmw capricornbmw is offline
Banned
Mein Auto: E36
Originally Posted by _Ethrty-Andy_ View Post
Im going to sticky this if the OP doesnt mind? Id like to rename the thread if you wont take offence, just remove the 1995 part? is that okay?
Please note, to people using this in the future, european market cars will be very similar if not identical, but some further research may be required.
It will also be of NO use to 520i owners, they run a totally different body loom to other E34 models
Thread was not renamed.
Old 10-05-2016, 03:53 PM
ralphm ralphm is offline
Mein Auto: 1992 bmw535i
thks
Originally Posted by djchuck View Post
I found this online and thought that there may be some forum users here that could make use of it.
Enjoy!
http://www.jonkensy.com/DTA/ETM/Sear...g%20Manual.pdf
saves us all a lot of guesswork
Old 04-06-2017, 09:41 AM
CAVIN CAVIN is offline
Mein Auto: e34 540i bmw
Hey guys, I'm a newbie from South Africa, and also owns both E30 325i, and e34 540i automatic, there is no spark on the engine, the windows, sunroof, and central locking does not work, and the hazards of indicators doesn't work, any clue what the problem is? thanks guys.
Merwin
Sent from my E5633 using Bimmerfest mobile app
Old 04-25-2017, 10:33 AM
dwkestell dwkestell is offline
Mein Auto: 1994 530i
I have a 1994 530i - I've only owned it for a couple of week, but notice that the dash output for Odometer, trip odo, and shift selector will intermittently flake out, and then display properly. I haven't started to dig, but wondering if anyone else has experienced this or where to start?
Also - the traction control light stays on after the switch has been pressed. Fuse, ABS, other??
Old 09-11-2017, 06:31 PM
Bavarian Raven Bavarian Raven is offline
Bavarian Raven
Mein Auto: 1995 BMW 540i
1995 BMW E34*Electrical Troubleshooting Manual
After a visit to a body shop to fix a ding, my fog lights have never operated properly. The left light gets no power, the right one is on when ever the car is running and the switch does not turn it off. Also the dash always says 'FOG LIGHT'. Maybe we will be able to trouble shoot the problem with this manual. Oh yea! the body shop denies having any thing to do with the lights.
Old 09-11-2017, 06:47 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
as mentioned the foglights are on the same line. Which means you have a short or broken line. Typical spot is at the foglights connector itself. Check the connector for breaks in the line or any bare wiring.
Sent from my SM-S902L using Bimmerfest mobile app
______________________________________
86 BMW 325es...Sold,
92 BMW 535i...Totalled
89 BMW 535i aka "Zaraki"... Totalled,
90 BMW 325i m60 swap... Sold for a friend,
95 e34 525 5 spd S52 Swap aka "Grau"...Sold,
01 Cosmoschwartz on Dove e38 740i msport... Sold,
01 Titan Silver on Schwartz e38 740i Msport Aka "Lucky Lilly... PROJECT KILLER WHALE
00 Chevy 4wd s10 BLazer LT aka "El Squeeky"... Sold
03 E53 x5 4.6is...Daily
Old 09-11-2017, 06:53 PM
Now the light on the dash. Was the switch working prior?
Old 09-11-2017, 08:17 PM
Check your grounding points. Current is probably jumping from another circuit where the ground is poor and grounding through the right fog light.
Old 09-11-2017, 08:21 PM
Yep, I recently resurrected the right fog light by cleaning the connections between the harness connector and the twist-off cap on the fog lamp housing. The connection sees a lot of moisture down there and is not waterproof.
Old 09-18-2017, 05:42 PM
Bavarian Raven
E34 Fog lights
The switch was working prior to the body shop work. Thanks for all the good ideas one day soon we will work on this litttle problem
