E63/64 - Engine - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Closed Thread
Old 11-15-2017, 11:42 PM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
E63/64 - Engine
Fuse Layouts
Reference: 645Ci Fuse Layout (Link by TopDownInFL)
https://www.bimmerfest.com/forums/sh...d.php?t=487072
__________________________________________________ __________________________________________________ _____________
Reference: 650i Fuse Layout (By coug60)
https://www.bimmerfest.com/forums/sh...d.php?t=748208
Reference: M6 Fuse Layout (By whatheheck (M5Board))
http://www.m5board.com/vbulletin/e63...e-lay-out.html
Servicing
DIY Microfilter Change along with Lower Housing Removal (By tampamark)
https://www.bimmerfest.com/forums/sh...d.php?t=679975
Oil Change and Check Control Reset (By Yorgi)
https://www.bimmerfest.com/forums/sh...d.php?t=508299
DIY - Oil Change with Pics (By bimmerzone)
https://www.bimmerfest.com/forums/sh...d.php?t=654029
DIY Spark Plug change - with illustrations (By tampamark)
https://www.bimmerfest.com/forums/sh...d.php?t=679882
DIY air filter k&n! (By buronan)
https://www.bimmerfest.com/forums/sh...d.php?t=146683
Engine
Common Problems link
https://europeanedgeoftallahassee.co...w-s-n62-engine
Cylinder Head Attached Parts
Engine Oil Level Switch Replacement (This doubles up as an Oil Level, Temperature and Quality Sensor)
PDF Added at the bottom of the page
Upper Timing Case
Changing vanos solenoid o-rings on the n62 engine (By gk73a (Bimmerforums UK))
http://www.bimmerforums.co.uk/forum/...ngine-t258593/
For reference and fault finding help
https://xoutpost.com/bmw-sav-forums/...-misfires.html (By X5only (Xoutpost.com))
https://us.autologic.com/news/bmw-vanos-system (Autologic.com)
It should be noted to ensure the solenoids are seated all the way in, typical codes that can be thrown are timing codes and can be found at the bottom of the Autologic link.
Cylinder Head Cover
DIY: BMW 2005 645Ci / E63 / Crank Case Vent Valves CCV (By bigtyme562)
https://www.bimmerfest.com/forums/sh...d.php?t=572330
E63 E64 N62 V8 Valve Cover Removal W/ Pics DIY (By Sick645ci)
https://www.bimmerfest.com/forums/sh...d.php?t=685470
Also see Removing and installing Timing Case and Cylinder Head Cover PDF's linked at the bottom
Reference Only: N62/E65/E66 Valve Stem Seals Replacement, Valve Cover and Timing Chain Case Gasket (By Knight's Master Tech)
https://www.bimmerfest.com/forums/sh...d.php?t=803418
DIY Increased Emissions Gas Cap fix (By Skarv)
https://www.bimmerfest.com/forums/sh...d.php?t=653239
DIY: DMTL Pump (Increased Emissions - code 1434) (By Skarv)
https://www.bimmerfest.com/forums/sh...d.php?t=671137
Everything you didn't want to know about your Dynamic Drive DIY Valve Block (By wilson009, forwarded by FredoinSF)
https://www.bimmerfest.com/forums/sh...d.php?t=450240
645Ci Fan Removal (By Hsurf)
https://www.bimmerfest.com/forums/sh....php?t=1252810
Waterpump - Thermostat
Thermostat Replacement CE and loud aux fan issue fixed (By oRIDDLERo)
https://www.bimmerfest.com/forums/sh...d.php?t=776791
DIY for thermostat (By Skarv) Written directions, post no.2
https://www.bimmerfest.com/forums/sh...d.php?t=676805
Thermostat modification (By HULKED)
https://www.bimmerfest.com/forums/sh...d.php?t=723361
Cooling System Pipe
Coolant Leak Repair (Cap w Seal and Expanding Coolant Pipe) w Pics (By Bmwaudivwdude)
https://www.bimmerfest.com/forums/sh...d.php?t=525719
Vacuum Pump
BMW E63, E64 N62 Engine Vacuum Pump Oil-Leak Fix (By Timm (Bimmerforums UK))
http://www.bimmerforums.co.uk/forum/...k-fix-t489081/
Videos
N62 Engine Oil Change and PCV Valves
BMW Replacing Coolant Transfer Pipe N62 and BMW Replacing Timing Cover & Valve Cover Gaskets N62
N62 Engine Build Part 1 and 2
File Type: pdf 13 72 001 Replacing air cleaner element 645.pdf (273.3 KB, 50 views)
File Type: pdf bmw_updated_engine_crankcase_ventilation_system_vacuum_specifications_sib_2009.pdf (85.0 KB, 310 views)
File Type: pdf Secondary Air Injection System Fault Codes P0491 P0492 BMW 5 Series 2004.pdf (294.8 KB, 49 views)
File Type: pdf SIB 11 01 07N62 and N62TU Crankcase Ventilation System Cold Climate Conditions.pdf (437.0 KB, 37 views)
File Type: pdf RA Removing and installing top left timing case cover (N62_N62TU).pdf (91.0 KB, 50 views)
File Type: pdf RA Removing and installing top right timing case cover (N62 _ N62TU).pdf (91.8 KB, 36 views)
File Type: pdf RA Removing and installing_sealing left cylinder head cover (N62_N62TU).pdf (204.8 KB, 56 views)
File Type: pdf RA Removing and installing_sealing right cylinder head cover (N62_N62TU).pdf (195.2 KB, 67 views)
File Type: pdf RA Removing and installing_replacing alternator (N62).pdf (54.7 KB, 100 views)
File Type: pdf RA Instructions for disconnecting and connecting battery.pdf (29.8 KB, 49 views)
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Closed Thread
