Battery Replacement Question - Bimmerfest - BMW Forums
Old 10-09-2019, 07:08 AM
jalumi69 jalumi69 is offline
Mein Auto:
Hello,
I have 2012 528i, I want to replace my battery - My battery is original BMW 105Ah AGM, I have found a Duralast battery from AutoZone which doesn't show its 105Ah, but says H8-AGM. My question is - Will this battery be OK for my car? Do I need to register it to work efficiently?
Thank you in advance.
Product Details
Part Number: H8-AGM
Weight: 60.76lbs
Warranty: 3 years
Notes: OE Exact Fit
*** 900 cold cranking amps (1000 cranking amps) ***. 170 reserve minutes. Warranty consists of 3 years free replacement. Battery is vented to outside of vehicle. OE manufacturer used various size batteries in production. Carefully size to fit. Vehicle computer system must be reset, contact your service specialist. AGM Valve Regulated Lead Acid (VRLA) is required. See the vehicle owners manual for safe and proper battery installation. Check the customer's vehicle, battery installation could take up to 30 minutes. See owners manual for battery location.
Battery Group Size Designation: 49
Reserve Capacity: 160
Battery Voltage: 12
Cold Cranking Amps (CCA): 900
Positive Terminal Side: Top Right
Old 10-09-2019, 07:17 AM
Doug Huffman's Avatar
Nuclear engineer
Originally Posted by jalumi69 View Post
Hello,
You must register it for best service life. It will work without registration but will not last as long and may cause other problems. Registration will demand AH capacity as that is the controlling parameter for proper charging.
Old 10-09-2019, 07:32 AM
Mein Auto:
Thank you
Thank you Doug - I really appreciate your reply
Old 10-11-2019, 02:25 PM
JeffDunes JeffDunes is offline
Mein Auto: 2011 535i Sport 6sp MT
You can replace it yourself and then drive to the dealer or a good independant who can register the new battery for you and also indicate the capacity (e.g 105ah) if you use a new battery with a different capacity. You can also get an app like the Carly app which will allow you to do both functions.
2000 328ci Sport 5sp MT
1958 Isetta bubble car
Old 10-11-2019, 02:40 PM
Breach Breach is offline
Mein Auto: F10
Do check at what amp-hours this battery is rated. From what I can see it's in the 90-95 Ah range. So, if your OEM one was 105 Ah you need to have someone first do a conversion in ISTA or use e-Sys (or a coding tool) to change the capacity *before* registering (different operation). Ideally, you should buy a 105 Ah AGM battery, though 95 Ah would be fine - in 2010/2011 95 was the default battery for Fxx. With 105 Ah you would only need to register.
Old 10-13-2019, 02:11 AM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
check my video below. you register yourself.
Old 10-15-2019, 01:49 PM
Mein Auto:
Thank you all
I really appreciate for the informative response - I returned the battery from AutoZone as I did not install it yet, and went and got one from BMW 105Ah (The difference was just a few dollars in price (less than $15)) I did register it using Ista+.
JeffDunes - I did ask the dealer if I put in the battery myself will they register it for me, thay wanted $180 just for that - I told them "No thank you".
Thank you all
