Folding mirrors - Bimmerfest - BMW Forums
Old 10-05-2019, 06:36 PM
Josef.88 Josef.88 is offline
Mein Auto:
Folding mirrors
So I have a 2004 e60 And I wanted to switch my mirrors with folding mirrrors
I was able to purchase folding mirrors however when I got them I tried to swap the mirrors. My cars mirrors has two connectors one with 5 and the other one with. 4 wires. And the one that I purchased. Only has 3 wires into one connector. I saw on google how to probably adapt it but it links up to the KGM module which I don't have aperantly my modules are on the door. Do anyone knows if I could make this work or have I bought a useless folding mirror
I also tried looking some up with two connectors but for some reason all the folding mirrors I see have three connectors or one. But my car receives 2.
ID:	867133   Click image for larger version
ID:	867135   Click image for larger version
Old 10-05-2019, 07:35 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
Useless purchase until you get all the parts, modules switches then coding.
Probably have some wiring to do too.
Old 10-05-2019, 11:25 PM
Funnster Funnster is offline
Mein Auto: 2010 535i
If you have a pick your part yard near you, just source the things you are missing. RealOEM is a guide to see what you need to get. Or check eBay as it's sometimes cheaper just to order a used part.
On Realoem you can also see if the parts are interchangeable, meaning if a module you have will do the job or if you need to swap it with something else.
Coding can set up the car so if you hold down the lock button on the key fob they will pivot inwards, and outwards by holding unlock.
Probably need the armrest switch, I don't know if you can code the car without the switch to use just they keyfob. The switch and the mirrors may need to be in communication.
My guess on the wiring is that everything is already there, BMW, like most car companies these days, offer a lot of options which usually work with the existing wiring loom.
These cars aren't hard to update/modify and since they are found in junk yards used parts are pretty cheap. Have fun with it!
Old 10-06-2019, 07:08 AM
Mein Auto:
So I am station in Korea and Have not seen any yunk yard near by. My car is American specs but yes. Now I'm stuck with these cool folding mirrors that I can't even use. If anyone knows on maybe an adapter or something. Maybe a how to your it your video. To make it work I would really apreciate it.
Old 10-06-2019, 04:43 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
whats the last 7 of the vin?
Specializing In Breaking Things Professionally
15486372<-----
Old 10-07-2019, 10:47 AM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
Check out newtis.info
Somewhere there will be a wiring diagram showing what wires need to be added. I suspect it's all going to be taken car of inside the door. You may not even need to code in the option.
You'll definitely need the correct driver's side door switch module, or to add your own button for the mirrors. The missing wires likely go to a few empty terminals on the module in the door.
Old 10-08-2019, 09:32 AM
Jtbgonesailing Jtbgonesailing is offline
Mein Auto: 05 530i & 81 320i
Folding mirrors was not a option on the 04-05 model year e60's. Actually I believe it was a LCI addition, could be wrong on the LCI portion. At any rate for a 04-05 good luck.
Old 10-12-2019, 06:26 PM
djrynyc djrynyc is online now
Send a message via ICQ to djrynyc
Mein Auto: 2004 530i
I have 04 530i with m5 mirror , you could do it with some modifications need to be done
Sent from my SM-G935P using Tapatalk
Old 10-18-2019, 11:29 PM
Mein Auto:
The last seven or my vin are
B811421
Do you have an idea on how I can have it done. I have a set of spare ones with folding motors but the connectors only have 3 wires and the one that my car has are two connectors one with 5 wires and the other one with 4 wires. And there is no purple wire in it
Old 11-11-2019, 08:02 AM
Mein Auto:
Do you know any solution for my issue I have at hand. Or how I can find a video on how to make it work on my car
Old 11-11-2019, 09:27 AM
Get on newtis.info and dig up your car's wiring diagram for the mirrors. You may get lucky and just have to run an extra wire.
Old 11-11-2019, 02:36 PM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
I have the folding mirrors on my 2004, they fold manually. Just replaced glass on driver recently. Had to sort out which one to get. There are definitely different mirrors available, quite a list. Mine was heated and auto-dim, and connectors were definitely different than non auto-dim.
Jim
2004 BMW E60, N62, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 11-11-2019, 03:32 PM
Need to swap the cable and motor to make m5 e50 mirrors work on 04 530i e60, that what i did to make them work
