vin number"0" in 10th place...(year) - Bimmerfest - BMW Forums
Old 03-03-2008, 12:28 PM
lep lep is offline
Mein Auto:
if someone know more about the "0" . A friend is telling me mi z3 is not from 1997.
vin: WBACH71 010LA26523
Old 03-03-2008, 01:05 PM
Giznaz Giznaz is offline
Need a tow?
Mein Auto: '99 Z3 2.8/'11 X3 35i
Real OEM says it is:
You Have Selected: P Z3 roa Z3 1.9 M44 ECE 19961000 L N
Production Code: CH71, batch ID: 48079
Non-USA roadster, built 1996-10, likely 97 model year, 1.9 Liter M44 engine
http://www.realoem.com/bmw/select.do
Old 03-03-2008, 01:08 PM
greyish's Avatar
greyish greyish is offline
tire consumer
Mein Auto: 99 z3c
Agreed.
ETK lists yours as a 1997 Z3, left-hand drive, 1.9 (M44). Build date of 1996/10.
Old 03-04-2008, 08:23 PM
rehostman rehostman is offline
Mein Auto: 2007 X5 4.8i, 2009 E90 M3
I still don't understand why people use Real OEM or ETK for decoding the VIN. They are both incorrect.
The 10th digit of the VIN is the vehicle model year, and starts with the letter D for MY83. In the alphabetical sequence, the letters I, O, Q, U, and Z are left out. Then they use numerical digits, starting with number 1.
This leads to the following sequence for the 10th digit:
D 1983
E 1984
F 1985
G 1986
H 1987
J 1988
K 1989
L 1990
M 1991
N 1992
P 1993
R 1994
S 1995
T 1996
V 1997
W 1998
X 1999
Y 2000
1 2001
2 2002
3 2003
4 2004
5 2005
6 2006
7 2007
8 2008
The VIN you are providing cannot be correct. 0 is not a valid 10th digit.
Cheers.
Patrice
2009 E90 M3 Melbourne Red on Black Leather
2007 X5 4.8i Monaco Blue on Saddle Brown
Old 03-04-2008, 08:29 PM
Need a tow?
Cheers.
Hmmm I haven't found it to be wrong yet, in my dealings.
However, YMMV, TTIW***, LOL, IIRC and other internet acronyms
Old 03-04-2008, 08:49 PM
I am not familiar with these acronyms except for LOL so I am not sure what to make of these. But the VIN is an IEEE standard. The following sites give a fairly complete description of the structure of a VIN for cars:
www.decodethis.com
www.vehicleidentificationnumber.com
Clearly, the digit 0 is not a valid vehicle model year number.
I may have been unlucky with my use of ETK and RealOEM VIN decoders.
Cheers.
Patrice
Old 03-04-2008, 09:59 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Cheers.
The VIN posted is correct.
Old 03-05-2008, 08:13 AM
postalZ3 postalZ3 is offline
Mein Auto: 2000 Z3 2.8
1. Non-USA model?
2. Prod date and model year will cause confusion
My vin YLF71040 prod date of 6/99 is a 00 model
Tony
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 03-05-2008, 11:05 AM
Hi.
I may have poorly explained myself. The VIN posted WBACH71010LA26523 is correctly posted but is an invalid VIN as per the IEEE standard. Most of the VIN decoders on the web do not pick up on that.
As postalZ3 shows it with his/her VIN (YLF71040) his Saprtansburg-produced Z3 in June of 1999 is a Model 2000 vehicle and therefore has a Y for its 10th digit.
I really have no idea why the 10th digit of lep's VIN is a 0.
Cheers.
Patrice
Old 03-05-2008, 01:46 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
Hi.
Cheers.
It is a valid VIN, only the North American produced vehicles followed the ISO 3779 VIN standard strictly in 1997, but this vehicle was manufactured in Germany. Here is a quote about VINs:
"The European Union has a similar regulation for VINs, but it is less stringent than the North American rule. European VINs are not required to include year, factory or vehicle attribute data. However, the two systems are compatible. While most countries have some form of VIN system that is compatible with the North American system, cars that are imported must have their VIN number entered into the MVR database along with enough information to explain what the codes are if the original VIN system differs from the ISO 3779 standard." ( http://auto.howstuffworks.com/vin.htm )
Old 03-05-2008, 01:52 PM
greyish's Avatar
tire consumer
Mein Auto: 99 z3c
I'm positive someone will correct me if I am wrong, but all Z3s were built in SC plant. The WBA... has more to do with manufacturer and origin of the majority of parts.
Also, the VINs for Z3s were WBAs and USCs at different points. I happen to have a USC... Regardless, all built in South Carolina.
Edit: the explanation may still be accurate since it was not labeled as a US-built car, even though it was put together here.
Old 03-05-2008, 01:54 PM
greyish's Avatar
tire consumer
Mein Auto: 99 z3c
I can only guess at this as the zero in that position baffles me as well. With some cursory futzing with ETK and some VIN decoders, my guess is that the "0" in that position is necessary to make the checknum work. That still does not explain to me why they would do that, but that is my guess.
Perhaps Ron can fill us in?
Old 03-05-2008, 03:19 PM
jsc's Avatar
jsc jsc is offline
I think the issue of using a Euro VIN on a US built car is that technically the BMW Spartanburg plant was on German soil in 1997, as part of a free-trade zone, so US VIN numbers were not used then for Z3s produced in that free trade zone. Looks like this ended for BMW on or about 2001 due to this court case: http://www.usdoj.gov/osg/briefs/2001...0238.resp.html
BMWs assembled in Spartanburg while the plant was in the free trade zone were subject to import duty for US sold vehicles.
Also, from an old post:
"10: Model Year (applies to US cars and some non-US/NA)
T-1996, V-1997, W-1998, X-1999, Y-2000, 1-2001, 2-2002
Often, but not always, "0" for non-US/NA cars"
- https://www.bimmerfest.com/forums/sho...1&postcount=35
Last edited by jsc; 03-05-2008 at 03:34 PM. Reason: Add link to year digit explanation
Old 03-05-2008, 04:29 PM
greyish's Avatar
tire consumer
Mein Auto: 99 z3c
I want to say I remember an old thread about this, possibly even some discussion in the one you linked, but mine is a 99 non-M Z (12/98 build) and it has a 4USC.. VIN. Which is a US designation. Whereas M coupes all seem to have WBSC.. from 1998 all the way to late 2001 production (anecdotal), the last ones having 5UMC.
So while that court case may very well have had something to do with it, it still seems as though the origin of the bulk of the parts might have something to do with it, at least prior to that case. That is my quasi-educated guess.
Old 03-05-2008, 06:28 PM
Awesome. I think that quote should rest this case.
Patrice
Old 02-26-2018, 10:58 PM
ksaigon ksaigon is offline
Send a message via ICQ to ksaigon
Mein Auto: 320i
Also have same question, I have VIN WBA8X310X0G831783 and do not know when it's manufactured
Old 02-27-2018, 04:47 AM
vintage42's Avatar
BMW CCA 1405
Put the last 7 into the decoder at bimmer.work to see your build data:
http://bimmer.work/vin/3175d80b3fd71...67b9d95c33fca/
You have a Metallic Red 320i made on 2017-01-23.
Old 10-19-2019, 01:49 AM
Gew Gew is offline
Mein Auto:
I know a Japanese car which has the digit zero for tenth character in it's VIN as well. All online VIN decoders leave out model year, sigh.
