BMW X3 Battery Always on? - Bimmerfest - BMW Forums
Old 10-16-2019, 09:07 PM
kkevinlin kkevinlin is offline
Mein Auto:
Bmw x3 2004 2.5i; I have an aftermarket backup camera connected to a cig lighter port, will the car battery drain overnight if i leave the backup camera plugged in?
Old 10-16-2019, 09:09 PM
Twi7ch Twi7ch is offline
Mein Auto: 2004 X3
Yes, the cigarette lighter has constant power.
Sent from my Pixel 2 using Tapatalk
Old 10-17-2019, 05:00 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
Search for my and others' old posts on how to find/make switched power for dashcams, etc.
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 10-19-2019, 08:12 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is online now
BeeemerBro
Mein Auto: X3 M54 150k
So after a couple of days sitting waiting for the shocks to come in...i fire up the 06 X3 start to drive and fine the head lights are slow to come on. As I drive and then break...the head lights go out. With each subsequent breaking the lights go out!
My problem is...
A) alternator is bad
B) weak battery
C) gas pump soon to go out
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 10-30-2019, 12:03 PM
jlex jlex is offline
Mein Auto: 2005 X3.0i
Sounds like A & B are your problem. Charge up battery and test it to see if it's holding a charge. Also hook up volt meter to see if you're outputting 14 volts.
My '05 was draining the battery if left unused for a week or so. Got out the volt meter to measure parasitic drain... (it shouldn't be reading more than 50 milliamps). Found out the circuit associated with the panoramic sun roof was draining power. Removed that fuse (as I don't use the sunroof) and problem solved. Well worth the time to track it down.
Old 11-06-2019, 12:08 AM
BeeemerBro
Ive now started to take each batt to aa or az for a days charging if needed. If there are any problems with any car the winter will expose them starting with a weak battery. I learned this from my years living in Milw. But now in the south....i still do it just out of habit.
Sent from my SM-G531H using Tapatalk
Old 11-06-2019, 06:57 AM
Lugging a battery around to a FLAPS for charging doesn't seem like much fun to me... why not just get a good charger for the home and use it w/o having to remove the battery?
Old 11-06-2019, 07:25 AM
dukedkt442 dukedkt442 is offline
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
