Video module. Video INPUT possible? - Page 14 - Bimmerfest - BMW Forums
Old 10-18-2019, 04:36 PM
vibbelito's Avatar
vibbelito vibbelito is offline
Mein Auto: 2007 730i E65
I only get my crackling sound when on 474Mhz with my diy adapter to the active antenna that I got with my DAB+ reciver. Any other frequency ive tried and I get a no signal instead.
My DIY adapter straight into the VM gives me a no signal on all frequencies that I have tried.
I'm at a loss here.
Skickat från min SM-G955F via Tapatalk
Old 10-21-2019, 06:41 AM
vibbelito's Avatar
Okay one reason that I don't get any picture if it is true that input = output. Might be because I wasn't able to set any lower refresh rate than 50hz on my pc at 720x576 and standard definition DVB only supports 25 fps at that resolution based on this
I will check if I can use any of those other resolutions at 25hz refresh rate.
Old 10-21-2019, 12:19 PM
vibbelito's Avatar
It's at least trying at 1920x1080 @60i
Old 10-21-2019, 12:32 PM
vibbelito's Avatar
And almost there at 1440x576 @25i
This is the background picture I had set at the moment.
Old 10-21-2019, 02:54 PM
vibbelito's Avatar
Well in kind of work now. I managed to find a program that could set detailed costume screen resolution details. So now it just has to be fine tuned to the proper aspect ratio.
This is 720x576 @30i
I took a short video also so you can see the glitching that is present right now but this might be due to bad reception/transmission.
So now I have to figure out how to get the picture straight into the VM without broadcasting it. Probably a very specific frequency that has to be set.
Old 10-22-2019, 03:47 AM
vibbelito's Avatar
Found this where BMW explains the difference between 8 wire (10 pin) LVDS and 2 wire LVDS that they use now. They are much compare them to the difference between parallel port and USB. Parallel and serial.
Old 10-22-2019, 06:31 AM
vibbelito's Avatar
Okay after reading some pages on the web I can assume that my bad/ no reception is due to me mixing a 75 ohm cable and 50 ohm cable. That creates reflection that might look like this and can result in package loss.
So in order to defeat this at least partially I'll most likely have to build something like this that reduce that.
Old 10-23-2019, 10:18 AM
vibbelito's Avatar
I did some more experiments and tried another much smaller 15cm mag mounted 50 ohm tv antenna which seemed to work much better but still the sound is crackling and the picture breaks up every 2 seconds with 2 flashes.
I wonder if it could have anything to do with the blanking interval?
This is the settings I use in the software right now
The tv tuner seems to be able to cope with any horizontal resolution but the vertical seems like it can't be set any higher than 576i
And it seems to also work with 30hz and 35hz.
Old 10-27-2019, 03:17 PM
vibbelito's Avatar
LVDS pinout
i found a pinout of the 10 pin lvds port for the MMIF.
Name:	lvds pinout.png
Old 10-28-2019, 12:49 AM
cimdahers cimdahers is offline
Mein Auto: BMW e65 730d
Tnx
Sent from my LYA-L29 using Tapatalk
Old 10-28-2019, 02:27 AM
vibbelito's Avatar
Hum, looking at that pinout it looks like I wired my LVDS to HDMI cable wrong.
I wired it up based on the signal name so TX1 to tx1 tx2 to tx2 and so on.
Based on this lvds to DVI-D:
So this would be wrong based on the pinout I found.
The only thing I got right was the sync signal since that was clearly labeled on the wiring diagrams.
Old 10-28-2019, 06:11 AM
vibbelito's Avatar
Since I can't get the tv transmitter to work at all with a direct input into the VM and only partially with the soldered antenna, I'm going to try to make this instead and hope that the picture and sound will be stable.
If that doesn't work I'm stuck..
Old 10-29-2019, 05:36 AM
cigas4 cigas4 is offline
Mein Auto: BMW E65 745D
You are mirroring screen here?
I have made similar upgrade using Miracast Dongle and AV To RF Converter.
Basically I can mirror screen of iphone, android or laptop.
My TV module has only analog receiver, so it is useless now when analog TV signals are shut down in my area.
Old 10-29-2019, 05:45 AM
vibbelito's Avatar
Here I am going directly from a laptop into the HDMI to Digital tv RF converter.
What av to rf converter do you use?
And what cables?
I can't get the car to find the channel when I go directly from my av to rf converter into the VM.
Old 10-29-2019, 05:55 AM
And what cables?
I use AV cables to RF converter.
I use this converter:
https://www.ebay.com/itm/AV-To-RF-Co...3HRnO-XBQQZCuw
Old 10-29-2019, 05:57 AM
vibbelito's Avatar
Thanks, how do your RF to fakra cable look like?
From this transmitter to the tv module
Old 10-29-2019, 06:01 AM
I go directly to antena plug of TV module, from RF converter.
Old 10-29-2019, 06:03 AM
vibbelito's Avatar
Can you please link the cable you used?
Old 10-29-2019, 06:11 AM
It is custom made cable
As I remember I just bought two different connectors, for RF module side and for TV module. Then using some tv cable and these two connectors, made a simple cable.
I can take a photo later today.
Old 10-29-2019, 07:04 AM
vibbelito's Avatar
Oh cool, yes pleas do take a picture
How did you solve the power for the modulator? A 12v to 230v converter?
The reason why I didn't go with one of these and chose a digital one instead that has proven to be very problematic is so that I can have HQ stereo sound since analog is only Mono sound. And so that I can name the channel and have it show up as HDMI on the idrive screen
Old 10-29-2019, 07:14 AM
I just through away complete part of original power supply and put additional 12VDC to 5VDC regulator (because RF converter itself is working on 5VDC internally).
Which device you use?
You are right, mono sound is pretty crappy, but the rest is no problem for me. Anyway, my TV module only supports analog TV signal, so for me this is the only option.
Old 10-29-2019, 07:38 AM
vibbelito's Avatar
I bought this modulator
"HDMI to DVB-T HD digital Encoder Modulator 1 Route 1080P RF Transmitter EMB220T"
https://s.click.aliexpress.com/e/FvPX2MFIx
It works but I am not able to set a default resolution in the thing that the car supports (720x576i) so it works as so as input=output so I had to download a program to my pc to force that resolution over hdmi.
If I can't get this to work properly with a cable like yours I will get the same analog transmitter as you.
Is there any delay between you changing anything on your phone (or what ever) and it showing up on screen?
Old 10-30-2019, 07:40 AM
So yesterday I have checked my car and found out that I have just cut into one of two antenna coaxial cables and soldered my cable coming from RF module.
Now I remembered that plugging one of antenna cable out and putting there my own cable from RF module, gave me some error message on diagnostics software - TV module is missing original antenna. So then I have decided just to cut into original cable.
Old 10-30-2019, 07:44 AM
vibbelito's Avatar
Do you mean that you cut your original car antenna in half and soldered to that?
Or do you mean that you just tapped into original antenna by removing the shielding and soldering onto that without splitting the original antenna in half?
Old 10-30-2019, 07:50 AM
Yes, "tapped" is correct word
Just removed small piece of shield on side of original cable to reach wire in center of cable and soldered mine there. Original cable is still in one piece
