Turn off hatch lights on X5 while tailgate is open? - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-03-2010, 09:58 AM
ccm9fc ccm9fc is offline
Mein Auto: 2007 X5
Does anyone know of a way to turn off the two small lights in the back hatch while it is open? We leave it open for long periods of time, and don't want it to drain the battery. Also, they have never gone off automatically (i.e. not after 15, 30+ minutes of being open).
Old 06-08-2010, 05:59 PM
acrackl acrackl is offline
Mein Auto: 2011 X5 35d
I discovered the same - there appears to be no way to turn them off. Contrary to what the manual says, lights do not go off after 15 minutes. I will bring up this issue when I take my car into dealership for another issue, but not sure how much help they will be.
First BMW Ordered Apr 2010, in my garage since Jun 2010
2011 X5 XDrive 35d, Deep Sea Blue Metallic, Oyster Nevada Interior
Old 08-11-2010, 09:35 PM
Blk Mtn Dan Blk Mtn Dan is offline
Mein Auto: 2001 X5
I have an 01 X5 that I use as a home inspection vehicle [245,000 miles on it]. I leave the back doors open for 3-4 hours at a time, sometimes twice a day - never had a battery problem. I have replaced the battery 3 times [once when it was 3 days old on warranty.] I wouldn't worry too much about it. I can't remember even repalcing a bulb, but maybe I did once.
Old 08-14-2010, 10:23 AM
Jetblackstreak Jetblackstreak is offline
Mein Auto: 2001 X5, 1996 328is
There is a simple fix for this. Close the locking mechanism on the upper hatch. Simply use a pencil or pen to do this. When you want to close the hatch, make sure to press the hatch button to unlock the latch before closing. Hope this helps.
Old 01-11-2011, 09:37 AM
Rob13 Rob13 is offline
Mein Auto: BMW X5
Hi There I have the same issue
I guess you can remove the bulbs ( I may do this )
Old 12-23-2017, 03:04 PM
mrstellabmw mrstellabmw is offline
Mein Auto: 1995 525i
Thank you Jetblackstreak for your easy and successful solution. Cheers.
Old 12-24-2017, 05:52 PM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
Just be careful. I have done that and son not knowing that I have done it, slammed the hatch...
And latch mechanism cost $350 ...
Old 12-26-2017, 07:45 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/05 X5
If I remember right just push the dome light button up front. It turns off all the lights if the doors or hatch is open. I know it worked on the front lights and I think it worked on the hatch ones too.
My BMW howto's
1995 318is
1997 528i
2000 323i 400k miles and climbing
Converted from automatic to 5 speed manual
2005 X5 3.0 with Nav, adaptive headlights etc
2013 X5 xdrive35 Turbo
Old 12-28-2017, 04:13 PM
Rickster X5 Rickster X5 is offline
Mein Auto: X5
+1 on this!
2003 X5 3.0
Old 01-02-2018, 09:40 PM
Echo304 Echo304 is offline
Mein Auto: 2005 X5 4.4i
Definitely another +1 to this, but you my have unnecessarily spent that money... I broke mine, and found that it's basically just a plastic piece within the mechanism that breaks. You can zip-tie it, and it returns to normal (ish) function.... There's a post about it somewhere if you google it.
Old 01-03-2018, 12:35 PM
Believe me I have looked a that very closely and this thing got damaged quite well. and zip-tie maybe good to get you home but I would not consider it as a permanent fix.
I do not partially or "sort of" fix broken things - if it can't be fixed by means of restoring 100% original performance/operation, I replace it.
Old 01-03-2018, 03:47 PM
I get that but not all of us have the money to shell out on a complete replacement, when the fix restored complete use of the hatch other than the fact that I have to be at the hatch to open it.
Old 10-21-2019, 03:30 PM
afn63537 afn63537 is offline
Mein Auto: 2001 X5
put LED bulbs in the hatch. You could leave it open for a week and the battery wouldn't care, but the cats might move into your ride.
Old 10-24-2019, 08:33 AM
FREE100KSECRET FREE100KSECRET is offline
Mein Auto: 545i
Simple
LED light swap is great way to avoid a dead battery issue as the rear hatch lights will get so hot if left open it melts plastic clips and light unit falls out, so replace bulbs with LED's and it will not be an issue, you can leave lights on for weeks without heat or battery drain.
