LED indicator bulbs - how to avoid hyper flash? - Bimmerfest - BMW Forums
Old 10-21-2019, 05:07 AM
theroux theroux is offline
Mein Auto: 2006 E60 530i
I've been tempted lately to change my indicator bulbs to LED bulbs but I'm well aware that there would be light out warnings on the iDrive if I did this, which I'd counter by having the cold/warm checks coded out by a shop I know. However, one issue I've also read about is hyper flash which I'm not sure how I would fix. Has anyone changed their indicators to LED? I'm a pre-LCI so it's the only choice I have.
I've also thought about changing out the brake lights (not the tails, just the stop bulbs) with LED since they light up quicker and would definitely improve safety, but I also wonder what might happen if I did that.
Old 10-21-2019, 06:48 PM
Toddmori Toddmori is offline
Mein Auto: 2008 550i Sport
You need a series resistor (CANBUS error canceling). The relay is tripped by resistance in the line, and LEDs have much less resistance. Same reason you get hyper flash when you have a short on a conventional system
Sent from my ONEPLUS A6013 using Tapatalk
Old 10-21-2019, 08:55 PM
Interesting, thanks for clearing that up. I've heard that there are some bulbs with inbuilt resistors but I've found no such thing.
What about for the brake lights? I imagine they wouldn't hyper flash considering they're not made to flash in the first place and wouldn't flicker on start up if I code out the checks.
Old 10-22-2019, 03:48 AM
I'm not sure, as I haven't done anything with my taillights, however, my flights do have a wicked flicker on vehicle startup, when the system is doing diagnostics
Old 10-24-2019, 01:29 AM
Is that with the coding done or is that without coding?
Old 10-24-2019, 03:46 AM
That is with coding out errors with Carly
Old 10-24-2019, 05:19 PM
Interesting. Did it let you code out hot and cold checks or was it just a generic disable function? I was under the impression from others that the flicker is only caused by the system sending out small resistance checks and coding out the checks stops those signals.
Old 10-27-2019, 06:45 PM
Just coded out the errors. The flicker only last 30 sec, right at startup. Pretty sure it is just the system diagnostics
Old 10-28-2019, 09:07 AM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Just FYI...the bulb check is not only at startup. There is a periodic bulb check after startup -- I don't know the period.
Old 10-28-2019, 09:43 AM
After I get the front end put back together, I'll have to watch for that
Old 10-28-2019, 12:32 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
I solved the LED compatibility problem by leaving the factory lights in place. I bought an X5 from a friend who had gone nuts replacing every possible lamp with LEDs. After a short time they all started flickering and some failed. I replaced them all with incandescent.
Old 10-28-2019, 02:06 PM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
You have to disable the cold and warm checks, not just the warnings, to get rid of the flicker.
Old 10-28-2019, 10:39 PM
Thank you that's what I was thinking. I find it odd then that it's possible to turn off the errors but leave the hot and cold checks active.
Old 10-29-2019, 05:14 PM
It is more disabling the error alerts than removing the errors
