Cute little trick to diagnose blocked CCV system... - Page 4 - Bimmerfest - BMW Forums
Old 04-23-2018, 03:09 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
Originally Posted by e46help View Post
What if the O-ring is bad on the oil dipstick what is still make the glove blow up
Sent from my LGMS210 using Bimmerfest mobile app
My guess is that it would not and oil would be leaking out the dipstick tube mount point, but if you have over a 100,000 miles on your BMW engine, it's recommended to change your CCV and hose's, so you should consider doing it.
Old 04-23-2018, 06:48 PM
rdl rdl is offline
Mein Auto: 530i 2003
Assuming everything else is working properly, a bad O-ring would leak air into the crankcase since the CCV maintains a vacuum of 4-6 inch water column. The engine would see this as a vacuum leak, just like any other.
Or are you asking if both the CCV and the O-ring are bad?
If the CCV failure mode is to create pressure rather than vacuum (i.e. blow up the glove) then air would leak out at the faulty O-ring and could carry oil droplets with it, making a mess around the tube.
Regards
RDL
Old 10-21-2019, 10:26 AM
e39s e39s is offline
Mein Auto: 530i
Here's a quick test showing a failed CCV. Listen to that extreme suction as the cap is removed with the car running. There should be very little or light vacuum.
Old 10-21-2019, 07:14 PM
cn90 cn90 is offline
Well,
When a PCV system fails, usually it is from a clog ---> increased crankcase pressure ---> oil leak past the seal etc.
The video you posted above is from a different mode of failure: too much suction. Funny enough, this is exactly what you want in an M54 engine to reduce oil consumption.
The "BavarianE39 mod" is exactly that: creating a lot of suction to reduce oil loss from leaky piston rings.
