DIY F30 Battery Replacement (Helpful) Info - Bimmerfest - BMW Forums
Old 04-07-2019, 06:45 PM
RRRize RRRize is offline
Mein Auto: BMW
I went to the dealer for a routine checkup and my SA informed me that it's time to replace the battery. What? Really? Seemed strange to me since all of my electronics were working pretty stellar along with the fact that I routinely forget to turn my lights off when I walk into a store or restaurant and when I return, I've never had a problem! I wondered why I had seen no indication that the battery was on the outs.
In any event, my SA insisted that diagnostics revealed that the battery absolutely needed to be replaced and that it would be $540 to do it at the dealership. Seemed crazy excessive to me, but he went on to explain that it is a special kind of battery designed for modern cars with tons of electronics and the ECO start/stop feature, blah, blah, blah. He further explained that after the new battery is physically installed, it must be registered - which basically means you have to tell the car's computer that it is a new battery so that it's power management will readjust to the new, more robust source of power. He further explained that registration is done via computer. So, he says that THAT is what justifies the $540 price tag. Of course I wasn't biting. So I set off to buy a battery and do the installation myself. This posting details how I did it myself for less than $200. I am hoping it will help someone else with an F30 (which is what I have - 335i Sports to be exact). In the end, I replaced the battery and registered it myself and it was ultra simple! Ö.but finding the right battery wasn't! Here's my experience:
Although the install and registration was truly a breeze, finding the right battery and the tools (software and ODB2 adapter) to do the registration was an utter nightmare! A couple of days of scouring the internet and forums as well as making a bunch of phone calls resulted in my getting everything I needed. So to start, my OEM battery was BMW branded and had 2 part numbers on it, listed as follows:
S: 61 21 7 575 327
AW: 61 21 6 924 022
Not sure why it has 2 part numbers, but thought I'd share that for reference. The battery has a rating of 12V - 90Ah - 900CCA and is an AGM (Absorbed Glass Mat) type.
I'll spare you all the details of my arduous hunt for the right replacement, but will say that I discovered that there is only a small hand-full of auto battery manufacturers out there and BMW is NOT one of them. Like many other companies, BMW simply chooses a battery manufacturer, purchases the batteries from them and then slaps a BMW label on the battery and then neatly tucks it into the trunk of our cars. Turns out that my battery with the part numbers I listed above is manufactured by Exide. But BMW has since discontinued that battery and replaced it with a battery of slightly different specs. The battery they are now using to replace the above listed part number is made by EastPenn. The power ratings on it is 12V - 92Ah - 850CCA. The EastPenn part number is 9A49. EastPenn's exact branding is EastPenn Intimidator 9A49. BMW's part number is 61 21 2 353 812. I searched high and low for the EastPenn battery and could not find it for less than $214. So I bookmarked it and shopped for alternatives with the exact same specs.
I wound up finding a Bosch battery, made by Exide with the exact specs of the EastPenn (12V - 92Ah - 850CCA) at PepBoys. To be exact, it is the Bosch Premium AGM Battery, part #49-850BAGM. 4 year warranty/guarantee - It was on sale (25% off)! So, I pulled the trigger! (I know the Bosch battery is made by Exide because I called Bosch customer service and they told me as much) I Installed it in less than 15 minutes and then registered it with the BimmerLink app on my iPhone!
To register the battery, you will need an app for your iPhone or Android AND a compatible ODB2 adapter to plug into your car. I decided to go with the BimmerLink app instead of the more popular Carly app because with Carly you have to pay $50+ a year if you want to keep the full version working. Personally, I am just not cool with the whole annual fee bit. I mean, I hear from many that the Carly app is truly awesome! I'd gladly pay $100 or more for it - ONE TIME - because of all that it offers. But having to pay a $50+ fee every yearÖ. I dunnoÖ. It's just me I suppose. And I am not cheap at all, but somehow I am rubbed the wrong way being forced to pay an annual fee for an app that should be like a tool in a toolbox. Surely, some of you may be inclined to flame me for my position there. Flame on, but please be civil. Maybe there's a stellar justification for the annual fee that I am unaware of or have not considered. Make the case Ö.maybe I'll be persuaded.
In the meantime, as I mentioned above, I went with BimmerLink which is $26 one time and a Veepeak OBDCheck BLE OBD2 Bluetooth Adapter for $27 on a flash sale at Amazon. (If you go with Carly, you will have to buy their adapter, which is $75 I believe).
I registered my battery with BimmerLink in less than 2 minutes!
NOTE 01: If you're using Carly, when you go to register the battery, since the original battery was 90Ah and the new one is 92Ah, you might be inclined to select the REGISTER OTHER BATTERY TYPE option. Don't do that. The Carly app does not have a 92Ah option. Just select REGISTER SAME BATTERY TYPE. If in your own research you find a battery that that you want to purchase and it's 80Ah or 105Ah, in that case select REGISTER OTHER BATTERY TYPE, then, when presented with the different amp options, select the appropriate one.
NOTE 02: With the BimmerLink app, you basically have no choice but to register same battery type. So if you get a battery that's 90Ah or 92Ah, you're fine. But if you have anything other than those 2 values, you cannot use BimmerLink to register your battery (at least that is the case as of the date of this writing). But in my opinion, I don't think you should deviate from the specs BMW is using and recommends. And again for your reference, they are - as of this writing - using the EastPenn 12V - 92Ah - 850CCA battery to replace BMW batteries in F30s with the following part numbers on it:
S: 61 21 7 575 327
AW: 61 21 6 924 022
NOTE 03:
If you go the BimmerLink route and get the same adapter I got (Veepeak OBDCheck BLE OBD2 Bluetooth Adapter) and have a penchant to forgo reading instructions, do not try to pair the adapter by going to SETTINGS / BLUETOOTH. Instead, Just plug the adapter into the car's OBD2 port and confirm the little light on it comes on. Then open BimmerLink on your phone and go to the SETTINGS option. The adapter will be auto detected in the ADAPTER TYPE category.
LINKS:
Bosch battery @ PepBoys
https://www.pepboys.com/bosch-premiu...%203.0L%20DOHC
Info on EastPenn intimidator AGM (chart shows the 9A49 specs) - This is the battery that BMW is using to replace battery in our car.
http://www.eastpennmanufacturing.com...Flyer-1737.pdf
BimmerLink App
http://www.bimmerlink.com/
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I really hope this post is helpful!
Cheers!
Old 04-07-2019, 09:02 PM
bimmerbingo bimmerbingo is offline
Mein Auto: 2016 X6 50i
Thanks for sharing your experience! I also replaced my OEM battery recently myself without paying anything! Why even pay the $26 for the app when you can register it using ISTA-D, the same tool used by BMW shops and not some 3rd party app? All it takes is opening up ISTA-D, read vehicle info, activities tab, service function->body,->voltage supply->battery->register battery change and follow prompts
2016 X6 50i M-Sport (mine), x-drive, CPO, alpine white
2015 435i M-Sport (mine), x-drive, CPO, sapphire black metallic, MPPK, MPBK, MPE
2015 X5 50i M-Sport (hers), x-drive, CPO, carbon black metallic
2015 328i M-Sport (hers), x-drive, new, alpine white
2007 328i (mine), rwd, used, silver
Old 04-07-2019, 09:19 PM
Mein Auto: BMW
Indeed, you're right! But I have a Windows X VM with ISTA-D that I ran on my Macbook Pro... but I recently sold the MBP in prep to get a brand new one. So I'm without the use of ISTA-D till I get my new laptop. Spending the few $$ for the app and adapter was not too bad an investment anyway since Bimmerlink has some other cool features in addition to battery registration PLUS it shows any and all faults and allows you to clear them as well! It's pretty handy to have that functionality on my iPhone since I can use it in a pinch!
BTW, what battery did you get?
Old 04-08-2019, 03:28 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Dealer installed my new 105 AH AGM and registered for ~$350 (cost of battery, labor and computer time). The AGM-VRLA battery is indeed different and fragile.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 04-08-2019, 08:28 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
Originally Posted by Mayorie View Post
+1
[IMG]https://**********/assets/84/f.png[/IMG]
+2
The job gets done quickly the first time for a reasonable price.
Old 04-08-2019, 03:03 PM
gkr778's Avatar
gkr778 gkr778 is online now
Novice driver
Mein Auto: 2014 320i ZSP ZMT
I went to the dealer for a routine checkup and my SA informed me that itís time to replace the battery. What? Really? Seemed strange to me since all of my electronics were working pretty stellar along with the fact that I routinely forget to turn my lights off when I walk into a store or restaurant and when I return, Iíve never had a problem! I wondered why I had seen no indication that the battery was on the outs.
In any event, my SA insisted that diagnostics revealed that the battery absolutely needed to be replaced and that it would be $540 to do it at the dealership. Seemed crazy excessive to me, but he went on to explain that it is a special kind of battery designed for modern cars with tons of electronics and the ECO start/stop feature, blah, blah, blah. He further explained that after the new battery is physically installed, it must be registered - which basically means you have to tell the carís computer that it is a new battery so that itís power management will readjust to the new, more robust source of power. He further explained that registration is done via computer. So, he says that THAT is what justifies the $540 price tag. Of course I wasnít biting. So I set off to buy a battery and do the installation myself. This posting details how I did it myself for less than $200. I am hoping it will help someone else with an F30 (which is what I have - 335i Sports to be exact). In the end, I replaced the battery and registered it myself and it was ultra simple! Öbut finding the right battery wasnít! Hereís my experience:
Although the install and registration was truly a breeze, finding the right battery and the tools (software and ODB2 adapter) to do the registration was an utter nightmare! A couple of days of scouring the internet and forums as well as making a bunch of phone calls resulted in my getting everything I need, so to start, my OEM battery was BMW branded and had 2 part numbers on it listed as follows:
S: 61 21 7 575 327
AW: 61 21 6 924 022
Not sure why it has 2 part numbers, but thought Iíd share that for reference. The battery has a rating of 12V - 90Ah - 900CCA and is an AGM (Absorbed Glass Mat) type.
Iíll spare you all the details of my arduous hunt for the right replacement, but will say that I discovered that there is only a small hand-full of auto battery manufacturers out there and BMW is not one of them. Like many other companies, BMW simply chooses a battery manufacturer, purchases the batteries from them and then slaps a BMW label on the battery and then neatly tuck it into the trunk of our cars. Turns out that my battery with the part numbers I listed above is manufactured by Exide. But BMW has since discontinued that battery and replaced it with a battery of slightly different specs. The battery they are now using to replace the above listed part number is made by EastPenn. The power ratings on it is 12V - 92Ah - 850CCA. The EastPenn part number is 9A49. EastPennís exact branding is EastPenn Intimidator 9A49. BMWís part number is 61 21 2 353 812. I searched high and low for the EastPenn battery and could not find it for less than $214. So I bookmarked it and shopped for alternatives with the exact same specs.
To register the battery, you will need an app fro your iPhone or Android AND a compatible ODB2 adapter. I decided to go with the BimmerLink app instead of the more popular Carly app because with Carly you have to pay $50+ a year if you want to keep the full version working. Personally, I am just not cool with the whole annual fee bit. I mean, I hear from many that the Carly app is truly awesome! Iíd gladly pay $100 or more for it - ONE TIME - because of all that it offers. But having to pay a $50+ fee every yearÖ I dunnoÖ Itís just me I suppose. And I am not cheap at all, but somehow I am rubbed the wrong way being forced to pay an annual fee for an app. Surely, some of you may be inclined to flame me for my position there. Flame on, but please be civil. Maybe thereís a stellar justification for the annual fee that I am unaware of or have not considered. Make the case Ömaybe Iíll be persuaded.
NOTE 01: If youíre using Carly, when you go to register the battery, since the original battery was 90Ah and the new one is 92Ah, you might be inclined to select the REGISTER OTHER BATTERY TYPE option. Donít do that. The Carly app does not have a 92Ah option. Just select REGISTER SAME BATTERY TYPE. If in your own research you find a battery that that you want to purchase and itís 80Ah or 105Ah, in that case select REGISTER OTHER BATTERY TYPE, then, when presented with the different amp options, select the appropriate one.
NOTE 02: With the BimmerLink app, you basically have no choice but to register same battery type. So if you get a battery thatís 90Ah or 92Ah, youíre fine. But if you have anything other than those 2 values, you cannot use BimmerLink to register your battery (at least that is the case as of the date of this writing). But in my opinion, I donít think you should deviate from the specs BMW is using and recommends. Ana again for your reference, they are - as of this writing - using the EastPenn 12V - 92Ah - 850CCA battery to replace BMW batteries in F30s with the following part numbers on it:
S: 61 21 7 575 327
AW: 61 21 6 924 022
NOTE 03:
If you go the BimmerLink route and get the same adapter I got (Veepeak OBDCheck BLE OBD2 Bluetooth Adapter) and have a penchant to forgo reading instructions, do not try to pair the adapter by going to SETTINGS / BLUETOOTH. Instead, Just plug the adapter into the carís OBD2 port and confirm the little light that come on on it. Then open BimmerLink on your phone and go to the SETTINGS option. The adapter will be auto detected in the ADAPTER TYPE category.
LINKS:
BimmerLink App
Cheers!
Excellent post, this should be a sticky!
Do you know if Pep Boys stores have the capability to register the battery in an F30 car?
What the world needs is a few more rednecks - Charlie Daniels
Tell you about rednecks. Theyíre probably the only people in the whole country that ainít unfit. - Fred Reed
God and guns keep us strong. That's what this country was founded on. - Lynyrd Skynyrd
Old 04-08-2019, 03:33 PM
Mein Auto: BMW
Check with your local PepBoys to see if they have the tools and provide the service to register the battery for BMWs. The one I went to did not provide the service, but I do believe that some PepBoys locations do provide the service.
Old 04-08-2019, 07:55 PM
Ah, I see, that's cool! I got the ACDelco 49AGM (900CCA/95ah) battery. I've only had it for three weeks, so time will tell how good it is. I was looking for a direct replacement (Exide) but had no luck finding one but on ebay so I settled for this one.
Old 04-08-2019, 09:22 PM
Mein Auto: BMW
Ya, finding a direct replacement is quirky business as I've found in my hunt. Battery manufacturers and even the re-branders make it quite complicated for those of us looking for specific specifications. And cross referencing the OEM to the re-brander is totally doable but it's a bloody time consuming, arduous, racoon hunt! That's really why I created this thread - so that the next guy or gal will not have to go through the trouble I did.
Old 04-08-2019, 10:28 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i/F30
You should be the Bimmerfest New York regional battery registerer. Possibly have office hours one weekend hour per quarter and have people get their battery registered for a fee.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
Old 04-08-2019, 11:53 PM
Mein Auto: BMW
Happily!
Old 04-09-2019, 09:12 AM
southcoastguy southcoastguy is offline
Mein Auto: 328xi
I bought a replacement battery for $175 before core refund. 900CCA, 95AH. used Carly to register. Funny, I have never heard of any annual charge
Further, I use Carly for many other reasons. I figure my total cost including Carly and a couple of metric sockets and extension to be $240.
Old 04-09-2019, 10:25 AM
Nuclear engineer
I believe that legacy Ivini Carly users continue the free subscription.
Old 04-09-2019, 11:08 AM
Mein Auto: BMW
That sounds about right. I recall in my research that folks who purchased Carly before a certain date are exempt from the new annual subscription model they have in place now.
IMO, it's a tool. A very good one, but nevertheless a tool. Personally, I cannot jive with the idea that one day I may reach into my toolbox and grab a tool I need but when I attempt to use I am faced with having to pay a fee before I can use it. That would completely annoy me. Like I said, I'd gladly pay $100 or even more possibly for the app ONE TIME. But an annual fee for a tool in my toolbox does not work for me.
Old 04-13-2019, 06:18 PM
LarryboysUDM's Avatar
LarryboysUDM LarryboysUDM is offline
Apay Kapoy
Mein Auto: 2013 335i 02RSXMT 06ML350
Great post, thank you!
This would come in handy someday since my battery would be 7 years old in a couple months.
I plan to recharge it again soon to see how long I could extend its life. If recharging brings it close full charge (almost like a new battery), why doesn't it require a registration?
My 1st BMW, bought Oct'12: Munich '13 F30 335i, RWD, Alpine White, Black Leather, M-Sport, DHP, Premium Pkg, Tech Pkg, 403M 19" wheels, Sport Auto w/paddle shifters, Heated front seats, HK, Alum Hex Trim/Estoril Blue accent, Xenon Adaptive Headlights, Sunroof, Alarm
Mods: Tint 35%, lower intake grill guard, Bimmer America Coding. Nankang 235/40/R19 AS, General G-Max AS05 255/35/R19
Pros: Power, drive, looks, space, mpg
Cons: Leaks, plastics
101K mi Feb'20
Hergestellt in Deutschland
Old 04-13-2019, 07:02 PM
Mein Auto: BMW
I don't think you can effectively recharge a battery whose cells are diminished and gradually diminishing. From my research, I've found that the AGM battery life in the F30 line is 5 to 6 years. If you've managed to have it going 7 years, I'd say count your blessings! If at this point she's dying, she has served you well. Get a new battery and bury old faithful with love and dignity.
Old 04-13-2019, 09:23 PM
namelessman namelessman is offline
Mein Auto: bimmer
My old E39 factory battery lasted almost 9 years and 90k miles!
My current F30 factory battery is 6.5 years and 65k miles, it still goes pretty strong for now.
Old 04-14-2019, 04:17 AM
Mein Auto: BMW
As I said in the original post on this thread, my battery gave me no indications whatsoever that it was on the outs. In fact, I also mentioned that I would routinely forget to turn off my headlights when I went into restaurants and stores - return an hour or 2 later and the car starts right up with no problem. Itís just the angel eyes that would be on though. But when I took the car in for a regular maintenance, I was told that it was time to change the battery.
So just because it does not appear to be on the outs does not mean that it's not on the outs. My e46's battery lasted for 10+ years, similar to your E39. But remember those cars in no way tax the battery like the F30.
If your SA does not tell you that you need to change the battery at your next scheduled maintenance, ask him/her to do a quick check to see what your battery's status is. You may be surprised to find out it's nearing it's time OR it may be prime time to change.
Old 04-14-2019, 05:58 AM
Mein Auto: 328xi
Modern batteries (those made in the last 20 years) will start you car and work fine - until they don't. I have had the experience of starting my car with no problems, driving to work and at the end of the day the battery was stone dead. You don't wait until your tires go flat to replace them, do you? Be proactive and avoid being stuck.
Old 04-14-2019, 11:05 AM
Mein Auto: bimmer
As I said in the original post on this thread, my battery gave me no indications whatsoever that it was on the outs. In fact, I also mentioned that I would routinely forget to turn off my headlights when I went into restaurants and stores - return an hour or 2 later and the car starts right up with no problem. It's just the angel eyes that would be on though. But when I took the car in for a regular maintenance, I was told that it was time to change the battery.
Smart chargers(e.g. CTEK) supposedly have battery tests done to indicate good/bad, right?
My CTEK MUS 4.3 detects sulfated battery, and test if battery can accept charge.
Old 04-14-2019, 03:12 PM
Even a 6v battery from a 1949 Dodge would start the car until it didn't. What has changed is is all the systems that continue to drain the battery with the engine off. A marginal battery can be drained down over a day.
But driving long enough to get the battery to an optimum charge or using a smart charger will help extend battery life.
Old 04-14-2019, 06:59 PM
Mein Auto: bimmer
My CTEK MUS 4.3 was just done charging the battery. 14.4V was used(but probably should use 14.7V). The charger went through the 7 steps without issue, so it appears my 6.5-year battery is still A-OK.
Old 04-15-2019, 02:17 PM
Mein Auto: 328xi
Till one day when it dies without warning.
Old 04-15-2019, 02:33 PM
Mein Auto: BMW
I had no clue about this notion of charging old batteries. So since you posted what you're using (CTEK MUS 4.3) I decided to look it up. Pretty interesting. Here is a link to the very informative video I found on it:
I have no regrets about changing my battery, but I'm going to do a bit more research on this based on your posting. Thanks for the info! Keep us updated on your battery situation since you charged it with your CTEK MUS. I'm curious to know how much longer your battery will last.
Old 04-15-2019, 02:55 PM
Nuclear engineer
The car knows more about the condition of the battery than the CTEK does.
The BULK charge phase ends when nominal charge voltage (you selected 14.4 VDC) is reached while charging at 4.3 Amps. Then the charging voltage is held constant while the charging current declines to some unstated value, when 'charging' is ended with the ANALYSE phase.
The car tracks State of Health - SoH - which is available for query by a capable communications program. SoH is a ratio expressed as percent of some unstated actual current battery parameters compared to those parameters at registration. The / a parameter may be minimum voltage during starter operation maximum current.
You can roughly track the declining battery capacity by noting the time required to recover your typical battery use discharge.
Battery capacity primarily diminishes due to loss of electrolyte water. As the water is lost the electrolyte level decreases making a smaller plate area available to the process. That reduces AH capacity. Also as water is lost the acid becomes more concentrated and that raises apparent battery voltage.
As the battery ages the charging will end sooner at lower capacity, which you will see as shorter and shorter completion times.
I usually charge with my CTEK 4.3 MUS weekly, the winter charges are longer, by about twice, than the summer charges. You can estimate the capacity charged as one-half of the hours charged times the maximum charging current 4 Amps. I charge about 10 AH in the winter and 5 AH in the summer. Milady Wife loves the bun warmers and as soon as the engine is running she has the bun warmers on. Also, in Wisconsin, the 1000 Watt 80 Amp PTC electric heater is on more often and longer.
What the ECU knows about the battery comes from the Intelligent Battery Sensor - IBS - which measures and reports Coulombs discharged, Coulombs charged, battery (system connected) voltage, and temperature. A Coulomb of charge per second is an ampere.
Similar Threads
BMW i3 Long Term Battery Capacity Report: Better Than Expected jacksparrow007 BMW i3 I01 (2014 - Current) 6 04-12-2019 07:25 AM
2002 325i battery replacement hifi440 General BMW Questions 5 02-11-2019 12:38 PM
Battery replacement due to cold weather - 95 AH vs 90 AH AGM landshark1169 X3 F25 (2011 - 2017) 2 02-05-2019 08:02 AM
Key Fob Battery Replacement sirius1 General BMW Questions 3 12-06-2018 01:17 PM
