Make your M550i sound like the M850i... - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 07-08-2019, 08:37 AM
C7Z51 C7Z51 is offline
Mein Auto: M550
thanks, looks good
Old 07-12-2019, 05:41 PM
bklyn550 bklyn550 is offline
Mein Auto: 2011 550i sport
Originally Posted by C7Z51 View Post
thanks, looks good
Thank u! It really sounds good.
Old 09-17-2019, 12:22 PM
empty8378 empty8378 is offline
Mein Auto:
So I just purchased the 2020 m550ix and was told the exhaust is louder then prior models. Has anyone done this on a 2020 model?
Old 09-17-2019, 03:17 PM
modthispny modthispny is offline
Mein Auto:
i took out all 4 resonators - the 2020 probably has 2 only, similar to the m850i, so you can remove those 2 and have a sound that is a bit louder.
2019 BMW M550i
Old 09-17-2019, 03:56 PM
Moewron Moewron is offline
Mein Auto: 2018 M550i
Which "two" would I tell them to take out? Like, how would I direct them to do this?
Old 09-17-2019, 04:21 PM
Mein Auto:
it's very self explanatory once the car is up on a lift. Any exhaust shop tech will know what to do once the car is up on a lift.
2019 BMW M550i
Old 09-28-2019, 05:18 PM
SyscoBMW SyscoBMW is offline
Mein Auto: M550i
Originally Posted by bklyn550 View Post
Attachment 855525 another few mins and I will see whatís up. Excited to hear the difference.
How did yours turn out? Did they weld it? What did it run you? I hear $200ish. I was quoted more than double that
Old 09-28-2019, 06:27 PM
I paid more than 200. The exhaust is one piece all the way back it takes someone a while to do the job. I think I paid like 425. Iíd do it again. Car sounds good.
Old 09-28-2019, 06:33 PM
Mein Auto: M550i
Oh I felt like they were trying to rip me off when I got quote. The other place I donít want to go back to because they hacked my M5ís Soul exhaust delete instal.
2019 M550i and some others
Old 09-30-2019, 04:01 PM
Itís took the guy who did mine around 4 hours. If it was bolt on stuff would be easier.
Old 10-20-2019, 01:25 PM
tmcribbs tmcribbs is offline
Mein Auto: 2018 G30 540i B58
I only removed the larger resonators on my '19 M550i (the ones closest to the muffler) and it sounds great. I left the smaller ones on. I didn't want it to be too loud and could always go back and have the second set removed if I really wanted. I was parked by a German mechanic who heard it start up from cold. He came over to compliment the sound and asked if I did the resonator delete. The sound is decently improved at idle and you can really hear the difference when you get on it.
$175 in So Cal. Took about 45 mins.
Current:
2019 M550i, Carbon Black, DA Plus, Prem, Exec, Leather Dash, 668M, HK
2018 X3 M40i, Graphite, DA, Prem, Exec, Adaptive Susp, 699M, HK
Past:
2018 540i
Old 10-20-2019, 03:05 PM
540 M-Sport's Avatar
Mein Auto: M550i, 540M-Sport, Scud
It would be great if someone with a 2020 M550i could post a picture of their car on a lift to compare the resonator set up and what was changed for 2020.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 10-23-2019, 05:42 PM
Mein Auto: M550i
I got rear resonator removed, added a nice bump in sound without going full delete.
Old 10-24-2019, 08:53 AM
GEEZERS11 GEEZERS11 is offline
Mein Auto: N/A
Would this work on a '17 540i?
Everything in moderation. Including moderation.
Old 10-24-2019, 10:31 AM
Yes, it will work on any car with resonators, but you need to look at the exhaust and see if or where the resonators are located, and can be removed.
Old 10-25-2019, 11:13 AM
How would one do that short of taking it to a shop? I'd like to be able to go into the shop and tell them exactly what I'd like done.
Old 10-29-2019, 09:18 PM
You obviously haven't read all the posts in this thread. So here are the steps:
1) Go to post #21 and print a copy of the photo of the resonators.
2) Find a reputable muffler shop
3) Take the photo to the shop and tell them you would like them to remove the resonators in the picture from your car, and replace with straight pipe.
Done!
Old 10-30-2019, 08:06 AM
Done!
So, you're right, I wasn't clear in my question. I'm curious about having just one resonator taken out.
Does it matter which one? If so, which one would you pull? And has anyone noticed any appreciable change in engine performance/smoothness/mgp with the change in backpressure?
Old 11-01-2019, 01:28 PM
I would be inclined to do what SyscoBMW did in post #38 and remove the larger of the two resonators. It makes sense the larger one will have more impact. It has not been confirmed, but that seems likely what BMW did on the 2020 M550i. (I sure would like to see if that is the case). I highly doubt the change will impact any of the parameters you question.
Old 11-01-2019, 02:29 PM
Mein Auto: M550i
I donít think there would be any performance enhancement. The resonators are literally straight pipes with little holes drilled in them with the outer area filled with sound killing stuff that kills the piping sound and removes basic volume of a closed straight pipe.
Old 11-04-2019, 06:38 AM
No, I don't think there would be an enhancement, either, regarding performance. I'm curious about the opposite, as resonators can create backpressure, which is necessary and (I'm guessing) finally tuned in a car like this to be at exactly the level the car needs.
Old 11-04-2019, 09:25 AM
That may not be the case, and it was purely for sound. Resonators really don't create backpressure, as stated by Moewron, they are typically straight through with perforated pipe that reduces resonances at specific frequencies. The rumors are the 2020 M550i has one of the two resonators on each side removed to increase the sound, due to complaints the car is too quiet. What has yet to be determined, is which resonator was removed, the smaller or larger one?
Here is another video on youtube with both resonators removed on a 2018
Old 11-04-2019, 09:44 AM
Mein Auto: M550i
Iíll send a pic later, but they are literally straight pipped right thru. Itís for sound in my opinion
Old 11-08-2019, 08:15 AM
Okay another question- has anyone had to do any subsequent work after getting the resonators deleted? Like, re-flash the car or anything?
Old 11-08-2019, 11:50 AM
Mein Auto: M550i
No- none at all is needed for something like this. Your replacing a straight pipe with tiny holes to absorb sound with another straight pipe without the sound holes. Even when you straight pipe entire exhaust and muffler delete you donít need to do anything. I deleted mufflers on my M5 with straight pipes as many people do, and nothing needed for that either.
HTML code is Off
Similar Threads
M550i to get same 530HP V8 as M850i NickDi G30 (2017 - Current) 17 05-24-2019 07:07 PM
Code out M550i engine sound dga G30 (2017 - Current) 4 10-06-2017 04:38 AM
BMW Service Codes 00000000 through 09999999 mksu19 General BMW Questions 7 02-22-2013 07:07 PM
I found 31 Service Bulletins on the 2009 Z4 sammie E89 Z4 (2009 - current) 1 09-26-2011 10:57 PM
Automatic Upshift Problem fiveten E89 Z4 (2009 - current) 1 09-26-2011 10:53 PM
