Electronically controlled electric BLDC coolant pump - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 06-05-2019, 02:37 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
"Electronically Controlled Coolant Pump
Particular care must be taken when performing servicing work to ensure that the pump does not run dry. When the pump is removed, it should be stored filled with coolant. The bearing points of the pump could seize if the pump were not filled with coolant.
This could jeopardize subsequent start-up of the pump thus rendering the entire heat management system inoperative (the pump not starting up could cause serious engine damage). If the pump should ever run dry, the pump wheel should be turned by hand before finally connecting the coolant hoses. The system should then be immediately filled with coolant.
Particular care must be taken during assembly to ensure that the connector is clean and dry and the connections are undamaged." Page 70 - 71
http://lindvigs.com/obioban/spec.pdf...ACmbfEgCbsVKeH
It should be obvious that the Graphitar plain journal bearings of the ECP will corrode in a used pump or a new pump as well. A new pump should be received wet and stored up-right only.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
