F3* lifetime coolant, 100k miles? - Bimmerfest - BMW Forums
Old 09-18-2019, 10:21 AM
namelessman namelessman is online now
Mein Auto: bimmer
This morning a colleague asked me about his F30 lifetime coolant(his mileage is around 50k miles), so has anyone on this forum changed their coolants?
My car had a thermostat recall and service captured the old coolant(not kidding as confirmed by foreman!) and reused, and only added 1L of fresh coolant per invoice printout. This is actually against TIS instruction, namely, no coolant should be reused! BMWNA just acted cheap on this recall.
Anyway by 60k miles/6 yrs my coolant was tested with pH strip and the pH was around 7, so additives were wearing out.
The local weather is quite mild so even pH 7 should last for another 40k or so, but there was a $300 coupon for brake fluid + coolant with $50 off from BMWNA($250 total) at dealer, so both were done a year ago. Brake job is around $150 here, so $100 extra for coolant change is $25 parts and $75 labor at dealer, not bad right?
From my reading, lifetime [email protected] and others is 100k miles change of factory fill, and any subsequent fluid change is 50k miles.
Now can BMW radiator/thermostat/expansion tank/water pump/hoses last beyond 100k miles? The N26 radiator is DOR, so that is covered for 15 years/150000 miles. The electric water pump can be a weak point, esp. it does run 5 minutes-ish after ignition off to cool the turbo.
So should the colleague be advised to change around 50k-60k miles? His coolant is tested to be around pH 7-8(slightly alkaline)
Old 09-19-2019, 07:18 PM
beware_phog's Avatar
beware_phog beware_phog is offline
Jayhawk Fan
Mein Auto: 435
I just had my coolant flushed yesterday on my 2014 435 with 40K miles. Mike Miller from BMWCCA is all about changing fluids every two years, and he's smarter than me so I do it. I know some here will disagree and follow official BMW for everything, but BMW changed some of the maintenance recommendations when BMW started having to pay for stuff. So yeah, i'm in the change the fluids camp.
Current:
2019 x3xDrive 30i | Executive | Premium| Convenience | Dynamic Handling | xLine | Upgraded Stereo | Mineral White | Canberra Beige | PCD
2014 435 M Sport Coupé | DHP | Cold Weather PKG | Driver Assistance PKG | Navigation | Side/Top Cameras | Upgraded Stereo | Style 441 Wheels | ED
Previous: 2003 540 Touring; 2001 740 Sport; 2004 330 Convertible; 2003 X3 (ED); 1998 323 Convertible
BMW CCA: 162191
Old 09-20-2019, 09:26 AM
Mein Auto: bimmer
My original plan was to follow BMW's lifetime/100k guideline, then the foreman said refreshing fluid does no harm, and alerted me of brake + coolant coupon, so why not?
Old 10-14-2019, 06:48 AM
LarryboysUDM's Avatar
LarryboysUDM LarryboysUDM is offline
Apay Kapoy
Mein Auto: 2013 335i 02RSXMT 06ML350
I'm at 97K miles with the original radiator, thermostat, expansion tank and water pump. At about 85K miles I had to replace the high pressure coolant hose due to a leak so I replaced the coolant with an aftermarket fluid.
My 1st BMW, bought in 2012: Munich '13 F30 335i, RWD, Alpine White, Black Leather, M-Sport, DHP, Premium Pkg, Tech Pkg, 403M 19" wheels, Sport Auto w/paddle shifters, Heated front seats, HK, Alum Hex Trim/Estoril Blue accent, Xenon Adaptive Headlights, Sunroof, Alarm
Mods: Tint 35%, lower intake grill guard, Bimmer America Coding. Nankang 235/40/R19 AS, Yokohama Advan Sport 255/35/R19
Pros: Power, Drive, looks, space, mpg
Cons: Engine (leaks & parts)
98K mi Nov19
Hergestellt in Deutschland
Old 10-14-2019, 07:00 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Coolant anti-corrosion is consumed Stoichiomatically - mole for mole. Liters of coolant probably have thousands of moles of anti-corrosion, and from where might the corrosion producing moles come? Lifetime works - and BMW now agrees. A cooling system component change will require draining / refreshing sooner anyway.
Be sure and select the proper anti-corrosion chemistry package. I believe that it is essential to long elastomer seals hoses gasket life.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 10-14-2019, 09:41 AM
Mein Auto: bimmer
Local BMW indies and foremen said no on lifetime coolant change until there is a repair of cooling component every 5 yeas or so, and that is the time to drain and refill(not necessarily flush).
Mine was changed in 6 years/60k miles for $100-ish at dealer, mainly that a dealer recall for thermostat only added 1L of fresh coolant, while the old coolant was captured and reused. BMWNA was too cheap to pay the remaining [email protected]#$!
The 50/50 mix also went from deap greenish blue to very like blue, is that a sign that moles get worn out? The pH was tested at 7, so it is losing alkalinity.
Old 10-18-2019, 07:48 AM
Matthew424 Matthew424 is offline
Mein Auto: 2015 328 X-Drive
Exactly what I was thinking and what I follow. Preventative maintenance is key, especially for fluid changes that are relatively inexpensive (minus transmission fluid change).
2015 BMW 328 X-drive : Dinan Stage 1: Dinan Exhaust: Dinan Springs: Dinan Supplemental Ride: Dinan Intercooler: Dinan Pedals: BMW Performance Headlight Bulbs : Bimmertech Front/Rear Cameras: Bimmertech MirrorCast : BMWCCA Member #516886 (Feel free to use my BMWCCA # for a referral).
Old 10-18-2019, 11:01 AM
Mein Auto: bimmer
My thinking is that fresh fluid can help with longevity with expensive components like electric water pump, yes/no?
Old 10-18-2019, 11:24 AM
Nuclear engineer
How soon does it stop being fresh, and why?
Old 10-18-2019, 11:34 AM
totally agree. i also autocros the car and figure with additional strain on the components, fresh fluids is never a bad idea.
Old 10-18-2019, 12:24 PM
Mein Auto: bimmer
My layman data is that fresh 50/50 BMW coolant + distilled water is around pH 8-8.5. When pH reaches 7 the coolant can turn acidic(and start corroding parts), and is no longer "fresh".
Mine approached pH 7 around 6 years and 60k miles. That is with dealer performing a thermostat and adding 1L of new coolant around 40k miles, and reusing the rest of old coolant!
So if your [email protected] years/100k miles and beyond still has a pH above 7 then it will still be A-OK.
Old 10-18-2019, 12:54 PM
Mein Auto: bimmer
What is your game plan with ZF 8AT? 100k miles or lifetime till transmission dies? Apparently there are E90/E90 with ZF [email protected] and original factory fluid and still kicking fine.
Old 10-18-2019, 01:10 PM
montr montr is offline
Mein Auto: 335d 2010, 430i GC 2018
On my E90 335d, I saw an improvement in the transmission shift after changing the ATF oil and pan at around 100K miles. There was some deposits on the two magnets in the transmission pan. I am now at 119 K miles
Old 10-18-2019, 01:54 PM
Mein Auto: bimmer
Does E90 require changing oil pan too? In F30 the magnets/filters are embedded in the oil pan, so the whole service kit is $150-$280 dependent if ZF fluid or not.
Old 10-18-2019, 07:46 PM
Same as the F30, the magnets and filter are part of the plastic pan. I used the ZF fluid.
Old 10-18-2019, 11:58 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
I honestly wish there was more science applied to these topics by parties of non-interest.
Our cars have enough fluids in them with various properties that will produce degrading effects as function of many variables such as time, temperature, miles driven, track days, etc.
Fundamentally though, there has to be some measurable property that ultimately is the product of all of the factors above which should be the determining factor in when these get replaced - and if it were measured continuously as a proxy for remaining useful life, well that would just be a benefit to obvious to the consumer.
The dealer basically says the engine oil lasts 15k while enthusiasts will argue half that. Is the dealer right from their perspective because more drivers keep it in ECO Pro or are the enthusiasts right because they only live in Sport+. Ultimately, there is probably a measure of viscosity or metallic content in the fluid that should determine when the oil should in fact be replaced - but we default to poor heuristics such as mileage because our cars lack intelligent sensors that can actually measure the relevant properties of the fluid that are detrimental to engine component life.
At the same time, brake fluid, being hydroscopic, needs to be replaced when its water content gets too high to the point where there can be localized boiling in the fluid itself. But there are a few factors here that should be considered - the average humidity content of the climate in which the vehicle is operated in as well as the braking habits of the driver and the ambient temperature. If the fluid never gets above the boiling point of water, it remains in an incompressible state and will not affect brake feel - hence those who brake as hard as often in cooler, dryer climates should have to replace their brake fluid on a longer interval compared to driver in Miami, for example. However, nothing on the car utilizes the differences in the electrical conductivity between water and DOT x brake fluid to even attempt this measurement and the result is a time-based maintenance concept that is inefficient for all.
Long answer to the OP's coolant question - if it make you sleep better to replace it at 100k, do it.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 10-19-2019, 09:18 AM
Mein Auto: bimmer
There are test strips and meters that can test health of brake fluid and coolant, but it is true such monitoring and testing can be implemented onboard by manufacturer.
The engine oil already has some type of monitoring/testing from the oil level sensor, supposedly on the dielectric property of the oil. In addition OCI is determined to total number of gallons consumed, and that accounts for EcoPro/Sport, uphill/downhill, stop-and-go, highway, and many other attributes.
Old 10-19-2019, 09:37 AM
Mein Auto: bimmer
Do note starting MY2014, F30 OCI was changed to 1 year/10k miles(from 2 years/15k miles), so BMWAG indicates that the oil property cannot last 15k miles in F30 engines.
Old 10-19-2019, 11:12 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
There is plenty of science to apply, it's the general automotive enthusiast community that prefers to stick with tradition and gut feel.
Lots of people (including me) have had their used engine oil analyzed and posted results showing that 10k intervals are fine. Those posts typically have many people saying, "that's great but I'm changing at 3-5k anyway because that's how it's been done for the past 50 years".
I had my indy check my 5 year old coolant last year, fully prepared to change it. They tested and said it was fine and still looked great when they could've charged me for the job.
As a funny aside, I noticed Mike Miller in one issue of Roundel said his E46 burns a quart of oil every couple thousand miles (or thereabouts) despite following his Old School maintenance schedule. Which I think changes the oil every 3-5k miles. When I sold my 2002 E46 in 2014 with 120k miles on the clock, I had been changing the oil once a year at 10k miles. It used less than 1qt every 10k. I had tested the oil on that E46 a few times to verify that 10k intervals were ok and went with the science.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 10-19-2019, 01:27 PM
Mein Auto: bimmer
Yes BMW agrees with 1 year/10k interval too, and with my driving habit, that should be around 8.5k miles.
Still mine is still programmed as 2 year/15k, with OCI around 13k, my interval is midway around 6.5k miles.
Old 10-19-2019, 08:27 PM
tenmm tenmm is offline
Mein Auto:
On the coolant my 2015 F30 N20 has 40K mi, the service records indicate that it's never been changed, and a few days ago a test strip registered a PH of 9.0 @ 60% coolant. (In case it's useful as a reference for anyone.)
FWIW - My cousin has owned a German Indy garage for over 40 years, and he's advising me to replace the coolant and the transmission fluid between 50 and 60K.
I talked to BMW NA yesterday and was told that the recommended OCI is 7500 miles or 1 year on my car (the annual recommendation has to be solely dealer revenue, at least I can't find any actual data to back it up - and quite a bit to refute it). Regardless, I was surprised to be told 7500 since I've read 10K in several places. (The OC's on my car thus far by the dealer have all been @10K, and the service system is still set to alarm at 10K.) Maybe I just got a new rep on the phone? I'd panned to change it at 7500 anyhow.
BTW - I was quoted $163.00 by the local dealer for an oil change. I think I've seen others paying closer to 90$ recently, so am I mistaken or is the price I was quoted high?
Old 10-19-2019, 10:46 PM
Mein Auto: bimmer
What is your general location?
Old 10-19-2019, 10:58 PM
charlesberry's Avatar
charlesberry charlesberry is online now
Mein Auto: 944 Turbo M235 Z4 335Mcar
I have an F30, 110,000 miles. Just did the thermostat, electric water pump and fluid change in my garage. Mine is an Xdrive with the bigger subframe, makes it harder to get to parts. Very doable for average DIY. At 100k miles, change the fluids. All the fluids. Oil changes, 7,500 miles. The additive package starts to wear out at 7,500 so I can only imagine what the oil is like at 15k.
Old 10-19-2019, 11:28 PM
Mein Auto: bimmer
Was the coolant [email protected], and if so, was the pH still above 7? Was there sign the water pump and/or thermostat going bad? Is yours a N20/N26 or N55?
Old 10-20-2019, 09:06 AM
Motor is an N55, original coolant. Just doing preventive maintenance. Ph test ? LOL!! The old coolant looked kind of crappy in the drain bucket.
