BMW X5 Leaking Liquid - Bimmerfest - BMW Forums
Old 09-27-2019, 07:23 PM
willy5079 willy5079 is offline
Mein Auto: 2013 X5 Xdrive 35i
My BMW X5 2013 now has a problem, again. It drives o.k, but leaking liquid, may not be engine oil but power train liquid. The leaking is slow but continuous.
I first checked it at Autobahn, Tracy. In less than 15 minutes, the technician give me a list of the following leaks:
Oil Pan Gasket Leaking;
Front Diff Seals Leaking;
Cam Sensor Leaking;
Cam Solenoids Leaking;
Turbo Oil Supply and Return Line Leaking;
Oil Filter Hosing Gasket Leaking;
Oil Cooler Gasket Leaking;
Valve Cover May Have Crack Due to Leak;
PCV Breaking Hose Leaking Oil;
Power Steering Rack Leaking;
Driver Side Charge Pipe Leaking at Interlooper
He said for a low mileage car (60k), these are unusual. He estimates it costs over $5000 and needs over a week to fix.
I then visit SpeeDee Oil Change at Tracy. Their diagnostics is “Possible Valve Cover Gasket Leak”. But my Valve Cover Gasket was replaced about two years ago at a BMW dealer.
SpeeDee does not do European cars.
Then I have the car checked at Meineke Car Care Center of Tracy. It took 30-40 minutes for the technician to check and they found “ Rack + Pinion Hose Leaking”, “Lower Rack + Pinion Line Leaking.” The technician decided it is not a gasket leak problem and the leak of power train liquid is slow. But they are yet to give me an estimate.
I would appreciate any comments on the above.
Old 09-27-2019, 07:34 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
That is a lot to diagnose in just 15 minutes. The other two places are no place to have a BMW looked at. I would be suspicious of the Autobahn diagnosis. If a shop were to give me a diagnosis with that many specific areas I would be personally inspecting each one after wiping down and cleaning each of the areas. That’s a lot of work to blindly accept.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 09-27-2019, 07:44 PM
320kplus's Avatar
320kplus 320kplus is offline
Mein Auto: 98 e39 540i
+1 ^^
Sent from my SM-N960U using Tapatalk
Old 09-27-2019, 07:49 PM
paramedic1079 paramedic1079 is offline
Mein Auto:
Check your engine mounts. I had a slow leak that eventually got worse and more noticeable.
Old 09-27-2019, 08:19 PM
320kplus's Avatar
Engine mounts if undetected can def reek havoc! Good point.
Old 09-27-2019, 08:25 PM
That long list is a lot to pin on engine mounts.
Old 09-27-2019, 08:35 PM
320kplus's Avatar
Agreed. Never said I was pinning all of it on the mounts. OP needs to put her up in the air, get a light and another set of eyes on it. And some rags...
Old 09-27-2019, 08:47 PM
Yeah. I know you weren’t putting it all on the mounts. The list from Autobahn is a dream for whoever makes money. No shop is that good in 15 minutes. A lot of it is DIY stuff to check and replace if OP is up for it.
Old 09-27-2019, 08:49 PM
320kplus's Avatar
Roger that.
Old 09-27-2019, 09:10 PM
Thanks for your comments.
The Meineke place is done by a technician about 50 years old. He is kind of serious.
He mounted the car and took off the pan, used a light to examine and let me take a
look at it (unfortunately, I am a layman!). I saw the leaked liquid at where he points
and that position (driver-side near the wheel) is what the leak comes from. (I put a paper
sheet to receive the leak).
Old 09-27-2019, 09:16 PM
The other place is call "European Car Care". They charge $110 for diagnostics and there
is a long line for an appointment. I do not want to fix everywhere that's not leaking, as
the Autobahn guy claimed. I just want to fix where it leaks for a BMW X5, with only 60k.
Is that reasonable or I am wrong, as a layman.
Old 09-28-2019, 12:28 AM
ard ard is offline
Resident Curmudgeon
Ugggh, what a mess.
You are trying to protect yourself, but since you dont have any knowledge, it is very very hard. You are trying to use hints, how old the guy is or how long it takes them, in order to evaluate their honesty and competence.
Try to find a recommenced shop in the Tracy area. I heard some poor things about AUtobahn in the past, BTW. Is East Bay the nearest dealer still? Im guessing them or valley in modesto?
You might start a new thread- or do a search here- "anyone recommend a shop in Tracy?"
(you can ignore people telling you to jack it up and look....)
I'll look tomorrow, see if I can find anyone to recommend.
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 09-28-2019, 07:30 AM
Gary214 Gary214 is offline
Mein Auto: 2011 X5 50i M-Sport
Cam Sensor Leaking;
Get the car detailed and professionally cleaned from below, maybe a steam clean.
Then go to Carmax and wash your hands of it
Old 09-28-2019, 07:33 AM
Mein Auto:
I'm not sure what your leak looks like but here are two pics of what I was looking at when my passenger side engine mount failed.
***Sorry the pics got flipped around after posting.
ID:	865975   Click image for larger version
Old 09-28-2019, 12:44 PM
Which Car Repair should I trust?
Thanks Ard. You are nice to comment on my
problems. Unfortunately, I had bad experiance
with both the Concord BMW and the East Bay BMW.
The Concord BMW took my car for the last warrantee
repair two years ago and replaced my Valve Cover
Gasket. But they made a pipe leaking problem which
took three visits to fix.
The East Bay BMW messed up my GPS by replacing
a recall airbag. It took them another three visits to
fix it.
Should I took the car to the European Car Care for
a $110 diagnostics (They look knowledgable.), Or
I could stay with the Meineke guy, waiting for their
quote ("Rack + Pinion Hose Leaking" and "Lower
Rack + Pinion Line Leaking"), if reasonable, give
the job to them?
Old 09-28-2019, 01:55 PM
BlueDevil Power Steering Stop Leak
After some research, I found a possible alternative to fix the problem.
There is a product at the local Auto Parts Store called "BlueDevil Power Steering
Stop Leak", supposedly to be poured into the Power Steering Reservoir, as
shown in the attached picture. It is supposed to stop small leaks.
I checked the reservoir, the liquid level is kind of low. (But the measuring
stick still has some liquid at the tip.) This may match with the Meineke
Technician's diagnostics of "Rack + Pinion Hose Leaking."
Could anybody give me some idea on this alternative? If it does not
work, then a parts replacement has to be done.
Old 09-28-2019, 01:58 PM
Power Steering Liquid
On the picture of reservoir, it says:" CHF 11 S Only". It is a powering steering
liquid used by BMW.
Old 09-28-2019, 03:12 PM
Don’t use stop leak products. They might end up ruining your pump and clogging areas that shouldn’t clog. Not worth the risk. Fix it right. The power steering reservoir is know to leak a bit from the top. Maybe that’s why it is low. Fill it with proper Pentosin CHF 11S.
Old 09-28-2019, 11:54 PM
deroy deroy is offline
Mein Auto: X5 e70 4.8
Steering gear is expensive and lots of labour. The power steering system operates at very high pressure. Some sweating (not dripping) at a connection or seal is no big deal imho, and does not validate a big job, nor snake oil additives.
I would clean suspect areas, top up the fluid and monitor for a while. You can reverse the o ring in the cap to try to seal the reservoir cap off better.
Verzonden vanaf mijn iPhone met Tapatalk
Old 10-01-2019, 08:32 PM
hunt65 hunt65 is offline
Send a message via ICQ to hunt65
Mein Auto: 08 X5
What I would do before I invested any dollars is to have the engine compartment(engine & trans) thoroughly cleaned, upper and lower, and then after a week of driving, have it checked. You will then be able to determine more precisely where your leak or leaks are coming from.
Old 10-01-2019, 08:38 PM
Don’t have it professionally cleaned. Do it yourself. Understand the areas where the leaks may be occurring. Clean them and then inspect.
Old 10-01-2019, 08:39 PM
Mein Auto: 08 X5
I've not had any of those issues other than an oil pan gasket replaced on the 2013 X5M. I have my oil changed at 5k mile intervals at BMW on all.
2008 X5
2011 535
2013 X5M
Old 10-01-2019, 08:42 PM
Mein Auto: 08 X5
That's good advice, hopefully he has what it takes to clean upper and lower areas so he ca determine exactly where his leaks are!1
Old 10-02-2019, 08:54 PM
satyaban satyaban is offline
Mein Auto: 2008 328xi
If you go to a BMW dealer and ask them to tell you everything wrong with a car that is 6 years old, how many pages do you think it would take to list everything they found?
The question is do you want to find and fix a leak or fix every seal that is not performing at its max. Check your reservoirs and fill what is low.
What is the nature of this "power train" fluid, is it thin like oil, thick like gear oil, and what does it smell like?
I'm just saying keep it as simple as you can, it is easy to over complicate stuff here sometimes.
Old 10-02-2019, 09:30 PM
It is power steering liquid
Thanks for your advise. It is power steering liquid and the reservoir is low.
I filled it and continue to monitor it, as many advised.
