x5 window switch not working - Bimmerfest - BMW Forums
Old 10-15-2019, 05:45 AM
Kencam Kencam is offline
Mein Auto:
hi all new user,
Had a look on here first, but cant see the problems I am having
I have a problem with my 2009 x5 window switch, I started the car last week and got a message on the screen, lights/indicators or windows not working. when driving my interior lights were flashing along with spedo lights and hazard warning light switch. tried hazard they did not work and window switch on drivers side did not work, time I got to work all is ok apart from drivers door switch, it does not work mirrors or windows, all other door switches work.
I have checked the fuse in passenger fuse box, got a new switch for drivers side still nothing. is there an other fuse that I can check
Please help as it is driving me mad
Old 10-15-2019, 05:47 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Lights and windows and a plethora of stuff go through the notorious Footwell Module - FRM - subject to an ELW extended warranty.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 10-15-2019, 05:50 AM
Mein Auto:
thanks Doug, is that something I can change myself?
Old 10-15-2019, 06:01 AM
ArgentoCarNut ArgentoCarNut is offline
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
It is covered under a recall if I recall correctly
Old 10-15-2019, 06:29 AM
Mein Auto:
Thanks, have not received anything yet, I will call bmw
Old 10-15-2019, 09:43 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
'tis the season for dying batteries. Not sure where you live (there is a reason for that my location thing) but a failing battery will cause some crazy issues.
I'd make sure the battery is serviceable before going after the FRM at the dealer. Not that FRM is not suspect, but you don't want to pay a $150 - $200 diag fee if you just need a new battery.
Old 10-16-2019, 01:31 AM
Mein Auto:
thanks FredoinSE, I had new battery fitted last winter as it was I bit low on charging
Old 10-16-2019, 06:37 AM
Gary214 Gary214 is offline
Mein Auto: 2011 X5 50i M-Sport
Battery is the "USUAL SUSPECT "
Old 10-16-2019, 09:29 AM
What was that?
Was the new battery programmed into the car? Do you remember if AGM or what type?
Old 10-17-2019, 01:47 AM
Mein Auto:
no AGM battery in car, as far as I know new battery was all set up about this time last year
Old 10-17-2019, 02:38 AM
Mein Auto:
just an update, last night I checked the following, mirrors cant adjust from switch, heated mirrors not working and the original fault can't control the windows all from drivers switch. what controls all these things
Old 10-17-2019, 04:16 AM
Nuclear engineer
newTIS.infobeta
Home / BMW E70 X5 xDrive35i SAV / Repair Manuals and Technical Data / 61 General vehicle electrical system / 61 04 04 (094)
Footwell module [ ... ] The following components are controlled:
Exterior mirrors
Power window drive
Headlight
Tail lights
Fog lights
Centre high-mount stop lamp
Auxiliary turn indicator light
Front courtesy lighting
Rear courtesy lighting
Number-plate light
2 stepper motor controllers for the adaptive headlight stepper motors
2 belt feeder controllers (only E92)
https://www.newtis.info/tisv2/a/en/e...system/1qXzYLi
Old 10-17-2019, 04:26 AM
Mein Auto:
Thanks Doug good to know
Old 10-17-2019, 04:33 AM
Mein Auto:
just to check, this is some bit of kit this dam footwell module. can the problems I have be broken but all other function normal via footwell
Old 10-17-2019, 05:51 AM
Nuclear engineer
Sure. As you can see, the FRM is complicated and we don't get to see the internal circuitry. Its function that usually concerns us owners is as a collection of electronic circuit-breakers that are self-resetting for a limited specified number of times.
I can't know if the high-short circuit current protection function is causing your issues. You asked if there is a common point for many problems. Yes, the FRM.
I believe that only a capable and willing dealership can properly diagnose.
Old 10-17-2019, 05:58 AM
Mein Auto:
Great knowledge and thanks for taken time to answer, looks like I will pull it and send for repair, got a scan book next week so lets hope they can point me in the right direction
Old 10-17-2019, 06:03 AM
Mein Auto:
Got a company to repair if confirmed FRM is at fault
Old 10-17-2019, 06:29 AM
Nuclear engineer
Best wishes
Old 10-21-2019, 04:05 AM
Mein Auto:
ID:	868927hi, managed to get a scan done, attached is what it found regarding FRM, contacted the company that fixes theses issues and they are saying it does not look like there is a problem
