E39 528i same engine problem - Bimmerfest - BMW Forums
Old 10-16-2019, 12:34 PM
R3jus R3jus is offline
Mein Auto:
So i changed both o2 sensors ( cost me 150euro ) changed all 6 spark plugs, did a lot of diagnostics AND STILL the same problem cylinder 6 misfire and p0173 and p0170, maybe i need to reset the ECU? Because i changed the o2 sensors today i didnt reset the computer check engine light still on, there are no vacuum leaks checked 3 times with smoke machine, checked all the ignition coils all seem to be working fine the problem happens only after a bit of driving ( the engine starts shaking when i push the gas ) checked the compresion in the cylinders also everything is okay, even checked the injectors they are all good, what could be the problem ? 528i 2000m, codes are cylinder 6 misfire, p0173 and p0170
Old 10-16-2019, 03:52 PM
mohamedrani mohamedrani is offline
Mein Auto: 520i 1998
maybe that helps :
Current Garage
98 E39 520i - 260k KM
bn63605
Old 10-16-2019, 11:40 PM
Mein Auto:
E39 528i engine problem
I'll see if thats the problem but if i had the cracked hoses wouldnt the engine always run bad? If the engine starts running bad and rough if i shut the engine off and turn it on again everything is fine again for like 10min
Old 10-17-2019, 02:23 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
ok...
p0173 and p0170 (*lean bank one and two)
have absolutely nothing to do with the spark plugs.. or the o2 sensors
there is one of 2 things happening..
1 you have vacuum leak, you have un metered air entering the system after the maf (you can confirm this thru live data)
2 you have a bad maf
NOTHING you said indicates anything should have been done with the o2 or the spark plugs.. so hopefully you have not complicated the problem by adding more things
(*sorry 3 things)
3 lack of fuel
Specializing In Breaking Things Professionally
15486372<-----
Old 10-17-2019, 02:26 AM
Mein Auto:
Originally Posted by Burning2nd View Post
ok...
(*sorry 3 things)
3 lack of fuel
What do you mean lack of fuel? Bad injectors or pump? So i checked for any vacuum leaks after the maf and there were none, so maybe its a bad MAF? But wouldnt the computer show that?
Old 10-17-2019, 02:59 AM
Burning2nd's Avatar
Under the lift arms
no the computer wound not just say "your maf is bad"
it doesn't not know that there is a calculation error If there is a calculation error
did you smoke check it?
lack of fuel could be a bad regulator
you need to confirm things,
fuel pressure.
o2 single
Maf single
live data
15486372<-----
Old 10-17-2019, 06:21 AM
Mein Auto:
fuel pressure.
o2 single
Maf single
live data
Yes i did a smoke test, but i didnt see any vacuum leaks plus if it was a vacuum leak the rpm would drop everytime now the misfire happens on after a while
Old 10-17-2019, 08:15 AM
Burning2nd's Avatar
Under the lift arms
no... I had a vacuum leak for years and never had a idle problem... there are to many variables to be able to just blanket statement "this would happen"
test with a known good maf
15486372<-----
Old 10-17-2019, 08:27 AM
Mein Auto:
I just got the p0170 and p0173 codes again but without a misfire so maybe it is a vacuum leak but the smoke machine didnt show any so where should i look?
