535XI miss fire - Bimmerfest - BMW Forums
Old 10-16-2019, 07:30 PM
fhgrantjr fhgrantjr is offline
Mein Auto: 08 535xi
535XI miss fire
Hello, This is my first thread. I have an 08 535XI with 90000 Mi. When I aggressively push the gas pedal The car skips ,all the rest of the time it runs fine. I hooked up a scan tool, and it told me there was a miss fire at cylinder # 6. It did not throw a code. I was wondering if anyone out there had any similar experiences. Thank You.
Old 10-16-2019, 07:50 PM
MysticRob MysticRob is online now
Mein Auto: E61 535xi Deep Sea Blue
Sounds perfectly reasonable. Check the usual suspects like plugs, coils, injectors, wiring harness on that cylinder, etc. Mine had the same issue at 100k miles when I bought it, and new plugs solved it. Looked like they were the originals in mine.
2008 535xi E61 Touring Wagon / 105k Miles / Deep Sea Blue Exterior/ Natural Brown Leather Interior / MHD Stage 1 Tune / xHP Stage 1 Transmission Tune
Old 10-17-2019, 09:41 AM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
Plugs first. These were mine at my first replacement (pic). Gap nearly double original, so the spark would 'blow out' at high speed.
Take a look at your coils, there's a date code. If they're original I'd consider replacing them but if your plugs are very worn the coils are probably fine. I replaced coils dated 11/07 just last year on spec - they hadn't actually failed.
If you keep the old coils in place, swap #6 coil with #3, leaving the rest in their respective cylinders. This way if you have another misfire event it helps eliminate the cause. If misfire happens on #3, you can blame the coil. If it happens again on #6 it could be the injector.
Name:	plugs old v new tight crop.jpg
Old 10-17-2019, 03:58 PM
bmrboy2008's Avatar
bmrboy2008 bmrboy2008 is offline
Mein Auto: 2014 535i M Sport
Sounds like plugs and/or coils for sure.
2014 535i M-Sport, Jet Black, Black Dakota Leather, Premium Package, Lighting Package, Multi-Contour Seats, M-Sport Suspension, Navigation, Harmon Kardon Stereo, 3M Tint
2008 528i Sport - Retired
2008 535i Sport - BMW Buy Back
2004 525i Sport - RIP
Old 10-19-2019, 06:58 PM
Mein Auto: 08 535xi
Thanks for the info. I will check the plugs first. At least i have a place to start. I will let you know how I make out, and again thank you very much.
Old 10-19-2019, 08:36 PM
twh twh is online now
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Most likely it is a failing coil. Just buy a new coil and replace that one. If you really want to try and debug it, you can swap 6 with another cylinder and see if the error follows.
Old 11-13-2019, 06:46 PM
Mein Auto: 08 535xi
Hello, I finally got around to replacing the coils and plugs. I bought a complete set of coils and plugs from FCP Euro. The folks over there recommended not to mix different coil manufacturers. I do not know if this is true but I took their word for it as I have done business with them before and was completely satisfied. The car now runs great. It was not a hard job but it would have taken less time if I had a 14mm 12 point thin wall spark plug socket that I had to chase down. Just some info that I am passing on to someone else that may want to change plugs in a BMW.
