Not Using Brake Pad Wear Sensors? - Bimmerfest - BMW Forums
Old 10-19-2019, 06:34 AM
isstatu1 isstatu1 is online now
Mein Auto: 2010 750Li
Out of curiosity, what happens when the brake pad wear sensors are not installed? Does it throw a code?
Old 10-19-2019, 06:41 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Not a DTC, but a worn brake warning / alarm. The system requires conductivity through the brake wear detector loops.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 10-19-2019, 12:10 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Mein Auto: 2006 X5 4.4/2013 650ix GC
Not. sure what you mean by "throw a code"...but there will be a fault code stored by DSC...and the check control system will be flashing some type of brake warning at you.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 10-19-2019, 05:55 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
You will get a warning on the dash, but it will not hurt anything. At 12.00 each, I would replace the sensors if they are damaged. You will then need to clear the warning in the secret menu, or ISTA. The brake system only uses 2 sensors.
