Alternator voltage really high - Bimmerfest - BMW Forums
Old 10-20-2019, 09:04 PM
Johnyboy30327 Johnyboy30327 is offline
Mein Auto:
Hello everyone. I have a 2011 750li xdrive and lately I have received a Ton of electrical messages. The biggest being my turbine speed sensor signal low and the transmission malfunction going into limp mode.
I think the cause may be my alternator. The voltage is really high. I have. Attached an image. It seems to be pushing out 15V to 15.5V and my battery is jumping up to 15V. Iím guessing this is not normal.
Can someone please help. Iím getting errors in modules from the all around camera system, pdc, transmission, instrument cluster, etc. Very vast selections of systems. Iíve been monitoring the voltages through my BimmerLink dashboard. Click image for larger version
Old 10-20-2019, 09:59 PM
Markst Markst is offline
Mein Auto: BMW 5
15v is fine if you don't have an AGM battery. Generator setpoint voltage is the voltage the ECU is asking from the alternator.
Measure with an actual multimeter on the battery terminals and on the alternator.
Old 10-21-2019, 08:32 AM
Mein Auto:
Ok, Iíll do that today after work and report my findings. Thank you for the clarity in the values.
Also, is the ďgenerator voltageĒ the actual alternator voltage it is delivering?
Johnathan
2011 F02 750li XDrive
Old 10-21-2019, 10:00 AM
Mein Auto: BMW 5
It should be, but I don't know how reliable bimmerlink is.
Old 10-21-2019, 06:42 PM
Mein Auto:
So the battery at every positive point is at 15.08v with the car running and 12V with the engine offClick image for larger version
ID:	869027. Iím pretty sure thatís too high as in the past it was never above 14.2v
Bimmer link seemed to be pretty close.
Johnathan
Old 10-21-2019, 08:23 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
whughes
Mein Auto: 2009 750li, 2018 X5
cHANGE THE BATTERY!!!!,, all kinds of goofy stuff goes on when the battery needs replacing
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights,
Dinan Stage 1 SW, Air intake, Free Flow Exhaust, Camber Arm
Old 10-22-2019, 04:43 AM
Mein Auto: BMW 5
12v with the engine off means the battery is almost dead. The high alternator voltage is the car trying to charge it. How old is your battery?
Can you see more info like battery type/ah/soc on bimmerlink?
Old 10-22-2019, 03:12 PM
Mein Auto:
Itís a 12v battery from advance auto parts. It has been in the car since I owned it. The local Indy shop said to replace the alternator because the battery at rest isnít dropping below 12V but when the car is on it is jumping up to 15V because the alternator is pushing out 15.2V to 15.5V while operating.
Johnathan
Old 10-22-2019, 05:19 PM
Mein Auto: BMW 5
As you can see from your own screenshot the alternator is supplying the voltage the car is asking for, there is a good chance it doesn't need to be replaced. If it isn't working as intended, you can probably fix it just by replacing the voltage regulator on the back.
If you disconnect the battery completely and still measure 12v or less at the terminals, it need to be replaced, it should never get that low.
Old 10-22-2019, 06:00 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
You most likely have a bad voltage regulator, which is a part attached to the alternator. The VR is around a 50 to 70.00 part. The alternator will need to be pulled to replace the VR, then is is a 5 minute job the insert it into the alternator. Usually with a bad VR, you will see warning s from the Dynamic Drive on the IDrive screen.
Old 10-22-2019, 06:29 PM
Mein Auto:
Yes, I received the dynamic drive warning and the battery tested good 15 minutes ago. I was thinking to replace the entire alternator just because I donít know how old it is and donít want to pull it more than once. But I could try the VR. Where can I buy one I saw some on eBay for $115? I have a 2011 750li Xdrive man. Date 5/2010.
Johnathan
Old 10-22-2019, 07:04 PM
Mein Auto:
So...I re-registered my battery using BimmerLink wondering if that could help. Instant change. I will see if this sticks. Click image for larger version
Johnathan
