Bmw x3 FAQ And DIY compilation - Page 6 - Bimmerfest - BMW Forums
Old 01-03-2017, 11:14 AM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
Originally Posted by rbelton View Post
Transfer Case Gear
FYI on this Transfer Case Actuator Gear DYI, you do NOT need to remove the electric drive motor. The white & black plastic gears will just rotate a little when pulled off of the steel worm drive gear. That way you not have to worry about messing up the brushes in that step. Also, don't worry about removing the flat washer on the white gear, it comes out when you take that assembly out. Also, I could clean the old shaved off plastic from the worm gear area with it in place. Use a small acid brush to wipe it clean & add new (high temp) gear grease.
Thought I'd pass this on from my experience on doing this fix. Hope it helps.
BMW CCA #132981 Tarheel Chapter,
Old 01-14-2017, 07:54 AM
hjdisch hjdisch is offline
Mein Auto: X3
Any suggestions on H2 replace rear brake light
Old 01-14-2017, 12:43 PM
Here's a link to it. see post #3. brake light
Old 01-15-2017, 10:51 PM
Dlissimore Dlissimore is offline
Mein Auto: 2006 X3
Great post!
on an unrelated note does anyone know how many Nm of torque this is: Tightening torque: 27 00 11AZ
I can only seem to find torques mentioned in this format and its driving me crazy..
Old 01-16-2017, 06:34 AM
Originally Posted by Dlissimore View Post
Great post!
@Dlissimore .......I think this is making reference to a specific specification manual, not a torque value. You would have to go to that reference "book" or "sheet" & then find the "thread size" & finish to determine the torque value. my $.02
I did a search & got this page...... http://www.readbag.com/bmw-m-techdata-torq-bmw-torq
Old 12-06-2017, 12:15 PM
GeoffB GeoffB is offline
Mein Auto: 2006 BMW X3 3.0i
Changing driver side HID Xenon bulb
Hello Everyone!
Just finished installing the Xenon bulb on the drivers side for my 2006 BMW X3 3.0i. Took pictures while installing, so I wrote up a "how-to". I'm guessing I'll have to do the passenger side soon (only did one side, these bulbs are expensive!), so if this tutorial goes over well, I'll write the passenger side follow-up when that time comes.
Hope this helps someone!
BTW, this is for the low beam (forgot to put that in the tutorial, would probably make a difference!)
File Type: pdf 2006 BMW X3 Driver Side Xenon Bulb Replacement.pdf (1.49 MB, 89 views)
Old 08-20-2018, 11:17 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Link to some tips on Rear Spring replacement for 2006 X3 E83
https://www.bimmerfest.com/forums/sh....php?t=1266698
Old 04-24-2019, 04:16 PM
rafiqi rafiqi is offline
Mein Auto: 2006 e65
2005 X3 low beam drivers side not working?
Hi all...Replaced bulb (was blown)...Low beam HID. Will not come on. Plugged it in on passengers side and works fine. Also High beam will not "Toggle"...I.e will not stay on ...Only works as a flasher. LCM maybe?. If SO...Can I get one of Ebay?
Thanks.
diy, e83 x3 maintenance, x3 fuel filter replacement, x3 starter replacement
