Broken roof rack mount cover - options - Bimmerfest - BMW Forums
Old 08-20-2015, 09:30 AM
geomax geomax is offline
Mein Auto: 335i
Earlier this Summer I had a roof racks installed on my car. I'm pretty much done with them for the season, so decided to remove them. When I removed the front rack, I discovered that the installer had broken the small flap that covers the mount point (right front).
I tried gluing it back together but it broke again as soon as I tried to fit it back in (Well, worth the try..).
Called the dealer - to replace that little plastic part they claim the entire trim piece needs to be replaced and painted. Total cost installed $265.
So...there must be some other options here. Does anyone have any suggestions or work arounds?
Old 08-20-2015, 09:54 AM
Mein Auto: '06 AW 330xi
What is broken? The tabs on the side of the door? Or the plastic retainer under the rail that hold the door in place?
I would first try going to a local junk yard or look on eBay.
BMW sells a matte black version. Replacing both sides would be cheaper than paying the dealer for one. However, since this is a long piece, shipping will probably be expensive.
You could also get the primed version and spray it yourself.
Roof rails:
http://www.ecstuning.com/BMW-E90-328...ior/Body/Roof/
OEM paint colors in aerosol cans can be found here:
www.expresspaint.com
Old 08-20-2015, 10:43 AM
Mein Auto: 335i
Roof rails:
Yes, the hinge on one side of the door. I was hoping to just replace the door itself. Just a small plastic part...seems silly to have to replace the entire trim piece.
Old 10-20-2016, 04:14 PM
reaso2000 reaso2000 is offline
Mein Auto: 335ix
Any luck finding the covers?
I have a couple missing, I suspect someone stole them!
Marc
Old 03-17-2017, 12:40 PM
e2thed e2thed is offline
Mein Auto: 2011 BMW 535i
Where you able to find a solution? I have the same issue now.
Old 03-18-2017, 08:47 AM
Mein Auto: 335ix
I found an entire (used) black rail on ebay for $25, removed the flip covers, and painted them. Unfortunately, as others have posted, BMW does NOT sell the covers separately. Left or right doesn't matter, I just made sure the body style was the same (E92 in my case).
Good luck!
Marc
Old 10-21-2019, 09:17 AM
Beau2424 Beau2424 is offline
Mein Auto:
What do you actually look up on eBay? Can't figure out the words to use. Storm blew one off last night on my passenger side.
