Maintenance for the long term - Bimmerfest - BMW Forums
Old 01-08-2018, 11:07 PM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
After going back and forth for a month or more on whether to trade my 2013 Msport 35i for a new model X3 or even an MB AMG GLC, I've decided to keep the one I have and add the Dinan upgrade kit (360HP, 394 ft/lbs). My X3 has been relatively problem free and is paid for, so sinking a little extra into preventative maintenance seems to make more sense than dropping $60k for a little extra power and options on the new X3. I decided the gear shifter on the column is a deal breaker for me on the MB; not to mention the cost.
I currently have 85k miles on my X3 and would like to keep it another 4-5 years. At the rate I'm driving, that would mean to about 150k miles.
I'm putting it in the shop next week. Other than the items listed below, what else should I have them change?
All fluids (brake, antifreeze, oil, transmission, differential)
All belts
Any hoses that feel soft
Rear brakes (fronts still have about 30% left)
Spark Plugs
Coils???
I put question marks by the Coils because I have not seen any discussions on this board about seeing a benefit of changing them until they fail. Coils are a known performance improvement for turbo Porsches and are often changed when the spark plugs are changed. They are about $60 each. Since the X3 is also a turbo vehicle, do you see any benefit to changing coils at the same time as the spark plugs; especially if I add the Dinan power kit?
thanks.
1979 Porsche Tobacco Metallic 911SC
1996 Porsche Guards Red 993 C4S
2005 Porsche 996 Turbo S
2003 BMW Ti Silver M5
2013 BMW X3 35i Carbon Black M-Sport
Old 01-09-2018, 06:51 AM
jman103099's Avatar
jman103099 jman103099 is offline
Mein Auto: f48 X1, e46 330ci, i3
Have you already changed the plugs/coils once? If not, and you're at 85k, I'd change the plugs AND coils.
I would add transfer case fluid to that list - the fluid is expensive (about 50 bucks) but labor should be easy. Some do the front a rear differentials too, and if you're already under there and keeping it another 4 years I probably would.
2019 i3 (11/19 - present)
2018 X1 (9/17 - present)
2004 330CiC (8/15 - present)
2015 i3 (4/18 - 9/19)
2011 X3 28i (1/12 - 11/17)
2011 328i (5/11 - 6/17)
2009 MINI Cooper (4/09 - 5/11)
2006 X3 (03/07 - 1/12)
1995 325i (05/06 - 3/09)
1985 325e (08/00 - 12/04)
Old 01-09-2018, 12:58 PM
Toast. Toast. is offline
Mein Auto: X3m, B8 Avant
Might want to have them swap out the battery.
Old 01-09-2018, 03:37 PM
guyver626 guyver626 is offline
Mein Auto: x3 35i
If you donít mind can you post what you decided to have done. And the cost. I too plan on keeping my x3 for the long term and want to know the ballpark maintenance would cost me. Thank you!
Old 01-09-2018, 05:50 PM
Autoputzer Autoputzer is offline
Mein Auto: 2014 535i + 2018 X3 30i
Sunlight damage sneaks up on you. I put a towel over the steering wheel and leather gear shift knob and boot when I park the car for any length of time. Armor-All for the black plastic.
I use wax for the paint. But, there's probably something better out there. The horizontal surfaces get more direct sunlight and get it all day. The sides, front, and back of the car get a glancing blow of sunlight and are in the shade half the day. So, I wax the horizontal surfaces twice as often as the vertical surfaces. I do the nose, mirrors, and A-pillar then too, but for added bug splat protection.
Since you have heavy tinted glass in the back, you could focus efforts on protecting the interior in the front. When I was parking at work all day, I'd throw a towel over each front seat and the dashboard. Eventually, the A-pillar upholstery came unraveled at the bottom on my E46. Putting a piece of poster board on the outside of the windshield above the bottom of the A-pillar would have prevented that.
It helps to park you car in different directions in sunlight. A had a neighbor with a west facing carport. The front of their car was fine. But, the back of it was fried to a crisp from sunlight damage.
In addition to the belts, there's also a tensioner that could be replaced. There are horror stories about loose belts getting wrapped around a shaft and sucked up the shaft into the engine.
Squirt some protectant on the CV boots on the drive shafts every once and a while. The outboard front ones get the brunt of degradation, since they have to flex with the steering angle.
Old 01-10-2018, 05:08 PM
Never changed coils or plugs. I'll do both at this time.
Toast, changed my battery last year around October but good idea if it was the original.
Old 01-12-2018, 09:22 AM
Following your advice.
Old 01-12-2018, 09:24 AM
I'll have them check the belt tensioner as well. Good idea.
Old 01-12-2018, 09:25 AM
I'll follow-up with what I have done and the total cost.
