Engine "Ticking" - Bimmerfest - BMW Forums
Old 09-28-2018, 07:18 AM
Grubber Grubber is offline
Mein Auto: 1999 Z3
Engine "Ticking"
I have a 1999 Z3 Roadster 1.9 11400 miles and the engine has recently started to "tick" when I start it on any occasion either hot or cold. I thought it could be a sticky tappet. When I accelerate it also increases along with the engine. At idle it's not too noticeable and when up to cruising with a constant throttle input there is no noise. It has been fine up to a few weeks ago when this annoying noise appeared.
Old 09-28-2018, 11:42 AM
vintage42's Avatar
BMW CCA 1405
Is that 11,400 or 114,000?
Here's a thread that found one cause of ticking, bolts missing in water pump pulley:
http://www.318ti.org/forum/showthread.php?t=29401
It could also be a loose spark plug, or a sticky hydraulic lifter especially if the oil was not changed enough in 114,000 miles.
Old 09-28-2018, 05:07 PM
Mein Auto: 1998 Z3 Roadster
Look for a loose spark plug. This seems to happen fairly often.
After that, start looking for harder problems.
Old 10-01-2018, 03:09 AM
Mein Auto: 1999 Z3
The mileage is 114,000 miles
Old 11-08-2018, 12:23 AM
Mein Auto: 1999 Z3
Many Thanks for the info. The infamous "Ticking" has now stopped on its own. Curious...
Old 11-08-2018, 03:36 AM
Moxysgym Moxysgym is offline
Mein Auto:
How about change MAF sensor??
I had an pretty much same symptoms on my Z3, after changing MAF sensor, those kind of symptoms has been disappeared.
Old 11-08-2018, 08:16 AM
vintage42's Avatar
BMW CCA 1405
What made you change the MAF sensor?
