Rear Tire keep balding - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 01-10-2019, 03:35 PM
Porta Rock Porta Rock is offline
Mein Auto: 2007 BMW 550o
2007 550i
I've been through 2 sets of rear tires in a year. The inner portion of tire keeps going bald fast. Any thoughts on what could be causing this issue ?
Also the front driver side has done the same thing.
Any information would help
Old 01-10-2019, 04:26 PM
Doug Huffman's Avatar
Nuclear engineer
A proper alignment to your advised ordered numbers.
Old 01-10-2019, 07:17 PM
eburnz's Avatar
eburnz eburnz is offline
30FF <3
Mein Auto: 2007 335i sport
are u using spacers ?
Sent from my iPhone using Bimmerfest
2007 BMW 335i Sport
Gone but not forgotten:
2007 550i SMG AMRTuned (Prod. 10/2006)
2004 BMW 530i (Prod: 7/2004)
2001 BMW 525i (Prod: 10/2000)
"Call it what you want, it's a BMW"
Old 01-11-2019, 02:08 AM
Been aligned a few times. Is there any thing that may be causing alignment to go bad so fast causing this issue?
Also no I'm not using spacers. OEM Rims and Tire sizes on front and rear.
Sent from my SM-G955U using Bimmerfest mobile app
Old 01-11-2019, 05:01 AM
Nuclear engineer
No, there is alignment and there is 'alignment'. How do you know that anything was done at your first paid-for alignment, or that the mechanic did not pencil-whip you?
Study your car's allowable "in spec" alignment numbers and their effects on driveability and tire wear. Decide what you want. Discuss the numbers with trusted advisors. Go to the alignment mechanic and tell him to align your car in accordance with BMW published (www.NewTIS.info) procedures to these - your - numbers. If you don't trust him, if he pencil-whipped you, then get an alignment check before you ruin another set of tires.
Salesmen are not trusted advisors, one does not pay a trusted advisor except a lawyer (then he is bound by canons of ethics).
Mechanical or electrical problems can hypothetically cause tire wear problems
