Lights on...Lights off ? - Bimmerfest - BMW Forums
Old 05-25-2019, 02:46 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
For the last two months I've experienced a variation of the current problem.
On the 04...I've had about 1.5 years ...a cream puff...wife is the main driver (hence the urgency)...anyways, on the dash the warning light (yellow) indicates the main headlight is out! Simply put ALL headlights are functioning...I just changed the bulbs out 2 days ago.
My notion is that it's getting very hot in the enclosed/encased headlight fixtures, in addition the outside temps reaching 95degrees plus or so as of the last week . Maybe for starters ill remove those caps...(seeking some ventilation). What are your thoughts BMW brain trust?
Sent from my SM-G531H using Tapatalk
[FONT="Arial Black"]
Old 05-25-2019, 01:15 PM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
Does it throw any codes?
I'm not very familar with the dash's lights/symbols -- only once had one that proved to be for a brake light out on X3#2. Interestingly, "the brake lights still worked" because it automatically turns on the secondary extra-heavy-braking lamp (in the hatch) when the regular lamp (in the quarter panel) burn outs.
Is the same dash warning-symbol given for any one of many potential lamps being out?
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Mein Auto: 2008 X3
(site is acting weird -- double post)
Modifications:
Modifications:
Old 05-25-2019, 05:04 PM
BeeemerBro
Now this morning and throughout the day... no warning lights!
strong battery
no codes
for the first model e83 the symbols are general
ex: the 04 doesn't have the door ajar symbol.
I think it hit 100 here in Savannah while I was out driving
I'm going to uncap the headlight housing...
Sent from my SM-J727T using Tapatalk
Old 06-06-2019, 10:07 AM
BeeemerBro
-headlight out-
indicator dash light shows headlight out...but head light is working and on....04 BMW X3 182k strong battery too...could it be a sensor? cable? dash? connection is good got new bulbs. and by the next morning all back to normal no indicator light on the dash.
Old 06-06-2019, 10:45 AM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
Did you look for any corrosion on the connecting points of the lamps plug-in connector? Is there a headlight relay involved? Anything that would cause an increased resistance to the current flow in that circuit might be sensed by the computer as an open circuit.
If you can't fix it, you don't own it.
Old 06-06-2019, 10:52 AM
heifetz17 heifetz17 is offline
Bimmer buff
Mein Auto: 1990 325i, 2004 X3
That indicator doesn't only mean headlamp, it monitors headlamps, brake lamps, tail lamps, and I believe license plate lamps. Check all the lamps and see if another is burned out somewhere.
The cap is to keep moisture out of the lens. If you have the cap removed, be sure to reinstall it before washing the car or if it's going to rain, otherwise your lens will get condensation inside.
Old 06-06-2019, 12:06 PM
BeeemerBro
yes, thanks for the input...this allows me to expand my search for the solution...so the dash light is not only for the headlights got to check that Manuel again.
