Clutch gets stuck??? Help anything would work. - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 06-11-2019, 09:28 PM
ZachHersh ZachHersh is offline
Mein Auto: 1998 bmw 328i
This all happened whenever I drove over the smallest speed bump so idk wtf happened. I engage the clutch it goes in, but it goes from being super light to stupid heavy and before this issue the clutch was super heavy... Whenever I go to disengage the clutch the pedal gets stuck just after the grab point so I have to kick the clutch pedal to the side for it to come back to me and it comes up really fast and hits the plastic and this only happens a few times after startup. I havenít had time to take a look at it, but first thing tomorrow morning Iím unbolting some trim pieces and check the brake fluids.
Old 06-14-2019, 04:28 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Check under the car and see if you see any fluid dripping from the bottom of the bellhousing. There's a good chance your clutch slave cylinder is failing/ has failed.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 07-15-2019, 01:50 PM
Turns out it was the master cylinder... just needs bled now and itís good to go!
