power steering problem - Bimmerfest - BMW Forums
Old 06-12-2019, 06:35 PM
mohamedrani mohamedrani is offline
Russian Bimmer
Mein Auto: 520i 1998
Hey guys ,
the situation is this :
my steering wheel whine so bad when i drive for few minutes ( when it gets hot actually), so i changed the oil in the resivour and flushed it couple of times and then filled it and cleared the air from the system , it got quite as new , but the problem raised again when i try to get the steering wheel near to max write or left and the steering feels like something is blocking it or just heavy ,
i think it's the pump itself needs to be changed , what should i buy
only the pump as in pic 1&2 , or like in page 3 because i got confused
do i need to change the resivour and hoses also or not ?
ID:	854717   Click image for larger version
ID:	854719   Click image for larger version
Current Garage
98 E39 520i
17 Wrangler Unlimited Sahara lifted
Old 06-12-2019, 08:56 PM
CSMBlack-540i CSMBlack-540i is offline
Search, Read, THEN Ask
Mein Auto: CDN 98 540i M62 3.15
Did you check RealOEM?
https://www.realoem.com/bmw/enUS/sho...diagId=32_0720
If new pump, look for the equivalent of the below part number 32411094098 in Russia:
https://www.fcpeuro.com/products?utf...ds=32411094098
https://www.ecstuning.com/b-luk-part...411094098~luk/
So, if you plan to keep the car for a long time, I would replace the hoses too since most of them are leaking by now.
Since you've cleaned the reservoir and flushed the system already, the reservoir filter should be rather clean. On the other hand, the reservoir is only USD$15-$20. Therefore, up to you if worth it or not since it's rather cheap since you'll be overhauling the PS system with pump, hoses and new fluid.
Old 06-14-2019, 10:19 AM
Russian Bimmer
thanks alot, will change them , the problem is i can't find anywhere the hoses for the system,only original and the delivery will be after 68 days...yes 68 days i'm not kidding and the price is almost 300$ for only one of them )
Current Garage
98 E39 520i
Old 06-14-2019, 11:13 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Think its normal with a little noise when steering wheel is all the way to one side.
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 06-15-2019, 06:35 PM
Russian Bimmer
unfortunately i don't have " little noise" i have very freakin loud whining plus the steering wheel gets heavy too !
Current Garage
98 E39 520i
Old 06-15-2019, 06:52 PM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
Did you by chance mix power steering fluids, using a different new fluid ? Did you fully flush out the old ?
Did you unscrew the bolt at the bottom of the pump to drain all the old fluid ?? Did you use the right synthetic type of new power steering fluid ??
Any or all the above can cause the symptoms you are describing. But your power steering pump may be just fine.
<=E39=>
Old 06-15-2019, 06:53 PM
<=E39=>
Old 06-15-2019, 07:12 PM
Russian Bimmer
well , i didn't mix fluids, i emptied the tank and filled it totally with new one
about the bolt, i didn't know about that, where should it be , if you have any photo would be great
what i did:
1-lift the car on jacks
2-sucked all the fluid from the tank
3-kept turning the wheel to lock right and left
4-sucked the fluid again
5-kept doing that couple of times
6-took the tank away and cleaned it with fuel then installed it again
7-filled the tank and removed the air from the system
results:
less than one day enjoying quiet smooth steering wheel then the sound appeared again
Current Garage
98 E39 520i
Old 06-15-2019, 10:44 PM
Step 7 above should be :
-- Unscrew the bolt at the bottom of the power steering pump (with a 7mm Allen socket wrench)
-- Drain the remaining fluid
-- Screw the bolt back in hand tight- after replacing its O-ring gasket, though it is not necessary
-- Refill the power steering fluid to the max mark
<=E39=>
Old 06-16-2019, 09:12 AM
Russian Bimmer
will do that today,
someone told me that to complete the process , i need to empty the fluid from the Steer.col is that true?
Current Garage
98 E39 520i
Old 06-16-2019, 09:32 AM
Russian Bimmer
DEXRON III semi-synthetics that's what i'm using , is that normal?
Current Garage
98 E39 520i
Old 06-17-2019, 06:27 AM
On the filler cap it should say ATF only, and you use ATF so it should be ok.
Old 06-17-2019, 01:06 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
newer ps caps have chf 115 on them, but the usage of chf 115 didnt start til the E60. dont use it on the e39.
99 528i 5sp sport
be alert...the world needs more lerts
Old 06-17-2019, 04:25 PM
Russian Bimmer
well yeah , i use ATF and the cap has ATF only written on it, but i used semi-synthetics fluid dexron III , will flush and fill it with synthetics fluid dexron III and hopefully it fixes the issue
Current Garage
98 E39 520i
Old 06-18-2019, 05:07 PM
Russian Bimmer
UPDATE :
Unfortunatly i drained the system , took the air out , but yet again started to whine when it got warm, so i'm going to get a new pump with new resoviuor
Current Garage
98 E39 520i
Old 06-19-2019, 12:34 AM
If you are installing a new pump and new reservoir, you might as well replace the hoses.
Certainly, make sure you use new clamps to tighten them up.
<=E39=>
Old 06-21-2019, 05:39 PM
Russian Bimmer
UPDATE:
changed everything and just noticed that I've always had a problem with that pump , there was always a sound like i'm driving an electrical car when i accelerate , that of course before the whining sound started to be high and the wheel gets heavy , but i thought maybe that's the car's sound
Current Garage
98 E39 520i
Old 06-22-2019, 09:54 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
So, did changing the pump solve the problem?
2002 530i
Old 06-22-2019, 10:28 AM
Russian Bimmer
Yep , all good now ))
Current Garage
98 E39 520i
