Yellow warning lights - Bimmerfest - BMW Forums
Old 07-25-2018, 12:07 PM
Looking-2-win Looking-2-win is offline
Mein Auto: Isuzu Truck
Once in a while these light up (not all the time). After I get where I'm going & return to the car I start it back up & no indicator lights !
It can be after several additional trips over weeks of time before they pop-up again. They seem to 're-set' after the car is turned off. The manual only says;
"The Dynamic Stability Control DSC
indicator lamp and yellow brake
warning lamp for Dynamic Brake
Control DBC light up continuously:
Dynamic Stability Control DSC,
Dynamic Traction Control DTC and
Dynamic Brake Control DBC are malfunctioning."
Any idea what is causing this 'once-in-a-while' issue?
Old 07-26-2018, 10:22 AM
So I guess this has never happened before...my luck.
Old 07-26-2018, 01:46 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
It's happened before lots of times. Could be an issue with ABS, DSC, the yaw sensor under the driver's seat, a wheel speed sensor, the steering angle sensor, a bad battery causing a low supply voltage, a bad alternator causing a low supply voltage, wiring issues, a bad instrument cluster, etc.
This is one of those that if the car drives OK and it resets with cycling power, you let it alone until the light come on and stay on, otherwise it's a long an expensive troubleshooting job to try and figure it out when it's so intermittent.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 07-26-2018, 02:02 PM
So wait until it's a real problem before doing expensive time consuming repair efforts... sounds like a good bit of advise. Thanks, I fully agree with your reply.
