Airbag light on, seatbelt light off - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 05-18-2019, 05:37 PM
Kingfish01 Kingfish01 is offline
Mein Auto: M3
Hello all, recently my airbag light came on, 1995 M3, just out of nowhere. Just got in one day, started car, and the light came on. Also, it blinks once as I start the car. Also, and I just noticed this, when Iím driving and I unbuckle the seatbelt, the seatbelt light does not come on. The car thinks Iím still wearing the belt. Are these two problems related? Anyone know what the problem could be?
Also, this car is OBDI so are there any code readers that can diagnose this?
Old 05-22-2019, 02:20 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
It sounds to me like the seat belt circuit is compromised. Unbolt the seat, but DON'T REMOVE IT YET. After the seat is ready to come out THEN disconnect the negative terminal on the battery. You can then take the connections loose under the seat and check them for corrosion or frayed wires. Don't reconnect the battery until the seat connections are restored or you'll get an SRS warning that cannot be reset with normal scanners.
Some Bosch scanners work on OBDI with the correct cable.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 05-22-2019, 04:22 PM
Mein Auto: M3
Thanks, I'll give that a try
Similar Threads
Changed battery and Airbag and Seatbelt light are on 2006BMW325IMICH E90/E91/E92/E93 (2006 - 2013) 0 01-17-2018 12:28 PM
No brake lights withers2 7 Series - E38 (1995 - 2001) 6 05-25-2016 06:10 AM
What is the best place to find a list of all the light bulbs in our various E39s? bluebee E39 (1997 - 2003) 21 03-12-2015 10:17 PM
Transmission, seatbelt and airbag light on at same time bmwownerde E39 (1997 - 2003) 0 05-23-2008 08:15 PM
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 04:59 PM
