HELP PLEASE!!! Been a Week - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 05-31-2019, 10:46 AM
Stock318i Stock318i is offline
Mein Auto:
Hey Guys,
As of Friday of last week Ive been have issues with my 1995 318i. Symtoms consist of loss of power, sputtering, wants to stall when accelerating and is fine when rpms are up and also want to stall when taking off. Almost $500 in and continues the same.
So far what I've done:
Changed valve cover gasket: There was in my spark plugs
Changed spark plugs and wires
Changed Intake Manifold: Found an exhaust Leak
Changed manifold gasket and flange
Seafoamed
What else could it be.
Fuel filter?
Timing?
Clogged Cat?
Anyone else with this issue?
Old 05-31-2019, 10:57 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Some bad ignition coils perhaps? Any codes from a BMW scanner?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-31-2019, 11:03 AM
MinneSsnowta MinneSsnowta is offline
Mein Auto: 2004 545i
It has to be throwing some code that should tell you the problem. Maybe camshaft position sensor or bad pcv/ccv.
Sent from my Pixel 2 XL using Tapatalk
Old 05-31-2019, 11:16 AM
Mein Auto:
Not to sure. Car has no check engine. Idles perfectly fine when not moving.
Can i use a regular obd2 code reader?
Old 05-31-2019, 01:31 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
If your car has the OBD connector under the driver side dash then yes, a regular code reader will work.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-31-2019, 04:41 PM
Mein Auto:
Will check out the codes and purchase a new ignition coil if needed. Will update.
Thanks guys
Old 05-31-2019, 07:32 PM
john kaminski john kaminski is offline
Mein Auto: 1994 325i
Vacuum leak ?
Cheap Trick
Old 06-06-2019, 02:33 PM
Mein Auto:
No just had all hoses replaced. Changed ignition coil. Took to muffler shop and the guy told me yes the cat is shot but its not clogged. So now its in the shop. Will advise once I find out what the issue is. If they figure it out.
Thanks guys
Old 06-07-2019, 08:06 AM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
Crank or cam sensor, maf, could be lots of things.
Old 06-07-2019, 08:44 AM
Mein Auto:
Update...
Shop found the issue.
Seems I had a cracked Cylinder Head.
Old 06-07-2019, 09:49 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Ouch. $$$$
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 06-07-2019, 11:14 AM
Mistyandjess10 Mistyandjess10 is offline
Mein Auto:
My 02 325ci, had a similar issue, mine was the fule filter & fuel pump, I wasn't sure if you said you had a odd "go" when you hit the gas, if it goes slow when you hit it and as you accelerate it will speed up but then slow again it's clogged, I didn't see your year but in older convertible it's left side under back passenger seat the left is just the floater, the filter is on the passenger and it's hard to reach with out a lift or drive ups. Sorry, I missed your model but alot of places these days will not charge you before going through the computer! Don't get got! Good luck!
Old 06-07-2019, 12:59 PM
D'oh, You Kids!
You must not have read his latest post....it was a cracked head.
Quotes to live by:
BMW-CCA #441426
Old 06-10-2019, 08:47 AM
Mein Auto:
Looks like ill be replacing my motror.
57k on new motor for $1600.
Over my 240k motor that needs a new cylinder thats goin to cost me $900.
Anytime.
Old 07-19-2019, 09:37 AM
Mein Auto:
Just got my car back from the shop on Tuesday. Feels so much stronger. Everything cost me about $1,800 for motor w/labor and new water pump.
