M52 compression test - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 06-02-2019, 10:16 AM
Racer_75 Racer_75 is offline
Mein Auto:
Performed a compression test on my old '97 323 earlier and just have a couple of questions.
Firstly, numbers were very low, 75psi highest 58psi lowest. I understand that these are bad, but the engine starts very well, even in the cold, idles nice, no rumbles, no misfires and not much smoke from the exhaust. I only got the cylinder closes to the front of the car and the number went up to 100psi ( the rain came on hard before I got the rest of them) This would lead me to belive the rings were shot.
Secondly, I have pink injectors fitted, which I did with the intention on fitting a turbo. Needless to say, that hasnt happened yet so I think it would better to go back to green injectors. It has an M50 manifold, M50 mid pipe and 328i backbox, tubular headers, ecu remap,ccv delete and catch can fitted and a cai. I've lumped some money into this engine and the last thing i want is to find a new one. But I guess that is looking more and more likely and yes, it is a Nikasil block
Does anyone have any similar expieriences? I'm fine with it being a bit down on power for the amount of miles I do, but I'm curious as to wether or not changing the injectors will make a difference, maybe if there is some fuel wash? Maybe not, but thought it was worth an ask
Old 06-02-2019, 11:16 AM
bluptgm3 bluptgm3 is offline
Mein Auto: 99M32
Sounds like the cylinders have been getting way more fuel than they require for some time now.
Most likely you have accelerated ring wear.
Old 06-02-2019, 11:39 AM
Mein Auto:
The car has been sitting up for the last couple of years and I've been working on it when I get the chance. It hasn't covered many miles since the pink injectors were fitted. Literally only starting and moving it round the block a few times.
Do you think this is still enough have caused accelerated wear of the rings?
Old 06-03-2019, 12:11 PM
john kaminski john kaminski is offline
Mein Auto: 1994 325i
Possibly with all the non running and then over fueling you've got "dry" cylinders or maybe stuck rings. You might try squirting a bit of oil in each cylinder and turn it over a few times with plugs still out and then retest compression
Cheap Trick
Old 06-03-2019, 02:04 PM
Mein Auto: 99M32
^+1 based on new info…
Old 06-03-2019, 04:08 PM
Mein Auto:
Thanks a lot gents. Guess that last piece if info was quite important ***55358;***56692;
Will definitely try that at the weekend and swap back to green injectors! Thanks again
Old 06-12-2019, 05:11 PM
XTech2003 XTech2003 is offline
Mein Auto: 2002 X5 M
low compression
A friend had this happen recently. I couldn't believe the thing ran. His was a sitting too long in a humid environment. He gave each cylinder some Marvel Mystery Oil and let it sit a few days. It loosened up the rings and now compression is around 170. Good Luck!
Old 06-12-2019, 10:40 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Same situation with my 633CSi. It had been abandoned, bought at a police auction. Probably hadn't run in years, compression was awful. After treating with penetrating oil the compression came back up to the 155-160 range.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 06-13-2019, 06:25 AM
Mein Auto:
Handy information guys, thanks. Will try that as well.
Was doing some reading into the Tester I bought and I guess its one of the worse ones. In a couple of weeks I'll buy a better one
