Need help. - Bimmerfest - BMW Forums
Old 06-02-2019, 02:10 PM
tre6059 tre6059 is offline
Mein Auto:
Need help.
I just bought a 04 745li and was told motor needs replaced but after going to look at it determined it isn't the motor so I bought it since he only wanted 900 for it. Get car home and try to start and nothing just as he said but I get ever message possible come up saying malfunctioning. I've read several post about no crank but none that fit my current issue. Along with all the malfunction lights the rnd keeps flashing and windows, seats, radio display along with other electronics do not function also. Could the ecu be bad or what other computer on car cause everything to not work properly? Also want to mention the battery is weak. I've read weak battery would cause problems but would u still be able to jump start car if battery was weak or bad?
Old 06-03-2019, 02:25 AM
vibbelito's Avatar
vibbelito vibbelito is online now
Mein Auto: 2007 730i E65
Yeah I've had to jump start my car several times when the battery was to weak or completely down. (Mine is an N52B30 engine)
Skickat från min SM-G955F via Tapatalk
Old 06-03-2019, 09:00 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
I would suggest for the 1st thing you should do is replace the battery .
Once you do that , clear all codes & start from there with whatever
error codes return .( RND FLASHING usually means BAD Alternator )
Old 06-03-2019, 09:39 PM
Mein Auto:
Got battery charged today, how do I clear the codes? Will this allow to clear codes and is it worth $400? BMW INPA ISTA D P Professional Dealer Diagnostic Programming Laptop From eBay.
Old 06-03-2019, 10:00 PM
PAPER's Avatar
CRISP & CLEAN
that battery is probably not good & will not last more than a couple cranks , as I
said buy a new battery . As for clearing the codes , you need a scanner to read & clear
the errors . Oh ya you need to have the Battery registered to the car .
Old 06-04-2019, 02:35 PM
Mein Auto:
BMW INPA ISTA D P Professional Dealer Diagnostic Programming Laptop From eBay. Will I be able to read code, register battery, and program the computers using that?
Old 06-06-2019, 11:27 AM
CarFanatic CarFanatic is offline
Mein Auto: BMW 750LI 2006
Ya man you can buy INPA and cable from ebay or amazon then code the new battery the instructions are on this forum use the search to find it
Old 06-06-2019, 12:33 PM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
You can find INPA and the cable for around $65 on eBay all day long, all you need is a laptop to load it on. Get a new battery and code it to the car (easy to do with INPA), once it is coded to the car, clear all the codes for the Engine and transmission (you have to do those in separate steps on INPA. Try to start the car and see what comes back. Also make sure that the Key has a good battery in it as well, otherwise it won't start either.
Mineral White Metallic 1993 850Ci
Alpine White III 2008 B7
Old 06-12-2019, 11:13 AM
Mein Auto:
Replaced battery, cleared code and came back with several things in red. Dme, vvt, and several other things. I took pic but don't know how to post it. There was also a fault in power module, could that cause loss of communication to all the modules?
Old 06-12-2019, 06:40 PM
Mein Auto:
Done diagnostic today and everything is malfunctioning, please let me know what could cause these errors. Could bad power module cause these modules to malfunction? I replace ivm today and there are no more errors coming up on dash but still get these errors when I run diagnostic.
Old 06-13-2019, 04:25 PM
Mein Auto:
745li no crank
Old 06-14-2019, 07:52 AM
If the IVM went bad (common on these cars with this age), the car won't start and you need to replace it. Available at BMW for around $110-$120. It is a plug and play installation. The IVM is located at the passenger side firewall, in the E-Box with the other modules.
Old 06-24-2019, 06:35 PM
Mein Auto:
Replaced engine
After I replaced engine on 745 now it won't crank. When I say won't crank key inserted foot on brake and push start button and nothing. Motor doesn't turn over no click or anything. My question is could computer gone bad during swap or would I have to use computer from donor car? What else should I look at to solve this issue?
Old 06-24-2019, 07:13 PM
AlteBMW's Avatar
AlteBMW AlteBMW is online now
bimmerfest Supporting Member
Mein Auto: 2017 G12 750ix 2014 F31
What year is your 745? This is a G12 forum. There is a 745 I bleieve for the 2020 year but rior to that it was 740.
BMWCCA since '88
'17 750i xdrive. Azurite, Cognac
Other: '14 F31
Other: '14 MB E350 wagon
Past: 3, 5 (E39 and F10), 7 & 8 series BMW, C, E and S MBenzes, Alfa Romeo GTV, MGB, Toyota Celica, Lincoln, Saab, Volvo, Audi A6, A4, and others (yes I am old )
Old 06-24-2019, 08:14 PM
Mein Auto:
Engine replaced
Old 06-26-2019, 05:29 PM
Mein Auto:
No crank no start
Having issue with no crank no start. I know people say ivm but I've replaced that and still same issue. My question is if I diagnose with ISTA would it tell me if starter need replaced? These are errors that I get when I do but none related to not starting.
ID:	856149   Click image for larger version
