BMW F46 LDW successful coded - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 06-07-2019, 05:10 AM
ak0707 ak0707 is offline
Mein Auto:
Hello Everyone
I have bmw f46 220d xdrive 2016
I already have FCW from factory and INTELLIGENT SAFETY BUTTON both works. Today I successfully coded LDW in my F46
SEND_MGS_345 do not active if you get error. In my case it has been replaced by SEND_MSG_18A
Start with Kombi module step by step
1- KOMBI:
TLC_VERBAUT > aktiv
ST_TLC_TIMEOUT > aktiv
ST_TLC_ALIVE > aktiv
ST_TLC_APPL > aktiv
2- HU_NBT:
LANE_DEPARTURE_WARNING > aktiv
3- BDC_BODY: ( maybe different in FEM_BODY)
ComAdapterPdu_18A_Steurung_Vibration_Lenkrad > aktiv
ComAdapterPdu_327_Status_Spurverlassens_Spurverlas senswarnsystem > aktiv
PIA_DEFAULT_SPURVERLASSENS_WARNUNG > aktiv
If you are installed steering wheel Control Unit with Vibration Actuator Motor then code:
LIN_VARIANTE_LRE > lre_tlc
LRE_VERBAUT > aktiv
4- KAFAS2:
TLC_START_VERSION --> Aktiv
TLC_ON_OFF --> aktiv
SEND_MSG_327 --> aktiv
SEND_MSG_345 --> nicht_aktiv (if error)
DT_LNDT_SEND: messages_activated
ACTUATOR_ON_OFF > aktiv
SEND_MSG_18A > aktiv
TLC_START_VERSION > aktiv
Vibration_Value > 04,05,06.07,08,09,1A,1B
This FDL coding I did in BMW F46 and 100% works
My next project is LCW and Pedestrian Warning
Malik
ID:	854219   Click image for larger version
ID:	854221   Click image for larger version
