I have 2 1993 e34's for sale - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 06-07-2019, 12:25 PM
JagerBomb's Avatar
JagerBomb JagerBomb is offline
Mein Auto: 1993 525i
As I said there are 2 93' 525's that both need work, one is red and has a pretty good body and is automatic (something wrong that put motor into limp mode and won't rev over 4,000 rpm ) and the green car has great drive train ( standard shift ) not so good body....would have real nice car between the 2 or fix both
There are 3 sets of wheels 2 sets aluminum and 1 set of steel
Buying a new home and need to get rid of some stuff (clean out my yard )
The one pic of green car is to show the wheels but I do have the bra that's in the pic
Sold as a pair what is ball park for fair asking price ?
ID:	854253   Click image for larger version
ID:	854255   Click image for larger version
ID:	854257   Click image for larger version
ID:	854259   Click image for larger version
ID:	854263   Click image for larger version
Old 06-07-2019, 01:02 PM
south26 south26 is offline
Mein Auto: 535i 1989
Ok, so does the green car move on it's own? Miles on each and interior pics would help.
Andy
Old 06-09-2019, 08:42 AM
JagerBomb's Avatar
They both run, green car needs has tank.....green car has 200,000 miles and red car has 250,000 miles
Would like to sell both but I don't have a problem stripping them and ebaying the parts
Old 06-09-2019, 09:38 AM
JagerBomb's Avatar
Honestly if i knew what all had to be changed over i would just put the whole drive train from the green car into the red car, but I was told that changing the red car from auto to stick is more work than the car is worth.....but no one will tell me what EXACLTY all needs switched other than the obvious (trans, peddles, clutch parts, rear end...etc.)
Old 06-09-2019, 10:13 AM
To swap you need
The
Tranny (on the tranny) Brace, slave, shifter/shifter arm)
Drive shaft
Pedals (with master)
Reverse wiring
Fly wheel (need to buy new bolts
Clutch/Pressure plate
Center consul manual shifter plate, leather boot, knob
Their is a relay but I always forget which one.
I would swap the diff since the one in the auto is most likely a 4.10 which you do not want with a manual.
It is a pain but a do able job.
Andy
Old 06-10-2019, 05:14 PM
JagerBomb's Avatar
What about the computer and wiring ?
