Tire Pressure Monitor - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 06-08-2019, 02:58 PM
johnfinger johnfinger is offline
Mein Auto: 2017 540i M-Sport
TPM tells me the pressure should be 36 front/40 rear but door sill says 32/38? Which do I use. Iím running stock size tires on M-Sport, only change being I moved from run-flats to non-RF.
Old 06-08-2019, 03:12 PM
imaphaetonguy imaphaetonguy is offline
Mein Auto: G30
You've got some flexibility in the psi range.
I've always preferred a bit firmer settings.
Pick the ride setting you like best.
Old 06-08-2019, 03:37 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2018 540i
The TPMS modifies "recommended" pressures based on ambient temperatures. My baseline setting is the 32/41 per the placard for my 19" all seasons (actually I do 33 for the fronts). As long as that's where they are cold, I don't worry too much about what TPMS "says" they should be, versus the actual TPMS readings.
BMW-CCA
Bimmerfest Supporting Member
Current: 2018 540i MSport | Med Blue/Cognac| MSport Brakes | Multi-Contour | HK | ZLP
Prior: 2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather
Old 06-08-2019, 03:58 PM
jjsC6 jjsC6 is offline
Mein Auto: See Sig
Be sure your settings know which tires you have. It is configurable.
2017 BMW 540 M-Sport Carbon Black/Ivory
2016 Lexus GX 460---Wife's car
Bikes...2017 Yamaha FJR1300---2017 KTM 1290 Superduke GT---2012 Ducati Panigale
Previous BMW: 2012 550 M-Sport
Old 06-08-2019, 04:43 PM
listerone listerone is offline
Oil Burners Rule!
Mein Auto: 2018 540d
I inflate my tires to one pound higher than recommended...33 and 39.When I check the display on setting out in the AM the recommended shows as one or two pounds higher than what's on the door but the actual always equals the recommended.
Current: 2018 540d / Sapphire Black Metallic
Formerly: 2014 328d / Mineral Grey Metallic
Formerly: 2011 MB E350 Bluetec / Palladium Silver
Formerly: 2009 335d / Monaco Blue
Fuelly
HTML code is Off
