4D16: SCR Efficiency - code cleared and gone... - Bimmerfest - BMW Forums
Old 06-13-2019, 05:19 PM
kanar200's Avatar
kanar200 kanar200 is offline
Mein Auto: X5d 2011, 530e
Hi,
Around 200-300 miles ago I noticed 4D16: SCR Efficiency code when scanning with Carly. I cleared the code and it is gone. I have around 103k miles on the clock. I understand that this code may be related to some stuff which is covered by extended warranty 10yrs/120k miles.
I guess I should not have cleared the code but rather go the dealer to take a look (which could cost me $200 diagnosis fee).
Is this code always related to the stuff which is covered by extended warranty or not necessarily? Is this code stored somewhere for some period of time? In other words, is it worth to get it scanned at dealership? I guess the answer is no.
Ultimate Towing Machine - towing Jayco 28DSBH (2017)
We travel not to escape life, but for life not to escape us.
Old 06-13-2019, 06:05 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Could be related to the nox sensors going bad.. It's got an extension check bmw-rp.com
Wait and see it will come back more often. They won't do the work if there's no code.
Tell them to do both sensors as when one goes the other goes afterwards.
Old 06-14-2019, 06:04 AM
smassey321 smassey321 is offline
Mein Auto: 09 X5d - 06 325i
Random one off codes that don't set off the CEL are common on the diesel. When you get one, you need to drill down and see the frequency of triggering of the code. If the code happened once 5k miles ago, ignore it. If it happens weekly, then it is more of an issue. I don't know if carley can do this but ISTA+ can.
Old 06-14-2019, 07:25 AM
hsindogg's Avatar
hsindogg hsindogg is online now
Mein Auto: 2011 X5 35d | 2020 530xe
It will come back, if there are no other codes, it may be your SCR catalytic converter.
Sparkling Bronze 2011 X5 xDrive35d
Old 06-14-2019, 07:51 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Piqued my interest and I discovered that BMW SCR catalyst is Zeolite-Y. Unfortunately for y'all, nuclear power plants use a zeolite coolant polishing unit, so I'll be refreshing my knowledge of zeolite chemistry.
My greatest career success was in directing the replacement of a highly contaminated polishing unit under man-REM, time and dollar budget after the competing organization toofed the job for millions of dollars of clean up.
At home I found my PO had bypassed the water conditioner for not understanding its function, use and adjustment. More than ten years later the thirty-ish year zeolite water conditioner functions effectively and trouble free.
LOL. Handbook of Zeolite Science and Technology, 1200 pages at ScribD.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 06-14-2019, 08:08 AM
TroubledGnome TroubledGnome is offline
Mein Auto: 1988 M3, 2011 X5 35D
Originally Posted by kanar200 View Post
Hi,
Over the winter I had this code pop in and out setting the CEL to on and off. I've assumed it was due to age of the NOx sensors >155k miles on the originals.
I replaced the forward one this past week and went on a 600+ mile road trip. The system readiness never passed and the CEL came back on. I'm going to replace the rear one this week and I'm assuming that it will fix the problem since I've yet to suffer any issues related to pollution control.
If I understand the warranty extension correctly the NOx sensors are covered until 156k or 10 years. Code or no Code the dealer should be able to run them through a test to verify proper functionality. You will have to take the gamble and cover the cost of diagnostics should you be wrong, but you would hope to find out the reason for the code and could then act on it as a DIY or independent mechanic fix.
Old 06-14-2019, 10:52 AM
Jim E.'s Avatar
Jim E. Jim E. is offline
Mein Auto: 99 M3, 11 X5d, 16 328d XT
Hi,
This is (or are) the the NOx sensor(s). I just had this code and it was covered under warranty. They ended up replacing both of them. They also had to replace my SCR Mixer but that was not covered.
See attachment.
Old 06-14-2019, 12:19 PM
kankou kankou is offline
Mein Auto: 2012 X5 35d
What was the bill for the SCR mixer?
Old 06-14-2019, 12:34 PM
Jim E.'s Avatar
Originally Posted by kankou View Post
what was the bill for the scr mixer?
$240 which is a rip imo.
