E36 expansion tank - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 06-18-2015, 03:17 PM
Dr36wL Dr36wL is offline
Dr36wL
Mein Auto: 1999 328IC
E36 expansion tank
So I took my e36 to the shop to get a basic 100k maintenance/inspection. And while I was getting a few things fixed they found out my expansion tank is "cracked severely, and leaking coolant into my engine." Parts and labor would have been just under $500. A friend and I took a look at it afterwards, and found it was not as bad as the shop it said it was, but should be replaced in the near future. Do you absolutely have to have a Genuine BMW expansion tank that costs a hundred dollars, or can you can have a different brand expansion tank thats a lot cheaper ?
http://www.ebay.com/itm/331090566810...MakeTrack=true
Old 06-18-2015, 03:49 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
You don't have to buy from the dealer, but you can look up the part number of the parts you're looking for on realoem.com or bmwfans.info and then go out on the web and find a source. FCP Euro has genuine BMW for $79. Behr is also a good aftermarket brand as they are an OEM supplier to BMW.
https://www.fcpeuro.com/products/bmw...dVkhoC5O3w_wcB
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 06-18-2015, 04:36 PM
Volken Volken is offline
Mein Auto: 1992 318iS
Go to an advanced autoparts/CarQuest, tell them to get on Worldpak and order one that way. should cost about 20$.
Only millionaire's buy new BMW's, and only billionaires buy 'em used. - my dad.
My 318iS is a love hate relationship.
Old 05-25-2019, 10:37 AM
shaun.marsh shaun.marsh is offline
Mein Auto:
I have a BMW 328i 2013 There is a coolant leak, the expansion tank leaks all coolant by the end of each day & coolant light comes on. The expansion tank & rad hose has been distorted. The thermostat always shows normal reading& car has never overheated. Been advised head gasket wants changing?
328i, e36
