What did you do to the 5er today? - Page 69 - Bimmerfest - BMW Forums
Old 06-10-2019, 06:50 PM
Bradleyjs Bradleyjs is offline
Mein Auto: 2019 F90 M5|2006 E60 550i
Hmmm, where do I start. Over the last few months I've been reviving my 2006 E60 500i M-Sport. I have been physically unable to drive over the last two year due to some medical issues.
- Battery Replacement
- Oil and all filter changes
- Radiator Coolant
- Replaced front/rear wind trim moulding (the FL sun just melts them - i go through them @every 5 years)
- Removed both headlamps to replace the rubber/plastic gaskets, polish the lenses, repaired some insulation wiring due to sun damage, bought and replaced "possible" effective SMC modules to fix an adaptive headlamp error (turned-out that ddnt fix the problem). After troubleshooting for week or so, just put the original modules back in and no more error and its working as designed (go figure)
- Purchased another car cover (this is #3) - typically the outdoor, heavy duty BMW car cover just tends to disintegrate from the sun - so i stopped using them for some tome. Note: With my previous car, a 1999 E39 540i/6, i went through four car covers.
- Completely detailed the car's interior, engine bay and trunk
- The paint's clear coat (a significant amount of it is ruined from the sun) but the majority is now highly polished and I perform daily upkeep to keep it in that state
- Replaced the window tint (it got ruined by the sun too!) with a slightly darker tint to hopefully hold back some of those damaging UV rays
- Took apart te third brake light assembly to clean it out from some white looking debris. How it ever got in there is your guess. After having the new darker tint it debris stood out like a sore thumb. I had to order, today in fact, a new third brake panel cover as the original shattered (from the sun, of course) and it broke two of the four clips and it's just hang'n In there now.
- There are more details of things I've done over the last few months - but I don't want to bore you (I do keep a daily log of all changes/additions just so that I can't remember what I did and when)
At this point, and @$2400.00 later, the car looks and rides like new. I've been the only owner and having for so many years yes mileage is only 90,550 as of today. Additionally, the engine is younger than the car body at around $65K miles it blew either the water pump or oil pump (many, many years ago I don't remember - wasn't logging back then) they had to tear into the engine to repair it and my SA told me that while te engine is being rebuilt that I should consider changing out the typical wear-n-tear items during the rebuild. I chose to do so and I immediately notice a significant improvement in the engine dynamics.
- Radiator Coolant
- Replaced front/rear window trim moulding (the FL sun just melts them - i go through them @every 5 years)
- Removed both headlamps to replace the rubber/plastic gaskets, polish the lenses, repaired some insulation wiring due to sun damage, bought and replaced "possible" effective SMC modules to fix an Adaptive Headlamp error (turned-out that ddnt fix the problem). After troubleshooting for week or so, just put the original modules back in and no more error and its working as designed (go figure)
- Purchased another car cover (this is #3) - typically the outdoor, heavy duty BMW car cover just tends to disintegrate from the sun - so i stopped using them Note: my previous car 1999 E39 540i/6 i went through four car covers.
the paint (a significant amount of it is ruined from the sun but the majority is now highly polished and I perform daily upkeep to ensure that it stays in that state
- There are more details of things I've - don't want to bore you (I do keep a daily log of all changes/additions just so that I can remember what I did when
Old 06-10-2019, 08:23 PM
daka daka is offline
BMWCCA 12660
Mein Auto: Lots
Back on the road,,,good...
Old 06-11-2019, 04:31 AM
Ps. I wonder why it posted twice...?
Old 06-25-2019, 07:18 PM
TX550 TX550 is offline
Mein Auto: 2008 550i
Decided to check in on the thread I started 4 years ago...going strong!
Didn't do this today, but had to change the oil pressure switch recently because in the middle of a 4 drive, I started getting a low oil pressure warning. Immediately pulled over to check for oil level and any weird noises. Oil pumps on N62 engines don't seem to be a problem and the check valves on the head were unlikely to be gummed up because the inside of my engine is really clean so I figured it had to be the pressure switch that I replaced 5 years ago. Bought a new switch at Autozone, which surprisingly had one for $15, when I reached my destination and installed it in 30 minutes. No more warning so far!
The Q-Ship
The Q-Ship
Old 06-25-2019, 09:19 PM
ABCarr ABCarr is offline
Mein Auto: 2009 550i
Sounds about right.....I recently replaced mine (second one in 4 years).
Old 06-25-2019, 10:50 PM
The autozone duracrap sensor has a lifetime warranty, so won't have to pay for them anymore at least.
I was planning to inspect and potentially replace it soon since the vacuum pump was going to come out because of a leaky front seal. Guess it beat me to failing before I could replace it. Still need to do the vacuum pump though.
The Q-Ship
Old 06-26-2019, 06:14 PM
motohunter4's Avatar
motohunter4 motohunter4 is offline
Gearhead
Mein Auto: 85 735i Euro, 08 550i/6
Been working on the 7er lately. https://www.bimmerforums.com/forum/s...-adding-parts&
Sent from my LGLS755 using Tapatalk
Old 06-26-2019, 08:47 PM
mull6's Avatar
mull6 mull6 is offline
Mein Auto: bmw 528i xdrive
Thatís an awesome car, I love the look of the older models.
Old 06-27-2019, 01:19 AM
Oh, damn, didn't realize you are here on this forum too! I was reading your thread over on bimmerforums earlier today.
Guess we're E23/E60 twins
The Q-Ship
Old 06-27-2019, 05:02 AM
Gearhead
Thanks. Yeah talk about two opposite ends of the BMW sedan spectrum.
Old 06-27-2019, 11:08 AM
Defintely. Interesting to see the differences between a design from the mid-late 70s and the early-mid 2000s.
The Q-Ship
Old 08-25-2019, 07:56 PM
cmyachtie cmyachtie is offline
Mein Auto: E60545i
So I finally decided to replace those 2 lithium batteries in the alarm siren located behind the right rear wheel, which turned into a messy job, but on the bright side will get better mileage as I wonít be driving around with a ton of gravel anymore....lol.
There was more dropping out after I took the pic......
My current daily driver:
2004 545i.... Aux+SB Chime+Dig speedo+iDrive discl. Coded+BT streaming MOD.Added. And the "mschumpert Trunk lid hack". Replaced TCU with a 2007 version that works!
1998 528i, 5 spd manual, black on black non DSP. SOLD @348Kkms.
My previous rides worth mentioning:1970 GTO "The Judge",1985 325e M3lite, Euro BMW +
1998 mTech 323Ti, in Munich, Germany on the autobahn for 1 yr
Old 08-25-2019, 09:17 PM
theroux theroux is offline
Mein Auto: 2006 E60 530i
It's been a big few months for it.
- Valve cover gasket
- Shocks
- Fixing the passenger seat occupancy warning
- New non-runflat tyres (love the smoother ride!)
- New front control arms
Still to do
- Oil pan gasket, which I'm not looking forward to since the subframe has to come off
- Oil filter housing gasket
Overall I've been really enjoying the car. I've had the past two generations of 5 series but this one by far has had the best handling of the bunch, my E39 felt like a heavy boat compared to this E60.
