dielectric grease - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > Everything Else > General Automotive Forum
All non-BMW car talk goes here...
View Poll Results: Dielectric Grease
Never use it 1 50.00%
It's Snake Oil 0 0%
Use it on everything 1 50.00%
Use it on most things except ...... (please specify 0 0%
OTHER 0 0%
Voters: 2. You may not vote on this poll
Old 06-12-2019, 06:17 PM
jaye944's Avatar
jaye944 jaye944 is offline
Mein Auto: 128i Cabriolet '12
dielectric grease
so do you use DG on everything on a BMW
would you not use it ever
would you DEF not use it on some things
it's snake oil ?
I've NEVER ever used DG in 30 years of wrenching
thoughts
__________________________________________________ ____
IF you DON'T like my post "MOVE ON"
IF you DON'T like my reply "IGNORE IT"
If your rude you'll get "IGNORED"
Old 06-12-2019, 07:32 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Canít it decompose/break down and cause the contacts to fail early? Where do you want to use it?
Sent from my iPhone using Bimmerfest
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 06-13-2019, 04:23 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
WooHoo. More PolyDimethylSiloxane and fumed silica.
I know what is dielectric grease, do you?
Dielectric grease, is a waterproof grease made by combining a silicone oil with a thickener. Most commonly, the silicone oil is polydimethylsiloxane (PDMS) and the thickener is amorphous fumed silica.
Years ago I bought a pound of Dow Corning - DC-11 silicone grease and use it where ever I want to apply PDMS with no danger of it running - door seal weather stripping, for instance. Underhood water excluding bulkhead weatherseal!
Dielectric means roughly resistor, and many idiots mistake dielectric grease for waterproof contact improver, like NO-OX-ID
https://www.sanchem.com/electrical-c...lubricant.html
This is what my local power coop uses and when I need a dab I just visit them.
DO NOT USE DIELECTRIC GREASE ON ELECTRICAL CONTACTS CONNECTIONS. Now that I think of it, as a sailor I used to maintain 300 KW DC motor-generators with huge commutators and brush sets - with big warning signs to keep atmosphere contaminants away, and they lived in hermetically sealed air cooled enclosures. Silicones and oils ruin commutation. We used to polish the commutators with heavy canvas.
Old 06-13-2019, 08:04 AM
jaye944's Avatar
hey Doug,
good explaneo
I'm seeing this stuff on you tube, for example on sparkplug boots and when changing bulbs,
gets gooped in, this one channel was discussing DG
said some people slap it on everything,
just wondering on the BMW,
this was the initial vid I watched
thoughts ?
Old 06-13-2019, 08:22 AM
Nuclear engineer
Wonder why my power company guys don't use it, and do use DE-OX-ID. The conspiracy of ignorance masquerades as common sense.
Or try the logic from the other direction. If DG is so cheap and effective then why don't the OEM's use it? How deep does the conspiracy extend?
I was a professional IBEW union marine-electrician journeyman-leadingman that never had engineering instruction procedures to use DG.
Old 06-13-2019, 01:38 PM
jaye944's Avatar
yes very good point ? everything is always assembled dry, no lube, no silicone grease, no anti-size.. now is that because everything is new, or the "cost" and time of slathering goop adds up.
is it to promote wear and future repairs.
I remember when I asked about spark plug replacements on the 1er, 2 camps came up, use anti-sieze and as the manufacture said DONT use it.
good points
that said, in the uk, on the telco side, many years ago, when the guy's did repair work and spliced wire together, they had a joint connector which essentially had a metal piece which clipped into the old and new cable (essentially tieing them together) it was a transparent
circle of plastic and it was filled with a clear goop, when you then crimped to get the joint.
but is was for telco cabling, using less than 50v at only a few milliamps
