Getting Z4, what common problem i should be aware of? - Bimmerfest - BMW Forums
Old 03-22-2012, 08:08 PM
hikari_118 hikari_118 is offline
Mein Auto: Civic Si
Hi all,
I am planning to get a Z4 in this weekend, i haven't owned any bimmer before, so i went to dealership and test drive a z4, but not quite sure what common problems i should check when i buy a z4 from private seller.
also, does bmw cars have vin stickers on fenders? I couldn't find any sticker on fenders
Old 03-22-2012, 08:21 PM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
I didn't uncover this until yesterday as I was changing the license plate holder on my '08 Z4.
Behind the license plate, on the fender, there is a sticker with the VIN number. At least on my car, there is, and I have no reason to believe other Z4s are similar. I wondered about the purpose of it, and I suppose there is one, but reached no conclusion.
jake
Old 03-22-2012, 08:24 PM
Mein Auto: Civic Si
jake
Sorry for my bad understanding.
isn't the license plate hanging on front bumper? im a bit confused here
Old 03-22-2012, 09:36 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
The biggest problem I have is everyone shouting at me (nice car!)
Old 03-23-2012, 09:21 AM
Mein Auto: Civic Si
yea sure it is!!
Old 03-22-2012, 09:41 PM
There isn't really any problems to look out for on the z4. They're pretty solid cars and the engines are near bullet proof. As long as all the proper maintenance has been done over the years and have had no accidents you should feel pretty comfortable buying the car. The z4 was also my first BMW and I love it. Ohh. Tires are the biggest thing. These cars have a trimmling problem. The source is almost always low grade tires. Runflats ride like crap. Continental dw or dws tires are the most favored for these cars.
Old 03-23-2012, 09:23 AM
Mein Auto: Civic Si
oh i like DWS, i had it on my current civic SI, they are awesome!
but after reading few pages of thread, what do you guys do if your car has a flat tire? there's no spare tire, am i correct?
Old 03-28-2012, 08:09 AM
bimmerzone bimmerzone is offline
Past Sponsor
Mein Auto: E63 650i, F13 M6
A lot of our customers get a space saver spare tire
Just in case you wanted to check it out:
http://www.bimmerzone.com/BMW_Perfor...85E86-KIT.html
Hope this helps
Old 03-22-2012, 09:43 PM
And the vanos seals dry out over the years so those might have to be replaced. But nothing to worry about.
Old 03-23-2012, 09:25 AM
Mein Auto: Civic Si
how many miles should that be replaced? and how much would it be?
Old 03-23-2012, 06:57 AM
crewdog843's Avatar
Not on front fender, on rear fender. Nevada is a two license plate state but not enforced. I have nothing on the front of mine (except for four holes).
jake
Old 03-23-2012, 09:27 AM
Mein Auto: Civic Si
jake
I see, does it mean there is no VIN stickers on front fenders?
Old 03-23-2012, 09:20 AM
SC2003Z4 SC2003Z4 is offline
Mein Auto: '03 Z4 2.5i Silver/Black
Hikari, what year are you looking at buying?
When you go to test drive make sure to rev up the engine, I found out my car needed a new throttle body on the first week of owning it....awesome!
Best thing is to pay for the pre-purchase inspection by a dealer who can see all the BMW codes, not just the OBD codes.
Javier 03 E85 2.5i
Old 03-23-2012, 09:31 AM
Mein Auto: Civic Si
Yep thats what I am thinking to do when I have test drive, I want to check for some unknown problems before I get the car
Probably getting 05+ with decent mileages; what mileage would the z4 engine would need to be rebuilt?
Old 03-23-2012, 10:52 AM
Carry a small air pump with you and a can of sealant. This will get you to a tire shop in most cases.
Old 03-23-2012, 05:21 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
i think i have read there are water pump/fan issues
Old 03-24-2012, 08:39 PM
Mein Auto: Civic Si
thanks, i better grab those before i got my car. really dont know what i can do if i got flat tires on the interstate
does water pump lead and fan will stop working?
my friend has these problems on his 330ci
Old 03-28-2012, 07:20 PM
P2ayc P2ayc is offline
Navigator
Mein Auto: 2003 Z4
Roof drains get clogged & the roof motor ends up sitting in water - have to remove the roof to replace it
If it's a private sale maybe you know it was garaged - if not worth looking into
Old 03-29-2012, 03:14 PM
keeton keeton is offline
Mein Auto: '07 3.0si
Keep in mind that the E85 Z4 was refreshed for the '06 model year. A few minor styling changes and totally different engines.
For the '05 and earlier,
- The water pumps can fail at around 80k miles.
- "Sticky steering", which involves replacing the steering column.
For the '06 and later,
- The N52 engine can have some valve clatter. At one time they were replacing the cylinder heads but now I believe they are just replacing the lifters.
For all years,
- The rear springs can break
- The power top motor can fail because of the design puts it in the path of water. You will see a rash of complaints here every spring. There are some great articles here on doing a DIY fix.
- If you ever leave the top open and it rains, water can short out some of the electrical systems, the most common being the airbag control module.
Have any Z4 you are considering purchasing checked out by a BMW-knowledgeable mechanic and you should be OK.
Old 04-01-2012, 10:23 AM
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2013 Porsche Boxster S
BMW did not change the design of the steering until July '06. So any build before then will have the old design. I found this out when my June '06 build had the problem. BMW did pay for half the cost to replace it. Cost to me $1200.
2015 Audi SQ5
Recent Past:
2009 335i Coupe Dinan S3
2006 BMW Z4
Old 08-23-2016, 07:21 AM
vesprum vesprum is offline
Mein Auto: BMW Z4 E85
Water pump / Sticky Steering
- For the water pump (and service belts), I agree on the failure rate. In fact, I replaced it, as preventive action, at around 90k,
- For the "Sticky steering" issue, though, it was unexpectedly resolved when ABS/DSC sensors (2 ea.) were replaced on the brake module. Since then the steering has been very smooth.
Old 09-08-2016, 01:59 PM
InTheSouth InTheSouth is offline
Mein Auto: 2003 Z4 2.5
Sticky Steering ?
For all years,
I have a 2003 and have this issue (sticky steering). Is it necessary to replace the column or can it be repaired (DIY)?
Old 09-13-2016, 01:54 PM
david bilton david bilton is offline
David Bilton
Mein Auto: 2006 BMW M6 Coupe
History of being garage kept is no guarantee of a dry top motor well. Water can accumulate via rainfall or car washes over the years, and it only takes a single leaf to plug the drain hole. My car had only 18000 KMs when I bought it a year ago, and is now at 24000 KMs, or 15000 miles. It has never been winter driven and its condition indicates it was always garaged. Nevertheless, I had to replace the top motor at considerable expense this summer. I suggest you get an inspection which includes a check of the drain hole condition.
current vehicles = 2006 M6 coupe, 2003 Mazda Miata SE, 2013 Honda Civic.
Past vehicles = 1999 BMW 328iC, 1998 Jaguar XK8 conv., 2003 Porsche Boxster S, 2007 BMW Z4 Roadster, 1963 Morgan 4/4 from 1964 to 1966
Old 03-30-2012, 11:18 AM
Ballinallthetym Ballinallthetym is offline
Mein Auto: 328i 2013 Convertible
Word.
Everyone listens to the man with the axe, but you may have to swing it around first.
Old 03-30-2012, 12:52 PM
madurodave's Avatar
BMW Enthusiast!
Biggest problem for me is my face muscles hurt from grinning all the time!
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
