E39 540i auto trans issue - Bimmerfest - BMW Forums
Old 02-11-2017, 01:13 AM
tlcltd2017 tlcltd2017 is offline
Dilly T
Mein Auto: BMW
My 540i will not engage first gear in drive mode, I have to use sports mode and select 2nd gear. It won't go anywhere in first gear and I have no idea why?? Can anyone help
Old 02-11-2017, 01:59 AM
ak_inshok ak_inshok is offline
BMW Hacker
Mein Auto: 1997 540i
Have you had the transmission codes scanned? Does the dash say "trans failsafe" by the gauges?
Sent from my Nexus 5 using Tapatalk
Old 02-11-2017, 07:51 AM
F32Fleet F32Fleet is offline
Mein Auto: 435i, 335d sold.
How many miles on vehicle and miles since last trans fluid change?
Sent from my HTC 10 using Bimmerfest mobile app
Old 02-11-2017, 08:12 AM
bartelbe's Avatar
bartelbe bartelbe is offline
Mein Auto: 2xe39,e34,e32,e36
Your going to need to pull the codes to determine if this is a eletrical issue or mechanical. The symptoms you gave are far to vague for anyone to point you in a logical path of correction.
Old 02-11-2017, 03:52 PM
Dilly T
Mein Auto: BMW
I'm not sure as car is parked at a mate's out of town and I just purchased it. But it works fine in all other gears
Old 02-11-2017, 03:53 PM
Dilly T
Mein Auto: BMW
Done approx 216,000k's
Old 02-11-2017, 04:32 PM
Dilly T
Mein Auto: BMW
Trans failsafe mode comes on if u try to drive in first gear and goes into what I would describe as limp mode but turn off and back on and start in second and it drives fine. If I take off in drive and it hits first gear... failsafe mode comes back up and same thing happens. Can start in second and all gears work fine from there.. first is the problem.. sorry I have no codes for you as has not been scanned
Old 02-11-2017, 10:33 PM
Dilly T
Mein Auto: BMW
Old 02-12-2017, 01:35 AM
BMW Hacker
This happened in my car and when I took the trans apart the first gear drum was shattered.
Old 02-12-2017, 01:37 AM
Dilly T
Mein Auto: BMW
Is this expensive and hard to fix
Old 02-12-2017, 06:51 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
If that's the case it sounds like your pressure regulator is the cause, when it fails the excessive pressure takes out the A drum. IIRC there is information about this posted in the E38 forum by either pirana100 or Rudie but it was DIY so not sure about any $$$.
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 02-13-2017, 03:28 AM
Dilly T
Mein Auto: BMW
Thanks heaps I will look into it. Valuable information. That's why I love this site
Old 02-13-2017, 04:57 AM
Don't forget about the codes though like bartelbe said, always a good step before tearing anything apart.
Old 02-13-2017, 11:26 AM
BMW Hacker
Agree with the codes and symptoms check first.
I took my 5HP24 apart and replaced the A-drum with a machined Kuhle unit. $120 US dollars. The master rebuild kit was about $425ish. I then bought a Revmax stage 2 torque converter and Revmax rebuilt & updated valve body. They were $399 and $599 respectively. The rebuild went well following the astg manual for the 5HP24. I had to make some tools out of abs pipe to press the retainer clips out of each drum. I also checked clearances for each and then final endplay with a gauge. It works great.
540i, e39, slipping, transmission
