How many fluids holds drivetrain BMW X5 E70 2011 xDrive35i Gasoline - Bimmerfest - BMW Forums
Old 05-04-2017, 06:23 PM
Dave1982 Dave1982 is offline
Mein Auto: BMW X5 E70 11 xdrive35i
Need help!
My X5 E70 2011 xDrive35i gasoline almost reaching 100,000 km, anyone know how many fluid holds the:
- Transfer case
- Front differential
- Rear differential
- Transmission (if flushing the entire system, including the power converter and the lines)
- Transmission (if just drain - refill fluid and changing the filter)
Any information will be appreciated,
Thanks a lot,
Old 05-04-2017, 08:59 PM
edycol edycol is online now
Mein Auto: X5 35d (traded in)
Originally Posted by Dave1982 View Post
Need help!
- Transfer case
- Rear differential
Thanks a lot,
1. DO NOT FLUSH!
2. If replacing transmission filter and just draining, 5-7ltr.
3. TC=0.49ltr.
4. Not sure about differentials.
Old 05-04-2017, 10:17 PM
FredoinSF FredoinSF is online now
The trans filter is part of the pan. You need a new pan of you want new filter which is good idea at 100,000km.
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 05-05-2017, 12:57 AM
Mr.47's Avatar
Mr.47 Mr.47 is offline
Send a message via Yahoo to Mr.47
Mein Auto: F02 740Li
Front diff is only 650ml~
Rear Diff 900ml~
LCI have the ZF 8hp45, 5.5L when R&R pan/filter, also engine has to run and trans has to be in specific temp in order to hold all 5.5L (not sure on temp spec)
Current:
2014 BMW X5 35d Xdrive Sophisto Grey Metallic /Cornsilk 50k miles
Sold:
2014 BMW 740Li Sophisto Grey Metallic/Black 39k miles
2011 BMW X5 35d Schwarz Black/Black 66k miles
1993 BMW 740iL Oxford Green/Tan 279k miles
Gone:
1985 BMW 318i Arctic White/Cornsilk 138k miles 8.15.2008
Old 05-05-2017, 08:38 AM
Rear Diff 900ml~
I think temp. is 35c, but not 100% sure.
Old 05-06-2017, 02:48 PM
Thanks you all for the info,
Today i got the vehicle back after a week of intense labor in a local garage and they change:
- Engine oil and filter
- AC filters
- Transmission fluid and filter with oil pan (without flushing the system)
- Transfer case fluid
- Front and rear differential
They also fix a leak in the crank case, replacing the gasket, rear retainer and the turbo oil return pipe,
Also clean the thottle body and replace two engine mount and the two front strut mount,
The vehicle feels very very good, but still "sometimes" hesitate a "little bit" when is in a stop. And when engage reverse gear, still produce in sometimes a noise and feel it in the pedal and in the steering wheel, don't know what it is,
Once again, thank you all for all the advice and info,
drivetrain, front differential, rear differential, transfer case, transmission, xdrive35i
