Car runs hotter on Highway - Bimmerfest - BMW Forums
Old 07-21-2017, 09:35 PM
EJL1982 EJL1982 is offline
Mein Auto: 2012 328i
I have a 2012 328i with about 65,000 miles on it and I recently noticed that it's running a bit hotter on the freeway than on side roads. It's not running hot on either, but this seems unusual. It runs at about dead on 1/4 on side roads and around 2/3 of the gauge on the freeway.
Thoughts???
Old 07-21-2017, 11:05 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
Google "map thermostat". BMWs (and other cars) are designed to run hot in low-load situations (like constant speed highway driving) so as to increase efficiency. When you're in stop-and-go, it runs the engine cooler so that the chances of overheating are small.
This is entirely normal, and is the reason that BMW no longer has temperature gauges - the fluctuations would lead people to believe that they have a cooling system failure (like you!)
Also, your temperature gauge is OIL temp, not water temp. They reflect somewhat different measurements ...
Old 07-21-2017, 11:12 PM
Thanks, this is my first BMW and I'm new to this stuff. Appreciate it.
Old 07-22-2017, 06:19 AM
Skiddz Skiddz is offline
Mein Auto: '14 428i coupe
My (new to me) '14 428 runs the oil temp exactly where yours does in those same driving situations; thanks for the info floydarogers
Sent from my XT1096 using Tapatalk
