Okay, so what grade gas do I REALLY need? - Bimmerfest - BMW Forums
Old 09-03-2018, 02:44 PM
tbraithw tbraithw is offline
ROBO-Tim
Mein Auto: 2018 320i
So I've got a very new 2018 320i.
What's the conventional wisdom on the appropriate grade of gas to use?
First inclination is to stick with Premium/93, but is it really making a difference on engine wear, crud build-up, or anything else?
Old 09-03-2018, 02:59 PM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
Here goes .......
My experience over 16 years .....
9 BMWS
One 740il
Two 535i
Two E46 330i
Two E90 328i
Two F30 328i and 330i
Over 1 million miles
All regular 87 Octane mostly QuickTrip
Never an engine problem.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2017 330i M- Sport Black Sapphire Metallic
2014 328i Mojave Metallic
2007 328i Black Sapphire Metallic
Old 09-03-2018, 03:45 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
Go with your "First inclination". In general, going with the recommended grade of gas cost about the same as scrimping on the grade because the car will change setting to accommodate the lower grade at the cost of lower mileage.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 09-03-2018, 04:01 PM
ROBO-Tim
Gas grade vs mileage
I never noticed any correlation between gas grade and mileage in my 2002 325i (std transmission). If the car automatically adapted to the cheaper gas, that factor alone didn't seem to noticeably impact mileage. What did matter was highway vs city (you can see the road trips on the attached graph) and also my gradual trend towards being less aggressive on the gas pedal. When I finally started consciously trying to optimize gas mileage (on the very last road trip), I suddenly got 32mpg instead of 29mpg.
Other than a few experimental periods, with no apparent change in mileage, that car spent its whole life on Regular/87.
Assuming that's still going to be the case, my motive to buy higher grade gas with a new car would be long term preservation of the motor against wear or crud build-up... but does it really make a difference?
Old 09-03-2018, 05:06 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
I don't believe you will get the advertised power from the car without premium, but using top-tier 87, 89 or 91 shouldn't do any damage.
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 09-03-2018, 05:36 PM
Axialflow's Avatar
Axialflow Axialflow is offline
Mein Auto: 5series 3series
+ 1
It should not cause any damage. The car will reduce power to compensate.
The computer will rate the fuel grade and log it into the DME fuel grade history.
Sent from my SAMSUNG-SM-G930A using Bimmerfest mobile app
Old 09-03-2018, 07:06 PM
John MS John MS is online now
Mein Auto: 2014 Glacier Silver 328i
BMW provides their educated wisdom on the appropriate grades of gas to use. Good advice to follow.
Old 09-03-2018, 08:04 PM
namelessman namelessman is offline
Mein Auto: bimmer
Another perspective is that, assuming ECU takes care of adjusting to 87 versus 91, when cost savings is bigger than the decrease in mpg, then it will be worth it.
E.g. 87 versus 91 has 10% difference in mpg, then fill u with 87 when price delta is more than 10%.
Around our area 87 seldom goes 10% below 91.
Old 09-04-2018, 06:22 AM
gkr778's Avatar
gkr778 gkr778 is online now
Novice driver
Mein Auto: 2014 320i ZSP ZMT
+1
For an N20 equipped 320i, that "wisdom" amounts to 89 AKI minimum, 91 AKI for best performance.
Practically speaking, that means 89 AKI gasoline for normal everyday driving, 91 AKI for track use.
What the world needs is a few more rednecks - Charlie Daniels
Tell you about rednecks. They’re probably the only people in the whole country that ain’t unfit. - Fred Reed
God and guns keep us strong. That's what this country was founded on. - Lynyrd Skynyrd
Old 09-04-2018, 07:44 AM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
Any commonly available gas'll work.
But real BMW pilots use Premium.
Do you look to economize?
Old 09-04-2018, 08:17 AM
JeffDunes JeffDunes is offline
Mein Auto: 2011 535i Sport 6sp MT
If you are leasing the car, or if you do not plan on keeping it more than a few year, then use regular. If you want to keep the car for many years then use premium as it may prolong the life of the fuel system.
2000 328ci Sport 5sp MT
1958 Isetta bubble car
Old 09-04-2018, 09:04 AM
laser's Avatar
So the nice thing about a gas thread is everyone can have an opinion.
The nice thing about our 2002 330i run on 87 regular for 200,000 miles is saving about $4500 to spend on CABs, SERP belt, failing window mechanisms, leaking OFHG, new leather drivers seat, rebuild cooling system, couple of windshields, batteries, tires ......... no engine repairs ...... but I'm rambling on now .......
Laser
How will premium or higher octane gas prolong the life?
Old 09-04-2018, 09:25 AM
gkr778's Avatar
Novice driver
That may be the case if "premium" grade gasoline contains a higher quality detergency/additive package compared to regular and midgrade gasoline. But that scenario is increasingly uncommon. Gasolines marketed as TOP TIER, for example, use the same higher level detergency treat rate for all octane grades of gasoline sold at participating stations.
Old 09-04-2018, 09:30 AM
SNye45 SNye45 is offline
Mein Auto: 2014 328xi
Always go by this: Required or recommended.
If a higher octane is required then use that octane. If not, and just recommended, its your choice to save a few cents on refills, or feel better about yourself by putting a higher octane in. The engine will adjust to whichever gas you choose.
2014 BMW 328xi Sport Line
Orion Silver
Premium Package
Lighting Package
Dynamic Handling Package
Tech Package
Cold Weather Package
Love it!!!!
Old 09-04-2018, 09:45 AM
The owner's manual for my 2011 535i states BMW recommends AKI 91 or 89, with a minimum rating of 89. It goes on to state... "Do not use any gasoline below the minimum specified fuel grade; otherwise engine damage may occur". I suggest the OP check the owner's manual and follow the recommendation there.
Old 09-04-2018, 10:46 AM
That's not answering the question. How does premium gas prevent damage to the fuel system?
BMW is not telling owners to use premium gas. Only 89 to 91 rated gas.
Old 09-04-2018, 11:48 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK, Q5
Does anyone know how often this comes up on the 'Fest? It's got to be once a month or so. Go with 93 octane.
Old 09-04-2018, 12:37 PM
According to my owner's manual it states...
"Required Fuel
Super Premium Gasoline/AKI 91 or AKI89"
I do not have an answer to your other question. If you want to know how premium gas prevents damage to the fuel system you will have to ask the engineers at BMW.
Old 09-04-2018, 12:53 PM
Not quite that often, and certainly less than an oil "discussion!"
___________
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 09-04-2018, 01:16 PM
gkr778's Avatar
Novice driver
Go with 93 octane.
93 AKI gasoline isn't readily available in many parts of the USA, and doesn't provide a huge benefit for stock F30 cars anyway over 89 and 91 AKI.
Old 09-04-2018, 02:32 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2020 Z4 M40i
Mein Auto: 2020 Z4 M40i
So you saved about $22 a month. Hard to see in financial impact, but it make you happy so good for you.
Kevin
CURRENT:
2020 Z4 M40i
2019 Chevy Suburban 4X4 RST 420BHP
2013 BMW 135is JB4 convt 6MT
2009 Yamaha V-Star
1998 Ford Ranger 4X4 Splash 5MT
1965 COBRA 550BHP FORD Racing COYOTE TKO-600
FFR Cobra Mk-IV COYOTE 5MT Build Thread
480 WHP of BURBBLES
I LOVE THE SMELL OF BURNT 100 IN THE MORNING
Old 09-04-2018, 02:37 PM
2020 Z4 M40i
Originally Posted by gkr778 View Post
+1
Run as high as I can buy for track days, 100 octane. Extra heat generated makes for a greater possibility of detonation. Street run standard 93 premium in most of the cars. Trucks run on 87.
Kevin
CURRENT:
2020 Z4 M40i
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 09-04-2018, 03:17 PM
Mein Auto: bimmer
Does 91 provide better fuel economy than 87 on your car?
E.g. 200k miles burned 8000 gallons of [email protected]
If using 91 can save 800 gallons of those with 10% increased mpg, then the savings can be 800 * $3.5 = $2800, so that $4500 savings of using 87 exclusively drops to $1700.
Old 09-04-2018, 03:30 PM
2020 Z4 M40i
$1700 in today's money is worth $1200 in 2002 money so average it out to about $1400 or about $7 a month.
Kevin
CURRENT:
2020 Z4 M40i
2009 Yamaha V-Star
480 WHP of BURBBLES
gas, octane
