Manual Fan setting acting weird. - Bimmerfest - BMW Forums
Old 03-09-2019, 10:30 AM
Hookster57 Hookster57 is offline
Mein Auto: 435i Grand Coupe
When I run my AC/Heat system in manual mode I noticed that the flow selector button on the passenger side doesnít go to the ďall 3 onĒ position that the driver side does. I can get feet, mid but not face.
Anyone else have this issue?
Sent from my iPad using Bimmerfest mobile app
Old 03-12-2019, 06:53 AM
wrickem wrickem is offline
Mein Auto: '19 G05, 07 M6
Originally Posted by Hookster57 View Post
When I run my AC/Heat system in manual mode I noticed that the flow selector button on the passenger side doesn't go to the "all 3 on" position that the driver side does. I can get feet, mid but not face.
What you're referring to as "face" is windows (defrost/defog to most of us) which can only operated manually on the driver's side in F3X cars.
*I did not make this up, it's in the manual.
current - '19 X5, '19 911, '17 Jeep Wrangler, '07 M-6
Old 03-12-2019, 01:16 PM
No, Iím talking about this in my 435:
Old 03-15-2019, 03:05 AM
Iím not seeing what you think the problem is. The driver side controls the top of the dash (defroster) in manual mode for both sides. The passenger side upper vents will never light up like the pic on the right selector button shows in your car.
Sent from my iPhone using Bimmerfest
Old 03-15-2019, 08:49 AM
The manual doesnít support that. It doesnít distinguish a difference in the function of the left and right manual mills knob.
Old 03-15-2019, 10:24 AM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
I don't know...seems pretty clear to me:
It's not really yours until you void the warranty.
Old 03-15-2019, 01:40 PM
+1
sometimes people just canít wrap their head around things though
Old 03-15-2019, 11:11 PM
Then why does the button on the right side show the same three flow directions?
Old 03-16-2019, 04:09 AM
The BMW engineers did it that way just to mess with you.
Old 03-17-2019, 10:18 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
It doesn't go to all three on nor does it go to just windshield. It's not an issue...or a problem. Just a safety feature that gives the driver control over defogging both sides of the windshield. If you want air directed to your face try opening and adjusting the vents.
Old 03-17-2019, 11:10 AM
That's all you got? As smart as you are? ***129315;
Face it, you don't know what you are talking about. The right button should blow the vents in the same three directions as the left. I'm pretty sure BMW is not that stupid to have a button not do what it says it will. Mine must not be working correctly which coming off of warranty soon I would like to have fixed.
I didn't come here to fight with you. I actually wanted to be helpful because I'm at least smart enough enough to be able to read a manual and understand the concept of the way the system works.
Now I wish I just told you to do a search like most people would:
https://www.bimmerfest.com/forums/sh...ight=defroster
Please post your paperwork here after you take it to your dealership to fix a problem which doesn't exist.
Old 03-17-2019, 01:02 PM
Well, one thing we can agree on is itís not well thought out with pictures on the buttons.
Good luck.
Old 03-17-2019, 01:41 PM
Almost all of us figured out how to operate the air handling system on their 3 series car. It works so well on Auto I rarely put it on manual. When I do the pictograms show the way. One of us is arguing for the sake of reading himself online. Much as a 5th grader would do.
Old 03-17-2019, 01:46 PM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
Ok, before guns are drawn at the OK Coral, I checked both my 2016 428i GC and my 2019 230i and both only show 2 lighted bars on the passenger side and 3 on the driver's side. My take on why the passenger button shows 3 bars is the control panel is the same panel for the right-hand drive cars, so BMW doesnít have to make two different panels for the right and left hand drive cars.
Dan
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSpt AlpWhite
Old 03-17-2019, 01:58 PM
That sounds plausible. BMW continuously goes cheap on 65k cars.
Speaking of that, howís your 428 holding up and how many miles?
Old 03-17-2019, 02:25 PM
AndDown's Avatar
just copacetic!!!
My 428i GC is doing well; did have a Drivetrain malfunction warning which disappeared at shutting off and re-starting. Had it checked out and turned out the sensor for the A/C pump was malfunctioning and pressure was getting too high. Also had them do the door lock actuator repair. Other than that, at 24000 miles, it has been good. Replaced tires at 20000 miles with DriveGuard which has done well - car is my wifeís DD and sheís a ďsomewhatĒ sedate driver. I do prefer driving my DD 230i as it drives more connected like my previous E46.
Dan
'01 X5 3.0 AlpWhite
Old 03-17-2019, 03:18 PM
Thanks for the report. I have 11,500 miles on my 2016 435 GC. Whatís the door lock issue? Iím surprised we havenít had to get the airbags recalled yet.
Old 03-17-2019, 05:26 PM
AndDown's Avatar
just copacetic!!!
This is going off topic from the original issue but the door lock actuator has been a common problem with the F3x series. I only had a one time occurrence but on my 2nd service, I mentioned it to my S.A. and he wrote up a repair ticket. Doesnít hurt that the master tech there is a friend, haha!
Here's a link and you could also do a thread search: https://www.bimmerfest.com/forums/sh...lock+mechanism
Dan
'01 X5 3.0 AlpWhite
Old 03-17-2019, 06:48 PM
Thanks for the link. Good to know. Not surprised.
Old 03-17-2019, 07:32 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 330i
Next time we'll all just say RTFM
Current BMW's:
2017 540i MSport
2017 330i Sport
Prior BMW's
2018 340i RWD 6MT MSport
2016 428 GC MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 03-18-2019, 05:05 AM
No John, one of us likes things to make perfect sense, and then there is you.
The first 3 bullet points contradict the last two in the manual on what the manual flow button does. On top of that, the picture on the button doesnít accurately represent reality.
The answer to why it was designed that way can only come from BMW. If you are honestly interested in an answer then ask BMW in Germany. And update this thread.
Old 03-18-2019, 08:20 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Functionally, BMW doesnít want passengers turning off defog/defrost when the driver might still need it. That should always be the driverís decision.
Yes, BMW is obviously saving some money by using the same button. To be fair, itís more than just another button. Itís the whole supply chain, storage, assembly/installation, and software systems that would be affected, with potential additional issues all along the way. Lots of cars have buttons that donít do anything. Pretty sure my steering wheel has buttons for features which I didnít purchase, in fact.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 03-18-2019, 08:56 AM
All I know is that my other two carís HVAC systems work much better.
Similar Threads
Air conditioner steve090619 G30 (2017 - Current) 1473 07-05-2019 02:25 AM
New 2018 F30 with manual head light leveler ? weebyx F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 4 05-22-2018 01:53 AM
manual to auto climate control andy_thomas Do-It-Yourself H.Q. 1 05-28-2009 02:10 PM
Anyone regrets getting manual transmission DevExpert 3 Series & 4 Series 128 12-12-2004 09:53 PM
X3: Manual or Steptronic ultramet X5 E53 (1999 - 2006) 1 03-08-2004 05:56 AM
