Dreaded drive train light again - Bimmerfest - BMW Forums
Old 06-23-2019, 06:24 AM
335d xdrive 335d xdrive is offline
Mein Auto:
Well yet again another drive train error light at 62000 and thought it was same problem oring on oil supply line to turbos changed that found hose had loose clips on engine block tightened put back together still drive train light looking at buying an evap machine to smoke test
Old 06-23-2019, 01:42 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
If I knew what year your 335D Xdrive was, I'd move your posting to the right forum so you could get some model-specific help. Please post your question there.
EDIT: O.P. told me via PM it's a 2014, so I moved it here, to the F3X forum.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 06-24-2019, 12:32 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
You might get pointed in the right direction by reading the codes and doing a little analysis.
Old 06-24-2019, 05:39 PM
Mein Auto:
Sorted after a smoke test on vacuum side came up a pass no leaks.noticed on turbo pressure converter that top of white tab was very brown looking changed off my brothers 2017 335d xdrive very ***x1f603; like a new car full power there are 2 of these one for small turbo and one for large turbo the other one went under warranty at 25000 no way was I paying stealership money and the drive train error did not store any codes had the same problem under warranty at 24950 they threw an egr valve, at it a fuel rail pressure sensor, fuel pump, new small turbo, and it was a 1.81 o ring on turbo oil supply line and a turbo pressure converter 70 I've also had subframe off to fit fit new Powerflex anti roll bar rubbers weekend just gone
Old 06-24-2019, 05:52 PM
Mein Auto:
Any one having problems on there f30 335dm sport with drive train error please check these before listening to Bmw dealers tell you it's turbos egr valves I've had 3 occasions now with drive train 2 under warranty now this one out of warranty first was one of 2 turbo pressure converters on right hand diagram which stored no codes,second under warranty the oring number 12 on left hand diagram.tonight I found the original 2nd turbo pressure converter had given up the ghost changed from my brothers 2017 335d xdrive and the car is back to normal mpg improved brakes better and no engine knock it sounded like my shells in bottom end of engine were gone
ID:	855895   Click image for larger version
