F30 rear right turn signal fuse ? - Bimmerfest - BMW Forums
Old 05-05-2018, 01:45 PM
Rikwudy Rikwudy is offline
Mein Auto: F30 320D sport
Hard wired 7pin tow bar electrics and over a month lost my car right rear indicator.
No voltage on site.
Is there a fuse on either fuse board in the boot or engine bay for the rear right indicator / turn signal.
Old 05-05-2018, 03:23 PM
Michael Schott Michael Schott is offline
Super Moderator
Mein Auto: 2017 VW GTI Sport MT
I can't imagine there's a fuse specific to one turn single. Did you check the bulb or check codes?
Old 05-06-2018, 10:19 AM
Jim Cash Jim Cash is offline
Mein Auto: E39 540i/A, F31 328ixT
BMW's have not used fuses on lighting for at least 20 years.
All lights are switched by software driven transistor switches. Your rear lights are controlled by the Rear electronics module - in the floor of the boot.
IN theory you should not be connecting extra lights directly - the system has a specific transistor and wiring for each individual light - and it measures the resistance on each so as to be able to detect failing lamps. Normally for a trailer you need the extra electronics module for that that controls only the trailer lamps.
I suspect that your rear module has detected a fault and has shut down that lamp circuit - but you should have a warning message.
Try disconnecting any wiring connection you made for that circuit and see what happens.
Cheers
Jim Cash
Old 05-07-2018, 12:38 PM
Thanks for sharing your knowledge Jim sounds very logical.
I've disconnected everything and it's still not getting any volvatage to the indicator.
If I disconnect the battery do you think the sensors will 're set them shelves.
Am I ok to disconnected the battery and 're connect and it still drive ect won't need to programme anything???
Old 05-15-2018, 02:39 PM
Hi guys, I've disconnected the hard wired towing electrics and soldered the wires back where I made the connections. I've put a new bulb in. I've disconnected the battery and left it for 10 mins.
And I still have no volts to the right rear indicator.
I have the warning that the indicator is not working but tried everything.
Has anyone any ideas diy without taking in to bmw and paying a fortune for which I think is a 5 min job
Old 06-28-2019, 01:30 PM
Lwlambo253 Lwlambo253 is offline
Mein Auto:
BUMP did you ever find anything? I have no voltage to my turn signal light also,
