Compact spare wheel - Bimmerfest - BMW Forums
Old 06-26-2019, 04:18 PM
JPDLK JPDLK is offline
Mein Auto: 1996 328 Ic & 2000 528 It
Compact spare wheel
Hi guys. I'm trying to hunt down a steel compact wheel for my F31. No matter where I go I keep running into a dead end except for Bimmerzone which has a wheel and tire combo. for about $390: OUCH!. I have to believe that someone is manufacturing that wheel but I'll be damned if I could find it. Also, there have to be compact wheels from other years that must fit by using spacers to compensate for any offset differences. Any ideas?
Thanks a lot
Old 06-26-2019, 04:57 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
Not many options here lately. Here are the most recent discussions:
https://www.bimmerfest.com/forums/sh...=compact+spare
Should be more discussions here: https://f30.bimmerpost.com/forums/fo...play.php?f=423
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 06-27-2019, 05:54 AM
Thanks, John I'll check them out
Old 06-27-2019, 07:41 AM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
you can use the E60 17X4 wheel on the F series with the correct tire. you'll need a spacer for the front for the 335i/340i to clear the brakes, not sure about the 320/328/330.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Present: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
Old 06-27-2019, 04:57 PM
Thanks. I've seen that before. But I currently have 18" wheels on the car. it's a 328ix Estate.
Old 06-28-2019, 08:15 AM
doesnt matter what the stock size is, as long as you keep the diameter close to stock with the tire choice. i used the E60 spare with a tire swap with my F30 and F34. those came stock with 18's and 19s
Old 06-28-2019, 09:35 AM
rpickoff rpickoff is offline
Mein Auto: 2018 F33
I have a never used donut with case and Jack. Where ate you located?
Old 06-28-2019, 11:32 AM
I understand now. I would use the wheel off an E60 and put the proper tire size on it to make the o.d. 26", is that correct? Would you happen to know also what size spacer I need and where I could buy it.
Thanks again,
Jack
Old 06-28-2019, 12:06 PM
Thanks again,
Jack
i used a 15mm, most sub 15mm spacers do not have a hub lip as they are too shallow to fit over the existing hub lip and extend the hub bore.
you may not need the spacer, the standard brakes on the 320/328/330i were smaller and not dual piston, so the spare may be fine.
i used one of a pair of rogue engineering spacers with 15mm longer M14x1.5 bolts.
IIRC i used a 135/90/17 for my F34 as that uses a taller sidewall spec than the F30/31. the stock tire size on the E60 spare should be fine as the E60 uses the same tire size as the F30/31. IIRC its 135/80/17 for the stock E60 spare.
be aware that any complete E60 spares are likely going on 10 years old now, so the tires are past their usable life span. a new tire costs about 114-140 depending on if you go with a conti or kumho. specs on both are the same, M speed rated and load rating of 102-103.
the bare steel rim is about 65 now. p/n 36116758778
i did a whole write up in the E90 forum.
Old 06-29-2019, 08:13 AM
Thanks again. You've been most helpful.
Jack
